Results 1 to 8 of 8
Thread: WTD - Std Wastgate Actuator 6-8psi
    GTFO of my ED doctor ed's Avatar
    irgendwo
    3,860
    Gents...
    stewing on an exhaust idea, and involves a boost regulated mechanical valve, so rather than reinvent the wheel, i figured a simple stock wastegate actuator would be worth having a play with. some simple 6-8psi OEM garrett doover would be on the money, something like pic below.
    figured someone might have something in a parts bin?
    thanks!
    ed
    Mit freundlichen Gre
    Quote Originally Posted by Keith Duckworth View Post
    are hairy Dogsballs's Avatar
    6,990
    I just threw a barra one in the bin last week. /csh
    irgendwo
    3,860
    no beer monies for you then
    192
    Have a couple in Perth.
    Means well but is skittled
    Barra Is Life. no13b_Coupe's Avatar
    Canberra Nth
    2,793
    I got a turbosmart one here. Not for beer monies though
    BF XR6 Turbo - 2L Turbo TE - 75 TX Coupe
    - PSN: rotacoupe
    79
    I'm sure I'll have a few in Melbourne eastern suburbs, pm me if you're interested
    1988 EA S-PackTurbo - 10.6@125MPH
    あなたの母親の肛門 Shifty's Avatar
    10,254
    You are sort of reinventing the wheel a little.
    Something like this I assume is what you are trying to achieve. If it's not on a true "bypass" pipe you can cut/drill the butterfly so that it is always partially open.
    Can't speak for quality of this particular one but it's quite simple mechanically. I'll be doing something of the sort.
    http://www.ebay.com.au/itm/Exhaust-C...cAAOSwAuZX13fC
    irgendwo
    3,860
    I've got a BMW twin outlet muffler with a valve already in place. It's some impossible CAN operated electronic control doover though, so just want to replace the activation mechanism.
    I think I've got one sorted, so thanks to replays above... in case this bloke falls through, I'll drop folks a message
