Results 1 to 9 of 9
Thread: Cooling issue
    The Crime Zone
    29,885
    Cooling issue
    Had a WTF yesterday, engine temp needle started slowly heading north while in traffic, but moving freely again didn't help at all. Turning the heater+fan on did, brought it down pretty quickly.
    The fact that moving didn't help with cooling made me think it isn't a fan problem; if it was a fan problem, it would be a problem with getting air through the rad & just moving would've helped (I'd expect?).
    Volvo SOHC engine; water-pump attached to bottom-hose, pushes water through engine which returns to radiator through top hose (assume this is normal for most/all engines but don't know for sure). e-Fan run off ECU which uses std engine temp sensor, but as stated above don't think this is an airflow problem.
    Pulled into a servo, looked for leaks or missing coolant; no problem. Level in overflow still OK. Didn't really know what else to look for; radiator itself felt hot, top hose felt pressurised & hot. Didn't think to feel bottom-hose. Gave the top hose a bit of a squeeze ("air bubble" I had no idea) and got a bit of a burp/bubble in the overflow tank.
    The rest of the drive it seemed to stay under control. Now being paranoid I wasn't sure, it seemed to get hot a few times but would always drop down again by itself.
    Thoughts? Pressure in the top hose means thermostat & pump must be working?
    It seems like some sort of radiator blockage, doesn't it?
    4,051
    Does the fan work?
    Is the radiator full of coolant - full overflow doesnt mean full radiator
    Pull and check the thermostat
    ACT Now!
    27,098
    Dud thermostat and/or blocked radiator.
    Jul 2009
    Inner Westside/Sydney
    1,244
    If jims suggestions are no go.
    As dnegative said, correct level in overflow doesn't mean happy system.
    Parents' magna did similar with small BHG was pushing a little bit of gas into the cooling system with similar symptoms. If it is only just starting to fail it won't blow bubbles at idle but will push gas at higher load while driving, changing the flow path to include heater breaks airlock/ lets stuff move. I was driving it at one point and just turning off the ac (and thus giving 100%cool air to rad) with the reduced coolant flow from the gas buildup was enough to pull the needle back down, likewise cycling heater. Radiator was fine.
    The Crime Zone
    29,885
    I guess then, best way forward is replace thermostat/coolant and monitor?
    If no good, pull radiator and get checked for blockage? [and if that ... farque ]
    1,934
    I'd give it a pressure test to check for any leaks then if ok bleed system a couple of times....found hairline crack in my radiator that way.
    Probably just not driven in a while then shit at brick at warm/hot weather change.
    A mate used one of those ir guns on his monaro radiator was still blocked after radiator joint 'flushed & serviced it'
    ACT Now!
    27,098
    Take the thermostat out and drop it in boiling water. This will test its operation. If it doesn't fully open then it's fucked.
    8,980
    I don't even bother testing thermostats, they're generally cheap enough on older stuff to simply replace. Same with the radiator cap. When was the last time you flushed the coolant?
    The Crime Zone
    29,885
    Yeah the coolant is more expensive than the thermostat, so given I'd be replacing the coolant regardless I might's well put a fresh thermostat in.
    And I'd probably be ordering from OS anyway, may as well get an overflow-bottle cap just in case.
    It's probably been 3-5 years (maybe 500km-1000km) since I last pulled the turbo & replaced the coolant, but I've never actively "flushed" it at all per se; what's the go there, garden hose in the top of the radiator?
    *edit*
    Ignore prior question, Mr Google has provided procedures.
