Results 1 to 4 of 4
Thread: Road Speed Input (Haltech Elite 550/750)
    Canberra - ACT
    3,204
    Sketching out a new chassis wiring diagram around using Haltech Elite 550/750. ECU change isn't the main driver for the new loom but it's part of trying get better integration through the whole car.
    The chassis has a speed sensor mounted at the diff snout that is used to drive the speedometer. The output of this is pretty stable and the current loom designs don't use shielding and don't suffer from obvious interference.
    Question is in the hands of a competent tuner is the roadspeed input to the ECU actually useful? Does it assist with better computation of load etc?
    I would be retaining the same sensor and feeding the pulse output to the appropriate input on the Haltech.
    My presumption is that we could set the Haltech to do tach and roadspeed output on a couple of the spare output channels so we don't need to go through the hassle of physically mounting an additional sender in the tunnel.
    6,434
    Road speed is great, if for idle control alone.
    17,893
    if you have spare inputs and the sensor is there why not..
    Canberra - ACT
    3,204
    Cool - will send a wire or two up to the pointy end of the car.
