Results 1 to 30 of 30
Thread: NSW: 600rwhp+ 200sx S15
    Super Moderator Morgs's Avatar
    Sydney, 2030
    2,718
    I'll preface this with I'm not really sure if I'm ready to sell this as it feels that I've only really just finished it and not had a chance to drive it. The reality is that I've have had this car for around 3 years and would have done less than 3,000km during that time.
    Don't let the subtle appearance fool you - this thing is the real deal – built with no expense spared and by the best in the business.
    Don’t underestimate the amount of money it costs to get a package to this standard – almost everything from the ground up is aftermarket in this setup. I originally purchased it from Dimi who had it for 18 odd months with the engine built and thought I’d “simply convert it to E85” but that was a long road, with a stack of receipts in excess of $30k.
    Unfortunately I spend most of my time travelling with work, and weekends are for time with a young family… leaves very little opportunity to enjoy what this was built for. What is motivating me to sell it is to see the car go to someone who is going to get the use out of it; and get it down the strip with a 9 second timeslip.
    It has performed exceptionally well on the rare occasion I’ve been able to get it to the track – a couple of Powercruise events and a Roll Racing event (latest was Dec-16).
    2001 200sx Spec-R Australian Delivered
    Genuine 77,500km on the clock – it is in amazing condition considering it has everything original from an aesthetics perspective
    Engine was built at about 73,000km – realistically it is only really just been run in!
    Shopping List:
    Head: The full tomei parts catalog
    Ported and polished
    Tomei 280 degree inlet and exhaust cams
    Tomei adjustable cam gears
    Tomei +1 over sized valves
    Tomei valve springs
    Tomei retainers
    Tomei bronze valve guides
    Tomei Solid lifter conversion
    Tomei rocker arm stoppers
    Nitto multi layer head gasket
    Arp Head stud kit
    Bottom end:
    Built by Westend performance
    balanced, lined honed, decked, squared, everything possible
    CP forged lightweight pistons
    Carillo H beam conrods
    Clevite bearings through out
    Spool 2.2L stroker crank
    Billet oil pump gears, ported and polished housing
    ARP main stud conversion
    Engine externals:
    2200cc top feed injectors
    6BOOST Exhaust manifold (NEW – only 100km old)
    Garret GT35-66R ball bearing turbo
    Turbosmart 45mm External Gate & Screamer (NEW – only 100km old)
    Custom 3" stainless exhaust
    Greddy type S BOV
    Greddy oversize oil sump
    HKS oil filter relocation and cooler kit
    Braided lines and fittings throughout the engine bay, heat shielding where required
    SX Fuel pressure regulator
    Intank fuel pump (Walbro - NEW) + Swirl Tank & 2x External 044s (NEW)
    Stealth Oil catch can
    Black Plazmaman Pro Series FMIC 3"
    3'' heat coated cooler piping
    Haltec PS1000 ECU, 4 bar map sensor
    Eboost 2 boost controller mounted in a pod on the A-pillar
    Drivetrain & Suspension:
    R33 5 Speed gearbox with modified synchro's to speed up gear changes (+ updated alignment kit)
    OS Giken twin plate clutch
    R33 diff and drive shafts, LSD rebuilt and re-shimmed very tight
    Balanced heavy duty tailshaft
    TEIN Coilovers (NEW – only 1,000km old)
    Endless 6 piston caliper brake upgrade - standard wheels still fit (NEW Pads 2,000km old)
    Slotted rotors (NEW – only 2000km old)
    Adjustable suspension arms
    Interior:
    A/C if fully functional and is ice cold
    All power windows, sunroof, mirrors work perfectly
    Leather luxury spec S15 front seats
    New Alpine head unit (Has Bluetooth if you think you can talk over the noise…)
    Wheels – Standard S15 front wheels & 300ZX rears with 255 Drag Radials
    Spare Wheels - 350Z painted satin black (tyres are low %) + Pair of S15 Wheels (tyres 80%)
    Power Figure:
    450rwkw / 600rwhp @ 34psi
    Recently re-tuned with new exhaust manifold & waste-gate… making full boost about 800rpm earlier than the indicated dyno sheet… and probably more power. Just had it on the dyno whilst on radials so not really sure what indicate peak power looks like!
    Photos:
    PM for contact details
    Please note: Insurance prohibits anyone but a listed driver behind the wheel and for my, your, and the general public's safety we'll keep it that way until money changes hands. Then you're free to roll it upside down into a pre-school.
    Find your Freedom
    Home Loans | Investment Portfolios
    www.FreedomFunding.com.au
    Click here for deal for PF Members
    C63s AMG
    Registered User peal's Avatar
    3,249
    Do want. Not a single chance of registering this in VIC.
    5,909
    does it chirp second ?
    Jan 2006
    5,806
    Sweet z32 rims bro 😎
    Peoples Champ Fatboy's Avatar
    11,379
    If it can stop this would be a fucking mental circuit car....
    Hmmmm.
    wants Sloan clone Lonx's Avatar
    2,859
    Just chiming in to say you can't fault that build mate. Nice.
    PF Gamers List
    Quote Originally Posted by klampykixx
    if a motor has big enough injectors to run say, 7psi but only just starts to max out right on rev limit, will it run more boost lower in the revs without maxing out if you lower the rev limit?
    Opens 7HEAVN's Avatar
    2,707
    Awsome car if only I had a spot free in the garage.
    Registered User MZ21's Avatar
    Sydney, NSW, Australia
    6,376
    Buy a lift. Problem solved.
    Sydney, 2030
    2,718
    Cheers guys... I'm still wondering if I should have posted this. Don't have the balls to put it up on Carsales at this point!
    Hmmmm.
    I'm really not into drag racing at all but that is what we've currently got it setup for.... but I've been thinking about that as an option as it would be a piece of piss to change... adjust the suspension & throw on circuit rims & tyres... the brakes on it are alright (6 Pot Endless calipers up front) but with a rotor designed to fit under 16s so it would benefit from a larger rotor for a track setup!
    Find your Freedom
    C63s AMG
    Registered User TurbostyleR's Avatar
    Sep 2003
    961
    Very nice car, very similar sort of power curve as my old 200SX, nothing, nothing, then tyre frying goodness.
    If you're in two minds selling it, I'd recommend throwing an ad up on carsales regardless. I had the same mixed emotions but put my old car up on carsales. Had a few interested people here and there over the next few months, and then 6 months down the track out of the blue had a CEO call me up and was keen on it as a track car for him and his kid to share. Was more than happy to let it go to him and I got the price I wanted for the car.
    A man can never step into the same river twice. Because, it's not the same river, it's not the same man.
    7,540
    Lightyear needs to buy this
    Registered User Dimi's Avatar
    Sep 2012
    1,632
    +1 Very clean car, one of the few highly modified s15s that hasn't been destroyed by hack jobs.
    Registered User Steve Whitney's Avatar
    Jul 2002
    3,484
    Sorry for the noob question, but what exactly do you mean by "listed driver"?
    Never fucked her but she did give me a blow job in my uncles swimming pool when I was 12, she got a goood mouth for sure.
    Oct 2006
    1,719
    listed on the policy
    VT, VH & C43
    Registered User Tardinator's Avatar
    Frank
    2,060
    Swap for eames dining chairs?
    7,270
    Thats about as sleeper as an S15 could get.
    Chuck likes sleepers.
    Chuck buys lots of cars.
    PM Chuck.
    Sydney, 2030
    2,718
    Cheers gents. I think I've decided to commit to sell it maybe. Or use it for promotional business purposes. Maybe.
    I'll get organised and throw it up on carsales..... (need that GIF with caption brace yourself the swedes are coming...)
    Find your Freedom
    C63s AMG
    Sydney, 2030
    2,718
    Alright I've got my eyes on another car now, so if anyone has been eyeing it off and is serious then give me a shout in the next three weeks before powercruise
    Find your Freedom
    C63s AMG
    8,859
    Oh man.
    So good. Best colour too. GLWS
    Sydney, 2030
    2,718
    Got my eye on something else so dropping the price firm.....
    If you don't have the money I can help with finance
    Find your Freedom
    C63s AMG
    Sydney, 2030
    2,718
    I will regret this... but sold
    Find your Freedom
    C63s AMG
    Registered User RNS-11Z's Avatar
    3,756
    Congrats on the sale but yeah I reckon youl regret it. These cost so much to build these days, especially to the level yours was at. My mate and I raced you at powercruie in a little datto and you pumped us hehe.
    PF Brisbane Cuntarm
    17,060
    I hear the new owner is really enjoying it!
    Registered User Rockhopper's Avatar
    west
    147
    Cliffs?
    The Crime Zone
    29,900
    Quote Originally Posted by Rockhopper View Post
    Cliffs?
    Definitely, looks like Sydney's eastern suburbs to me (but I don't know the area all that well - could be up in North The Shire).
    3,304
    Shit funniest thing Forg has ever said
    Registered User womblesti's Avatar
    May 2004
    2,030
    Is that Morgs s15? I think it’s Morgs s15!
    Registered User HSV Senator's Avatar
    1,402
    Well done to the new buyer, what a bargain! I wanted to pick this up badly but no space at all to keep it. Even tried to get mates to buy it but no interest.
    Holden Monaro CV8-R
    Lexus IS250
    8,859
    Lol
    Brian Fantana SkidFace's Avatar
    Jun 2010
    Adelaide, Marion
    2,183
    I hear the new buyer is stoked
    Quote Originally Posted by Gussy View Post
    It's the PF way. "Put a twin turbo LS in it brah, you'll have it converted and running in 2.5 hours and make an eazy 1000rwkw, lulz" All while the same people who suggest this stuff drive around in a corolla and have a fucked VN sitting in the garage for the past 3 years as a "project car."
