Results 1 to 19 of 19
Thread: WTD: L98 /LS2 /L76 /LS3 etc AC compressor bracket
    3,351
    Chasing the one with two pulleys. Anyone got one laying around that wasn't used in their mini conversion?
    3,351
    Come on there must be 100 people with unwanted AC bts leftover from their LS swap. Hook a whitey up
    sexy fingers
    Nov 2016
    Traralgon, Vic
    148
    Will have a look for you tomorrow
    VF2 Redline Ute
    E36 Track Nugget Project
    885
    Yep I had one and binned it sorry
    3,351
    Thanks gents
    3,351
    Ok change of plans anyone got an LS1 AC bracket and compressor I can just borrow for test fitting? I think they fit the L98 block
    windsor nsw
    1,185
    They will fit the block but won't line up with the balancer.
    3,351
    Thanks for the info before I went and bought a new LS1 compressor today! I guess I'll stick with the Delphi compressor and PWM control. Still chasing the twin pulley bracket if anyone has one laying around
    windsor nsw
    1,185
    I dunno if it's any help but marks 4wd do a bracket that mounts the early compressor so it lines up with the late pulley offset. Makes it hug the block much closer too
    3,351
    Yeah I've seen that. I've milled my OE bracket down to get the clearance I need already so would like to use that. Plu snot overly keen to spend another $750 on this AC system before lines. Who knows, surely I'll get bitten by the 'tight arse pays twice' mantra.
    Sensei Cobra
    Bris-bain
    6,773
    LOL, now you can see why I just ended up buying a new mount system and conventional compressor
    3,351
    I don't have a lot of faith in an aftermarket bracket like Mark's adaptors. The stock LS pulley system chucks belts so I'd be surprised if Mark's one doesn't do that. Probably fine on a low power Patrol/Landcruiser.
    But Clayton I'm keen to try and make the VE variable vane one work!
    Sensei Cobra
    Bris-bain
    6,773
    I know you are you stubborn bastard LOL.
    I used the Alan Grove bracket with the Sanden compressor.
    3,351
    I'm not as rich as you!
    885
    Checked the roof and I didn't throw mine out, PM me your address and I'll send it to you, it's the two pulley one same as the photo in the first post
    windsor nsw
    1,185
    I used the marks one on an LSA into a VZ GTO I did recently. It's a good bit of gear belt wise but need a bit of cutting to clear the LS1 sump and engine mount... and pricey for what it is
    sexy fingers
    Nov 2016
    Traralgon, Vic
    148
    Quote Originally Posted by bpm View Post
    That's marks to a tee.
    Expensive and highly likely it doesn't fit perfect.
    To OP I had a look for the bracket looks like I threw it out.
    I have that same marks bracket, had to grind down the sump and block to get it to fit. Too expensive for what it is
    VF2 Redline Ute
    3,351
    My man. PM incoming. Thanks to all!
    3,351
    Well as closure certified top bloke/sheila ITS60S hooked me up. PF is all sorts of win. Now if only he/she would send me some deets to transfer funds everything will be stable in this world once more..
