Page 4 of 6 FirstFirst 123456 LastLast
Results 91 to 120 of 166
Thread: Tow Rolla
  1. #91
    5,616
    Quote Originally Posted by TRD-MX62 View Post
    You are going to add a front to that tray yeah? getting squashed from two sides in an accident would suck twice as much!
    more than likely Chuck will chain the car down.
  2. #92
    \/ \/ My motivation \/ \/ ALLMTR's Avatar
    Newcastle-ish
    22,976
    It's no rocket ship up hills, that's for sure. I'm sure big climbs will be slow but don't care
    Not putting a header board on it. At the moment I have two 1000kg chains at the front and a single strap at the back V'd over the sway bar. Going to add a safety chain at the back to the chassis not the tray
    Doing the lights, reflectors and ramps at the moment
    1jz Rolla Van ....... 10.5 at 134mph
    "Reacher figured if he could put that drivetrain in some battered old sedan body, then that would be his kind of car"
  3. #93
    8,000
    Run wheel basket straps. Easier, safer and less likely to damage the car.
  4. #94
    Newcastle-ish
    22,976
    2.88t with me, tools, truck and van full of fuel and ramps , so 500kg under gvm
  5. #95
    Registered User Potsy's Avatar
    Shiteney
    2,893
    Does it require engineering for chassis extension ?
  6. #96
    16,752
    might be worth making up some wheel wedges for the front wheels (bolt on) just to make lone-loading it a bit easier.
  7. #97
    Stupid Engine Light Nacho's Avatar
    1,518
    Quote Originally Posted by Potsy View Post
    What chassis extension?
    Quote Originally Posted by lickmyleftone View Post
  8. #98
    Shiteney
    2,893
    Quote Originally Posted by Nacho View Post
    Thought as such.
  9. #99
    Newcastle-ish
    22,976
    Towed the rolla to the wsid yesterday. Just under 500km round trip. Sits on 95 like a boss. The concrete block sections of freeway suck tho and down to 70 up the two or three big hills.
    Need to get the rear brake lines done neater and vacuum bleed the brakes as I can't seem to get a one pump pedal. Also rocker cover gasket needs doing. The play in the steering also needs addressing as it takes a bit of concentration to constantly correct. Might see if I can get some new/Reco front springs as they have sagged
    First gear is ideal for Sydney traffic.
    Muffler hit on reloading the car so need to address that. Paint tray and fit the clearance lights (I did the reflectors)
    I was going to mount the ramps under the centre but seems easier (to get in/out) to just strap them to the tray between the wheelbase. Want to add a second battery, fridge, 4wd compressor and winch.
  10. #100
    Newcastle-ish
    22,976
    Added paint and clearance lights
    Was going to do the whole thing in charcoal but decided to do the sides in white as it'll be easier to see
  11. #101
    Radelaide
    4,980
    Good stuff chuck. The 4wd supacentre compressors are pretty good. Havent heard of fails and pump allot of air.
  12. #102
    16,752
    they do a kit with a small air tank and line etc to suit thats pretty cheap and reasonable in quality for the price.
  13. #103
    Newcastle-ish
    22,976
    Winch is the priority besides the maintainence items
  14. #104
    1,574
    add an E85 tank for filling up the rolla' and a small spray into the dyna on the hills
  15. #105
    Newcastle-ish
    22,976
    Yeah, trying to get another Dyna fuel tank for the other side for e85
  16. #106
    16,752
    That 'feels' like it might catch you out in a legality or on a bad day.
  17. #107
    Newcastle-ish
    22,976
    Legality?
  18. #108
    Registered User schnitzelburger's Avatar
    syd
    2,480
    being accused of something by sore losers since your fuel didnt come in a shiney labelled jerrycan
    and also on a bad day you accidentally re-fuel the van from the wrong tank
    Turbo NB MX5: more derp less carbon lightyear clone
    Supra sold it: 1983 MA61 Supra - 2JZ-GTE + 6spd
  19. #109
    Goat roper Motherfucker Jones's Avatar
    Struggletown
    6,575
    They're onto your moonshine running scheme Chuck!
    Quote Originally Posted by RVK 355 View Post
    Hold it flat cunt
  20. #110
    Chairbourn ranger! Mike Lowrrryyy's Avatar
    May 2007
    10,393
    Everyone knows you use a water truck for that.
  21. #111
    1,518
    A properly secured ADR spec fuel tank under a chassis vs all the 44 gallon drums ratchet strapped down to flatbed trays everywhere,
    I know which one I would pick.
  22. #112
    16,752
    I'd just worry that you would have some sort of dickhead try and argue that it was not an approved fuel carrying container - or not vented correctly, or some stupid shit - could also be argued that a neat jerry-rack in the same place would be more convenient.
    some events also require you to refuel in a specific place etc..
  23. #113
    16,752
    were there petrol dyna's?
    It will probably never be an issue - totally agree - just something about it feels like some cunt might take issue.
  24. #114
    Struggletown
    6,575
    If someone did I think they'd be the sort of person who made their own sheriffs badge out of cardboard and dealing with it would be no harder than telling them to fuck off
    Hold it flat cunt
  25. #115
    Newcastle-ish
    22,976
    Quote Originally Posted by schnitzelburger View Post
    That'd have to be one bad day as one tank would be set up with a fuel pump/hose to fill the rolla and the other would be plumbed up to my diesel truck. Much more likely to accidentally fill the e85 tank with diesel at a servo.
    I'd just worry that you would have some sort of dickhead try and argue that it was not an approved fuel carrying container.
    I'll keep an eye out for those badasses
    Went looking at winches today. Might try an atv winch, they're rated at 4000lbs, light, small and not too dear
    Got some tube for crush washers for the driveshaft mount and some longer tailshaft bolts so I can fit spring washers
    Also today's impulse purchase
    Brings the total up to $5,000
  26. #116
    16,752
    Aldi has 4wd winches for ~$400 at the moment.
  27. #117
    Newcastle-ish
    22,976
    Yeah, supercrap has 9500lb ones at 50% off (so $367)
    Going to try a 4500lb atv one for $170. Warn reckons you multiply vehicle weight by 1.5 which comes out at 3900lb. I'll shorten the lead to keep it close to the drum at maximum load. I've watched a few vids of people loading cars with 2500-4500lb one and think it'll be fine for the rare occasion I need it
  28. #118
    8,000
    If you run the cable through a snatchblock/pulley block you effectively half the load.
  29. #119
    Registered User 9triton's Avatar
    4,563
    Quote Originally Posted by irsa76 View Post
    and double the length of cable you pull in
  30. #120
    1,197
    I've got a 4500lb one on my trailer and it hasn't missed a beat, even when hauling dead cars out of paddocks on half flat tyres.
    Anything wider than a Datsun 1200 needs to go over the guards on my trailer so it makes the winch work.
    Ban low performance drivers not high performance cars
