Results 31 to 60 of 111
Thread: Epic roadtrip of awesomeness and new racecat
    9,051
    Quote Originally Posted by DSMAZDAGTR View Post
    Bought a donor interstate. Going to bring door locks, ignition barrell, front seats, and carpet back in the trailer if the weather isn't bad.
    Maybe also the south Australian number plates.. ..
    Pics of donor?
    great idea on the number plates
    At work :(
    18,391
    Ditch engine and insert new one?
    (TM - AVENGE)
    Needs More Boost DSMAZDAGTR's Avatar
    Geelong, Australia
    1,058
    I hear matching numbers is important...
    Interior is great except for drivers seat but think I can make it workable.
    Has a dead 4ac. Ran it out of oil he reckons. Still kicked over. New battery is already relegated to racecar (this thing practically pays for itself.). Donor also sits on king super lows..
    10,303
    What's the green seat in the original out of? Looks groovy.
    Geelong, Australia
    1,058
    No clue.. I assumed it was aftermarket.. I will get a better pic after work today.
    Geelong, Australia
    1,058
    Geelong, Australia
    1,058
    Pulling interior out.. suddenly feeling a little peckish..
    Mechanical 'Tard Cliffordcliffs's Avatar
    Aug 2014
    Not at Woody Point
    1,221
    Seat looks like golf gti ?
    Geelong, Australia
    1,058
    The things you find.... Names removed to protect the innocent..
    2,397
    Do what was in the envelope Honey Pants????
    Nov 2008
    265
    Tripper spec photos??
    Nice pickup on the 'rolla. Never see any of the 4AGE rolla's around anymore. Is rollaclub still a thing?
    Quote Originally Posted by jmac View Post
    ... he may have seen one of the signs of the apocalypse - 4 horsemen, fwd transmission, pestilence etc??
    Geelong, Australia
    1,058
    Rhanis wanted to have a play with her baby today. Bolted in new seats and took her for a private track test.. Brakes seem a bit spongy. Might need a bleed because I think the pads are ok.. Probably have not been done in a decade..
    Also, daughter had her first attempt at a motorkhana test - an improvised set similar to a lazy 8 (I was going from memory)
    9,051
    https://youtu.be/WLsROJ7RTMY
    https://youtu.be/RKd5adZslfo
    Holy shit that first video is fucking EPIC!! WHAT A TEST TRACK!!!
    Cunt.
    And in the second vid, how clean is that dash!!!???!! Keep the sun off it!
    Geelong, Australia
    1,058
    Went looking around U-Pull it last weekend was hoping to find a correct grille and new seat base for the drivers seat.
    Couldn't find any AE82's with these same seat bases. They all only had the 'flat-front' style like this:
    Certainly nothing with even close to a matching material to my existing interior.
    But, I found what looked the same style in an AE93.
    Problem was the seat bolt pattern was different.
    But, I reckoned that the foam was the same shape, so I pulled the base out to bring back.
    Tonight I fitted the 'spring' to my base frame (to replace the broken one), then installed the frame into the AE93 foam.
    Holes don't line up, but the holes are outside the foam, so it's just a hole to cut in the surrounding material that you don't see due to plastic covers in that area, so all good once it goes back in.
    Now to source the correct tartan material to allow new seat covers (or even to at least find a cover that matches my current donor interior, but that can wait - Blue slips for classic rego don't need matching seat cover material). Also, carpet is over and I gave it a quick shampoo / vac last night, but still not happy. Needs a better clean I think. Will have another go later.
ID:	103586Click image for larger version.
ID:	103587Click image for larger version.
ID:	103588Click image for larger version.
ID:	103589Click image for larger version.
ID:	103590Click image for larger version.
    Also, grabbed a period correct series 1 grille.
    Melbourne VIC
    56
    Good to see a young person learning to drive properly.
    I did 100's of laps around cones and gave me a good understanding of how a car reacts etc!
    9,051
    That grill looks the goods. You going to clean it up / paint maybe?
    Desert Nigga vet 180's Avatar
    Dubai
    3,343
    Wow, I smiled just watching this.
    Geelong, Australia
    1,058
    Road trip no. 2.
    Tow car got some new boots for the trip. Fixed the Speedo error too. And good for 15mm lift. Click image for larger version.
    9,051
    So what's the roadtrip for / current plan?
    Geelong, Australia
    1,058
    Road trip over to Adelaide. To allow parts to be interchanged better between donor and twinky over the Christmas break.
    Lowered suspension, bonnet, doors. Finish off interior. At least. Also do some cleaning engine bay, exterior. See how she scrubs up
    Unfortunately I have discovered unfortunately that the series 2 / 3 have differing front quarter panels...
    So, while they should bolt on, the donor quarters, lights and grille would convert my series 1 '86 into a series 3 '88 front end...
    Not certain that's the right thing to do.
    Also, hoping to get some local mates with vast twinky experience to have a looksie at her...
    I was going to drive it over for epic fun-ness.. But decided I'd rather not risk something going wrong. Also, could only drive on permid during daylight hours, and that didn't quite fit into my plans for the weekend.. Oh well.. Will grab a permit one day over christmas for a fun hills run...
    Arrived at destination:
    Fitting like a glove.
    Series 1 Quarter and LIght:
    Series 2/3 Quarter and Light:
    Series 2 grille cut to fit on the series 1 twinky (as purchased).
    9,051
    Any interior pics?
    Geelong, Australia
    1,058
    Now that tapatalk is back online I can put up some pics of how it's sitting at the moment..
    Plan for Christmas break will be swap lowered suspension over, finish the interior off, bonnet swap, doors, grille, hatch and bumper. Then give her a cleanup and see how she looks. Also, seem to have got a puncture in the back right on the test track. So that'll need fixing (have the spare on at the moment).
    6,477
    I used to have one of these. The engine blew up and I sold it to Rowdy.
    Word to the wise.. don't use "Twink" or "Twinky" when searching for stuff on the internet. Big port twink means different things in different circles...
    CJM 4 Life yo!
    Geelong, Australia
    1,058
    Spent today shopping and wrapping presents. But managed to swap the bonnet over, fit the correct grille and also for the interior side trims and rubbers.
    Also for rid of the post gearknob back to "a" factory one.
    9,051
    Oh that looks great! Bravo sir!
    CNGAF rowdytoot's Avatar
    hotel vast horizon
    10,160
    Best 50 bucks ever spent! Still got the wheels!
    9,051
    Oh wheels? Which ones? This thing needs the proper wheels!
    hotel vast horizon
    10,160
    Not stockies, whatever 90s five spokes lobster had on it - BSA I think is the brand.
    Miss that car, was great with the 20 valve in it and only just slower at Wakefield than the mx5.
    Shiteney
    2,992
    Still have my Red S1 in the garage, hasn't been to an event since 2012, farken……
    hotel vast horizon
    10,160
    I'm going to try and do a could of days at SMSP this year.
