Results 31 to 60 of 70
Thread: Lightyear Composites
    Bentleigh Victoria
    3,577
    They are small cars, that's why I like them. Less weight, small frontal area, etc. I can just fit in with standard seats. The trick is to fit a race seat and bolt it straight to the floor. Have you driven one? They feel so different when you hook it into a corner, even turning into a street at an intersection is noticeably different to a normal car.
    irgendwo
    4,551
    still in for a dual element wing
    fortunately my car is progressing as slowly as your composites development... we're neck and neck
    Mit freundlichen Gre
    Ballarat, Victoria
    363
    Updates? I see on FB you got some foam cut.
    6,361
    You doing a fastback for the new model mx-5 ?
    Bentleigh Victoria
    3,577
    I have everything to make the wings now. I dicked around today making the curved alloy pieces for the wing mounts. Let me know you width and wing mount spaces. I will make one over the weekend to work out prices more accurately.
    No new model fastbacks are on the drawing board as yet.
    Bentleigh Victoria
    3,577
    My engineer wants me to beef up the mounts. He said they should be 2.5 times stronger than necessary. So will order some thicker plates, it's easy now that the drawings are done.
    6,361
    know anyone that does a fastback for em ?
    Bentleigh Victoria
    3,577
    I refinished the fastback roof and boot as well the internal frames after they had sustained some damage and lost some of there size due to over sanding from the last guy. They are all at the new place ready to go.
    Bentleigh Victoria
    3,577
    I don't think anyone has done a fastback for the ND yet. I might look into it one day.
    irgendwo
    4,551
    I'll measure up widths and let you know
    Ballarat, Victoria
    363
    I will measure up mount spaces shortly
    Ballarat, Victoria
    363
    PM sent
    irgendwo
    4,551
    Ps, saw the pics on facepalm... you only doing the one 30cm chord at present? No chance you can get couple of secondary smaller flap chords? Say like a 120mm SM101 profile?
    Also, which profile did you 'lend' for the 30cm profile you've got?
    Edit, overwhelmingly large database here: http://m-selig.ae.illinois.edu/ads/c...atabase.html#S
    Bentleigh Victoria
    3,577
    I do have the moulds and bits to make the second element as well. It's the SM183 profile. I made the wing from scratch originally from online images. That's the one I did the 1:43 at Phillip Island with. But I needed a wider mould, so started again.
    irgendwo
    4,551
    had a look, id be after 168cm width, with mounts 92cm apart.
    ideally id be after 1x 30cm chord, and 2x 12cm chords - planning a dual element upper deck (maybe with active second element), and a lower deck chord to help pump the diffuser.
    planning something like this...
    alternative incarnation making the lower chord smaller between the mounts. will make the whole thing perhaps a little less bulky and offensive on the eyes (still with the dual element upper deck though):
    Bentleigh Victoria
    3,577
    I think you may as well go with the full width one. I don't find it offensive. Just hope you can balance out the front aero.
    irgendwo
    4,551
    I can add and remove the flaps as we go. As mentioned, figured I can mount them from the end plates, so simple bunch of laser cut end plates in different configurations, and suddenly have infinite wing combinations
    8,590
    No fastbacks but there is an AM hardtop for them now. http://www.good-win-racing.com/Mazda...t/61-2024.html
    Would look tops as a fastback, especially if you could get the lines to flow like the 124 spider/coupe renderings.
    Bentleigh Victoria
    3,577
    Taking a break from the AU on gas in space thread, it's hard work keeping it up.
    I thought I should update this. The NB fastbacks are being made, finally. It's taken forever. Just waiting on the windows to be supplied, should be Tuesday. And I put one of the new fastbacks on an NA to make the boot to suit the older shape car.
    This time I included a boot spoiler built in. It will suit the shape so much better than the squarer boot of the early MX5's.
    So that is now getting moulded as well.
    Not sure if I mentioned it, but I stripped an MX5 hardtop, moulded the outside, and remade the inner frame to suit generic automotive rubbers and get rid of any gaps that will cause wind noise or water entry.
    So many hours involved.
    Here is a sneak peak.
    I have also prepped the wing mould for the main element, I wasn't happy with the finish of the surface as it had imperfections from the PVA layer. I sanded it all out, and buffed it. Applied several coats of mould sealer followed by several coats of wax. Next week I will make a wing with all the redesign alloy bits. Look forward to testing a swan neck set up on the MX5.
    The boot started like this. I merely cut the hump out of the NB boot, continuously trimmed it until it was the right size and flowed with the roof section, then bonded it on. Plenty of filling and sanding later and we have a part ready to mould.
    Bentleigh Victoria
    3,577
    I forgot about this thread.
    Brendan made a video for the guys that are receiving delivery. He did a brilliant job.
    Bentleigh Victoria
    3,577
    It's been a long process, but it's finally happening. Once I finish the next batch I want to get back onto the wings and make one for the commodore to test at Phillip island for the next VicV8 round. Then start looking at making them to sell and try and make some of my money back I have invested.
    I am getting so many enquiries from US, UK and Europe. I will look into container shipping prices and distribution. Next I will need help to get the work done.
    irgendwo
    4,551
    European Distribution is easy
    Bentleigh Victoria
    3,577
    I am getting bulk messages and emails coming in from all over the world now. The video was made for the guys getting delivery. But it makes a good video showing the fastback at the same time. Seems to be popular. 1000 views in under a day. When I get back from Europe in late September I will be ramping up the promo and manufacturing. Looking forward to catching up if we can make it work out.
    Melbourne, Aust
    614
    I do a lot of Fiberglassing, have only given carbon a go once before i knew about vacuum bagging. maybe it is time to get back into it.
    Any recommendations on a vacuum to buy? i just want to make my door's in carbon LOL.
    CISCOKIDS
    The Gentlemen's Club
    Midnight Rocker
    4,872
    nice video -
    question : appears no weather sealing (or drain lip) between the new boot lid and the fastback ?
    if you were leaving it on - you'd want something there-especially in wet uk ?
    or sold as 'race use only'?
    Bentleigh Victoria
    3,577
    The boot seals against the boot rubber just like normal.
    Bentleigh Victoria
    3,577
    Iron bark Composites is where I buy the vac pump and gear from. He delivers too.
    4,872
    ahh yes see that on the boot lid now... . also see that there is a 'bulkhead' on the fastback to seal the cabin from the gap beween the boot and interior .
    Bentleigh Victoria
    3,577
    Yep, I thought of everything lol.
    4,872
    yeah but do dead hookers fit in the boot......
