Results 31 to 60 of 85
Thread: Hydroforming
    Aug 2014
    New Zealand
    604
    Good for u fondler. U can sleep easy tonight
    irgendwo
    4,080
    Because that's how you anneal aluminium? Red sooty oxy flame
    Mit freundlichen Gre
    5,782
    Quote Originally Posted by Mc Juicy Hairy Balls View Post
    warming that piece of 3mm ally is gunna form a lot easier given those dimensions than doing it cold.
    but you lads seem to know better.
    Aug 2014
    New Zealand
    604
    What just happened?? I was pointing out your peer reviewed justification as to oxy warming and how you should be glad.
    Which if we are to be fussy was meant to be annealing multiple times throughout the forming process not hitting the job with flame to heat it up in an effort to make it more pliable. But im overlooking that. Cheers for all the comments
    5,782
    My bad, I got the wrong end of the stick.
    If not use a flame maybe use a high pressure doofa that uses hot water.
    irgendwo
    4,080
    Heating a panel in contact with a pool of water ain't going to make said metal particularly warm nor bendy
    Apr 2009
    sydney australia
    286
    The 2 things I would take into account is bend radius and grain direction... because you are forming a radius in all directions , its probably going to tear along the grain . putting the biggest radius you can on your forming dies will also help.
    3,575
    I honestly don't think it's going to work, but I'd love for you to prove me wrong.
    Defective Faux Forg's Avatar
    Sydney Traffic
    1,584
    How many parts do you want to make? Cause if it's only 2, I'd hammer form them.
    Nay sayer Mr Ed's Avatar
    14,815
    Thats some cray cray shit right there, who would seriously suggest to heat the material with an oxy !
    They said not to heat a pressurised container with water in it. Thats not the same as heating up a bit of material without the pressurised canister behind it.
    Mar 2009
    Bendigo, Vic
    1,660
    That's what I thought fondles ment. Sorry Fondles.
    Mmmmmmmmm beer.
    5,782
    I said give it some heat before giving it a blast, so this is bad same same heating it while pressurized ?
    you is make my head all confused.
    Aug 2011
    334
    Try this setup but with the bolt holes on the very outer edge, not going through the ally. Then the sheets can pull towards the middle as it forms. Maybe.
    1,179
    Good luck!
    Here's a bit of John Skola doing some wrinkle rectification while pressurized, surprised there's nothing illicit nearby ...I'd expect it's only 1.6 wall stainless -
    Here's some practical tips - and maybe some warnings.
    http://www.eurospares.com/frame8.htm
    15,296
    I reckon you're going to have to stop and anneal two or three times through the process.
    Aug 2014
    New Zealand
    604
    I can only get 5005 h34. Which is the softest. Which is rubbish. Which makes this idea suck. Im going to have to do it another way, maybe a press tool to bend a 90 degree lip all the way around. Like a big oblong dimple die
    Apr 2009
    sydney australia
    286
    Apr 2009
    sydney australia
    286
    see if you can salvage some material from somewhere else like the centre of a aluminium roasting pan, or maybe a range rover bonnet that will give you a better grade than 5005. or talk to a metal spinner and ask them where they get their material from...
    <3 Gate Rollin's Avatar
    1,059
    I'd do colin's idea of welding two flat sheets together, maybe 5-10cm bigger in all directions than you need.
    Make 2 or 3 of the thing you posted a pic of in the first post and bolt them together for strength and depth (whatever is slightly deeper than you need).
    Put a thick chunk of steel for it to sit on in a press (big press), put the alloy sheets in, then put your die contraption on top, and set the press say... 40mm above the top of your die.
    As you pressurise the alloy it'll rise up and into the die, and because it's not held down at the edges it'll be free to get forced into the die without tearing.
    I suggest a press because they're easily adjustable for the height you need and strong - you could probably make something similar/purpose built that might work better, and the setup will need refining, but I reckon it'll come closest to doing what you want.
    Sent from my GT-I9505 using Tapatalk
    Aug 2014
    New Zealand
    604
    So i went away and decided that a full on domed part wasnt really required. I figured just a nice radiused flange was the ticket.
    Did a bit of study on flow forming using an air hammer. Looks the goods in videos but i found an actual hammer was better in real life, maybe i need to increase the weight of the tool here to deliver a bigger blow? Anyway got some product churned out and im really happy with the result. Using annealed 5005 3mm sheet over a chip board former, why would u do anything else? Takes all of 10 mins each one.
    Jul 2006
    1,139
    Nice work, I pictured something much larger/deeper in your original post (was thinking sump size for some reason).
    Edit: just reread your first post. Not sure how I had come to that conclusion when you'd posted dimensions.
    Aug 2014
    New Zealand
    604
    Cheers yea i might hit the former with a bigger radius with the router and try to make it deeper. The extra clearance that would provide would be helpful. But this is a great way to make tank ends etc.
    5,782
    Thats come up a treat, nice one.
    3,108
    Top work!
    Sydney Traffic
    1,584
    Nice one!
    Aug 2014
    New Zealand
    604
    Thanks chaps. Probably pretty straight forward sheetmetal work 101 but we all learning
    Better pic
    Aug 2011
    334
    Looks great. What are they?
    Apr 2003
    434
    Thats awesome, need to try it some time.
    4,707
    Quote Originally Posted by mrniceguy View Post
    baking dishes
    Mar 2009
    Bendigo, Vic
    1,660
    baking dishes
    They are iceberg proof canoe's for little people?
    Mmmmmmmmm beer.
