Page 1 of 3 123 LastLast
Results 1 to 30 of 85
Thread: Hydroforming
    Aug 2014
    New Zealand
    604
    Hydroforming
    Anyone had much to do with hydroforming? Specifically with aluminium? My intention is to use this die and sandwich 3mm alloy plate between this and another 12mm steel plate. Then hook up the waterblaster and hopefully get a this blown out to 50mm high. The die is 100mm wide.
    Reckon it'll work and the material will stretch without issues?? Dunno but should be interesting
    Aug 2014
    New Zealand
    604
    Die hole is 100mm wide.
    3,271
    3mm seems quite thick?
    Aug 2014
    New Zealand
    604
    True but by the time it stretches it will be thinner than 3mm and i want a minimum of 2mm thickness so i can weld it and strength etc. my playskool calc dosent do elongation formulas
    5,828
    I reckon you gunna need a fuckload of pressure out of that water blaster to the get that to work, maybe heat that ally up with an oxy before giving it a blast.
    Mar 2009
    Bendigo, Vic
    1,689
    Maby re think that one. lol
    Mmmmmmmmm beer.
    5,733
    Need a hydraulic hand pump I reckon
    <3 Gate Rollin's Avatar
    1,059
    Use the most ductile alloy you can find and have a go.
    I'm interested to see the results.
    Sent from my GT-I9505 using Tapatalk
    Defective Faux Forg's Avatar
    Sydney Traffic
    1,608
    I don't think you'll have enough clamping to prevent the aluminium from dragging through the dies and tearing at teh bolt holes. And when that happens you'll get all wet.
    Aug 2014
    New Zealand
    604
    Yes i could plumb in my hydraulic press pump. Its a 50 ton press and over that area would generate many more times the force than 50 ton. It would have an area of maybe 10 times the cylinder area.
    Aug 2014
    New Zealand
    604
    Haha Fondles not everything can be fixed with fire
    Aug 2014
    New Zealand
    604
    So grades 1100 or 3003
    Mar 2009
    Bendigo, Vic
    1,689
    Welding two thin sheets together along the edge would be the best way. It would give you two for one and solve the bulk of the failure points the bolt holes will make. Bit more work but WAY less leaks and bad words in the long run.
    Edit The more I think on it the more I think it will tear at the bolt holes. The tension will exceed the clamp force with ease and yield point at the bolt holes wont be far behind.
    Mmmmmmmmm beer.
    Registered User Dimi's Avatar
    Sep 2012
    1,628
    Give it a crack with 0 temper sheet, won't need crazy pressure to form it.
    3,271
    Mar 2009
    Bendigo, Vic
    1,689
    BAM! ^^^^^^^^^^^^^^ This 11tymillionX
    Mmmmmmmmm beer.
    5,161
    Was gunna say, heaps of utube vids on the subject.
    Daily: Honda Civic EK1 Hatch
    Aug 2014
    New Zealand
    604
    Yes but i havent found one using ally yet. Only way to answer the question is to give it a blast. Will try to post colin esq vid for viewing pleasures
    3,584
    I definitely prefer the idea of a hydraulic hand pump rather than a pressure washer, just more control...
    5,828
    I assume an industrial high pressure washer will be used as I dont think a home unit will do much at all to 3mm ally given the dimensions, but am defo keen to see if it does actually work !!
    Apr 2010
    Bogan City
    824
    Possibly make ur dye plate larger with the holes much further away from the dye edge allowing the material to stretch less over a larger area. I been thinking of doing something similar but not got around to it yet. My plan was to make a concave dye routered out of timber to resist the material and allow it to form the required shape. My understanding was a pressure washer generated pressures in the thousands of psi.
    irgendwo
    4,155
    i think youre pushing shit uphill with your die idea.
    with the die, youre fixing the edges and expecting the water/oil pressure to actually stretch the the metal. ie youre not forming it, youre deforming it... youre expecting to take the entire material beyond yield and stretch it into shape. who knows how the material is going to deform when you try and stretch it, plus the force required is enormous. youre trying to literally inflate a metal balloon.
    the 'welded bag' idea is on the other hand, forming the metal. the edges arent fixed, the material is free to contract at the periphery and form itself into a a 'shape of least resistance'. this shape is predictable, and and involves no stretching of the material whatsoever. its not a balloon, its just a bag of a given volume, and youre using fluid to give it its external shape
    Mit freundlichen Grüße
    Aug 2014
    New Zealand
    604
    I get what your saying but look at this
    That is for steel tho i guess. Different elongation.
    Commotion, i like what ur sayin. I could do that and even machine a step into the plate or o ring it to give more bite.
    irgendwo
    4,155
    ok, ill pay that, but in that scenario youre using a formed die to create the shape, no just leaving it to the shape of the peripheral clamp, and hoping the middle bit balloons to the right shape/dimension
    that must also use an absolute shittonne (metric) of pressure, and wouldnt be comparable to furzes kärcher washer
    Apr 2010
    Bogan City
    824
    I remember myth busters doing an episode where the did exactly what u proposed. I think it was steel and I think it may have been to try form a boat hull type thing which was rocket propelled. The details escape me but that was my inspiration.
    5005 in annealed state has yield of 35MPa and rupture strain of about 20% so I would say it would handle some decent deformation before tearing and not require all that much pressure to do so.
    Edit: found it but been dubbed in another language.
    https://youtu.be/sxcOzPzqOi8
    irgendwo
    4,155
    Whatever is driving this, it ain't small, and achieves sfa
    https://m.youtube.com/watch?v=JEOiQiC8QRY
    4,769
    this
    0 temper is annealed - up to 30% ductility in 1100/ 3300 alloys
    (thanks google)
    or learn how to anneal aluminium - panel beaters do it with panels with oxy/acetylene torch when working it
    but you havent said what the end product is for - shape/decorative - or strength /pressure retaining
    so would be a lot more metalurgy in it to select the correct aluminium grade - some can be work hardened - ie forming , some can be heat treated after forming, some even gain strength from natural ageing after annealing
    but to sttretch 3mm alloy sheet down to 2mm- 33% reduction in a piece only 100mm across is going to be no mean feat -
    4,769
    ha ha colin :
    what a nutter:
    Build a JET ENGINE using only a DRILL, GRINDER and duck tape (NO WELDING)
    Aug 2014
    New Zealand
    604
    Its just for a new set of intake manifolds. Im going to see what other grades/ tempers of alloy sheet are available. No doubt a disappointing few. Id say theres probably about 3 different grades i could get without going for an indent order from overseas
    5,828
    Thats some cray cray shit right there, who would seriously suggest to heat the material with an oxy !
