Page 1 of 3 123 LastLast
Results 1 to 30 of 69
Thread: Lightyear Composites
    Bentleigh Victoria
    3,499
    I thought I would post up things I am working on. If there is interest I will keep updating.
    I started making carbon fibre parts about 8-9 years ago as I couldn't buy the bits I wanted. I was shown the basics by Dick down in Torquay. And the rest I learned from trial and error. Most parts I make are vacuum infused carbon fibre.
    The current projects are the Fastback roof and boot for the MX5. And the big race wing.
    Today I made the first 300mm main cord element. It turned out pretty good for a first try.
    [url=https://postimg.org/image/5xvq7b3b9/][img]https://s26.postimg.org/wiy92v5op/image
    It passed the initial test- put blocks of timber under the ends and stand in the middle. I made it about 1670 wide, the width of an MX5 body. I will test it on the track, and make the 2nd smaller element to get some data. The wing feels so strong, maybe too strong. I could have built it lighter, but at least you know it will never fail. The total weight is 3.4kg's. Not super light, but not bad. I can save some weight by making the endplates 6mm. I made them much thicker incase someone want to mount the wing by the ends.
    Cronulla
    1,263
    You sure are a handy bugger light year its no wonder your so successful, and can steer as well.
    Nice work and show us the trophy at the next commadore outing.
    turbosurfer
    Bentleigh Victoria
    3,499
    Cheers, I hope the car is good enough to get a trophy at Winton. To make sure I am getting some better diff gears installed on Monday. And will look for some used slicks. That should give me half a chance of keeping up.
    Jul 2006
    1,211
    Are the ends aluminium, were they CNC or can you buy them? Does the wing bow when you stand on it or were you just trying to make sure it doesn't snap?
    Looks good mate.
    Bentleigh Victoria
    3,499
    There is zero deflection when I stand on it ~90kg's. It feels every bit as strong as steel. The ends are water jet cut alloy drawn up by me and then cad drawn over several attempts by others. Inside is high density foam cut by a foam cutter using the same cad drawings. The alloy bits do add a decent chunk of weight. So I will make them 6mm if they are not going to support the wing.
    I can try take a pic with a couple of guys standing on it. It's crazy how strong it actually is. I have no concerns about it breaking or even flexing.
    Jul 2006
    1,211
    Awesome. Actually sounds much stiffer than steel. Well done.
    Ballarat, Victoria
    361
    Keen on wing. How wide can you go? Would like 1800 or maybe wider. Can you put the mounts at the spacings I want too?
    PM me some prices
    Bentleigh Victoria
    3,499
    I can go about 1950mm Max. Every wing can/will be custom made to suit the required widths. Mounts can be done by me. I haven't worked out prices yet, I will make another one and write note all the time/costs involved.
    Bentleigh Victoria
    3,499
    I am making a standard shaped vacuum infused carbon fibre MX5 hardtop. I will show you guys what is involved. It's not a step by step how to, rather just showing the process, and how much work goes into it.
    To start, clean and prep the mould.
    Bentleigh Victoria
    3,499
    Next spray a mist of tacky spray, cut the cloth and lay it in the mould.
    Bentleigh Victoria
    3,499
    Then carefully push the cloth into all the shapes of the mould. Trying to keep the weave pattern running straight everywhere. Trim the excess. You might notice around the back the cloth doesn't line up, that's a second layer as it needs more strength there.
    Bentleigh Victoria
    3,499
    Core layer.
    Bentleigh Victoria
    3,499
    Another layer of carbon fibre is in, and a release layer over the top.
    Bentleigh Victoria
    3,499
    Next I put in the infusion mesh and infusion channel. Then tacky tape around the perimeter and place the plastic bag on, connect the lines and turn the pump on to suck out all the air.
    Now the tricky part starts- finding all the air leaks..
    Hooroo! Nitephyre's Avatar
    ormeau@gc.qld.au
    6,789
    That's cool to see how it's done
    Bentleigh Victoria
    3,499
    It is pretty cool. Next is mix up the epoxy resin, put the hoses into the pot, undo the little vice grips, and it sucks all the resin in and saturates the part. Then strip all the consumable parts off, and pop the part out of the mould, trim it, and that's the end of the making of a part.
    I finally got my Fastback moulds, so will get started on that on Monday.
    Pic of removing consumables.
    Townsville
    686
    So how do you make the mold?
    Bentleigh Victoria
    3,499
    Moulds are pretty straight forward. Prep the part, brush tooling gelcoat on, several layers of fibreglass and resin. Let it cure. Then take the part out and you have a mould.
    Feb 2014
    Singleton, Aus
    214
    Would you be interested in making panels for some of our race cars? Early commodore and a datsun 1600? Can provide panels for moulds.
    Jan 2013
    3,661
    was gonna ask about a carbon bonnet for my triumph 2000
    I like cars. Cars are cool.
    Bentleigh Victoria
    3,499
    I won't be able to take on any work for a while. I will be flat out making these fastbacks until I find someone who can do the fibreglass work. Then I can get back to doing the carbon work. I will be making the wings in between.
    Ballarat, Victoria
    361
    Make wings stat!
    Toowoomba
    1,236
    Interesting to see the process, thanks for sharing.
    Bentleigh Victoria
    3,499
    Wings will be made. Later next week I will have all the alloy parts cut. Making 20 of everything. There are a few alloy pieces seeing as this will be sold with an optional second element. So there are 8 water jet pieces of alloy to make one dual element wing.
    8,409
    I too would like to express interest in a custom Lightyear Composites wing. Will you be making carbon end plates for them?
    Bentleigh Victoria
    3,499
    Yep. I made a set for the wing, they are on the commodore now. But I want them white..
    I also made the first fastback from the new moulds.
    Bentleigh Victoria
    3,499
    Took the car out today, so took some pics of the new fastback.
    CNGAF rowdytoot's Avatar
    hotel vast horizon
    9,966
    Looks great Dave. Lettuce know when the carbon ones can be made....
    Bentleigh Victoria
    3,499
    I found a place that can make the fibreglass/carbon roof and boot sections. So it looks like in a month or less I can pump these things out. They might be a tad too expensive in carbon fibre with these guys, so I might have to make the odd one myself.
    Leaves me with doing the selling and assembly, and a lot less itchy.
    7,591
    Cool
    How do you fit in one?
