Results 1 to 11 of 11
Thread: BC coilovers knocking
    Apr 2014
    ACT
    1,075
    quick look online seems to tell me BC coilovers almost always knock anyway. but I'm trying to find a solution for it so its not dreadful to hear.
    has anyone dealt with bc coils before? its just the RHF. sounds like when going over potholes its lose. I might pull the strut out and check the spring has been preloaded and that it doenst have room to move around much within the strut.
    when I had it on a jack yesterday I noticed I could move the strut a little bit by moving the hub with force.would knock a little bit then. wound the coil up a little or atleast til I couldnt feel slack *but I did this byh hand so it probably wasnt wound enough*
    also went from 17 clicks hard to 5 clicks hard to see any difference. its a bit quieter but the knock is defintely still there.
    what to do what to do lol
    619
    Check the nut on top of the shaft is properly tight where it goes through the spherical bearing. If it's even a quarter turn off, you get that knocking noise. Mine were constantly coming loose until I put some wick in locktite on them.
    It could also be the spherical bearing wearing if you have had them a while, they are not ideal for daily use.
    Registered User evo-gsr's Avatar
    Aug 2013
    Here and There
    851
    Ive got BCs in one of my cars....Never had these issues you mention.
    Fuck 1uz you're such a sad cunt, trolling at a rookie level is the lowest form of self expression.
    Interesting that no-one wants to come to the rescue of 1uz though. Maybe he really is an annoying flog ?
    Apr 2014
    ACT
    1,075
    They're brand new essentially. Thats what I was thinking from what I've read. i'll pull the strut off and check the nut later. thank you
    619
    Quote Originally Posted by LoveB View Post
    You shouldn't need to pull the strut off, just remove the rebound adjuster, put a 5mm Allen key in the top to hold it, and tighten the nut with a spanner. I put witness marks on mine with a paint pen so I could see at a glance that it (only one side was coming loose) was moving. After having to tighten it up after every outing, I got sick of it and put locktite on it, problem solved.
    Apr 2014
    ACT
    1,075
    even better. I read online some people say they need to be torqued while some say just make it tight. i have no torque wrench so I guess I'll just make it tight lol
    16,334
    Zing it to 2 ugga duggas.
    Apr 2014
    ACT
    1,075
    i have a chinese breaker bar tho so maybe 2 ching chongs
    Apr 2014
    ACT
    1,075
    fixed - sprinkles was on the ball. top nut had more room to be tightened
    5,290
    hahah two ching chongs.
    Good tip, need to check the ohlins in the echo, one has a slight knock
    No, that's asians
    A80 Supra
    80 Landcruiser
    619
    Cheers, happy to help.
