Page 5 of 5 FirstFirst 12345
Results 121 to 150 of 150
Thread: Time for a new tow car, so bought the cheapest Cayenne on carsales
  1. #121
    Newcastle
    10,404
    i don't think that's a real-world reading - i get 23 on a good day... ( with the N/A V8 mainly without using the throttle at every opportunity) but it's been down to 19
    Something very wrong there. I get mid teens around town and down to 11ís on the hwy.
  2. #122
    Newcastle
    10,404
    Quote Originally Posted by cossie55 View Post
    fixed the trailer lights with this little mod:
    Attachment 102314
    Overall impression was that it will be a very capable tow car.
    Can you give me a some more info about what you have done here? Iíve just replaced the lights on my box trailer with new LEDís.
  3. #123
    9,175
    I got 12 on the highway yesterday on a few hundred Kms, probably should adjust my driving style
    Have also done 25kms past 'distance to empty' after 0, so maybe the computer is wrong
  4. #124
    8,027
    die, cost $4000 and aren't rebuildable - my mechanic only did 2 our of all the cayennes he worked on though
    but there's plenty at the wreckers
    Depends on what has died, from a quick search it's the bearings that die, which are replaceable. If it's damaged a gear then it appears to be a bin job though. Changing the diff oil seems to help them live, dad changed the diff oil in his t-reg @160k, the recommened interval apparently, and it wasn't real healthy.
  5. #125
    Jan 2015
    1,334
    how was it after the change? was it groaning beforehand?
  6. #126
    8,027
    His was fine, changed because it was due rather than any noise.
  7. #127
    Opens AxGT's Avatar
    Brisso
    1,866
    Quote Originally Posted by Mike Lowrrryyy View Post
    Looks like a bunch of parallel load resistors (one on each trailer bulb line) to the white earth return. No resistor on the blue - that is the service brake warning line.
    Can't make out the colour code, but 8 ohms is pretty normal (to simulate a 21w light bulb load). Those resistors don't look like 20 watts though...
    Dirty Subaru owner
  8. #128
    Newcastle
    10,404
    Just wanted to follow up with a thanks fellers. Did this myself today and it works like a champ.
    Cheers.
  9. #129
    Newcastle
    10,404
    Follow up to follow up it looks like I'm getting some heat build up. Might have to take it a step further and build a better solution.
  10. #130
    9,175
    would be interesting to see what's in the box of tricks that is a few hundred bucks, i'm not that keen to cut mine open though
    Quote Originally Posted by Smidge View Post
    Would bang. Did bang. Marrying that shit.
  11. #131
    Places Unknown -Matt-'s Avatar
    Nov 2006
    Parts Unknown
    1,815
    Had one in the other day wanted to be traded in 2006 ? With 250K
    It was a manual 4.4 litre
  12. #132
    Opens AxGT's Avatar
    Brisso
    1,866
    Might be worth a bit of googling to see how much current the circuit needs to detect, so it doesnít barf.
    You could try 32 ohm resistors, they would only be sinking 5 Watts, rather that 20
    Dirty Subaru owner
  13. #133
    440
    Mine gets hot also, but I have done many hours on it now, and it works a treat, I just ignore the heat, it isn't so hot that I am yet concerned
  14. #134
    Opens AxGT's Avatar
    Brisso
    1,866
    What resistors did you use cossie?
    Dirty Subaru owner
  15. #135
    Oct 2010
    44
    Regarding towing, my 955 Turbo returns about 18l per 100 towing my tandem axle 8x5 box trailer.
  16. #136
    440
    Not sure. A friend specified the resistors and supplied them. I just built the adapter. It does work perfectly, and I seem to need it on every trailer. I can send you a full responsibility image so you can see what they are.
  17. #137
    Opens AxGT's Avatar
    Brisso
    1,866
    Sounds good - just a close up of one of the resistors is fine, so we can read the colour code
    Dirty Subaru owner
  18. #138
    440
    is this one any better?
  19. #139
    Opens AxGT's Avatar
    Brisso
    1,866
    Yep, perfect.
    They're 7 ohm 5% resistors. They'll be getting bloody hot, as they'll have to be dumping ~20 watts each of heat when they're on.
    Dirty Subaru owner
  20. #140
    4,905
    There's no way those resistors will handle 20W for very long. 1 or 2W at best.
  21. #141
    440
    I really don't know much other than I have used them for probably 10 hours or towing so far without issue, but I am willing to take advice from others on what to do instead.
  22. #142
    Opens AxGT's Avatar
    Brisso
    1,866
    If you're concerned, I'd grab a metal jiffy box from jaycar or altronics, then a bunch of these resistors
    https://au.rs-online.com/web/p/panel...stors/1074147/
    Mount the resistors to the jiffy box, and put it somewhere it will get some airflow, then rewire through that.
    Dirty Subaru owner
  23. #143
    9,034
    makes sense to just intercept the trailer connector with the special adapter. alloy jiffy box (as above) as a heatsink is a great idea
  24. #144
    Sex Pest Cock Fist's Avatar
    Launceston
    3,025
    Fuck. Shouldn't have opened this thread.
    This seems like a horrible bandwagon, but it's a bandwagon I'm considering jumping on..
    edit: ex-Porka tech mate of mine says brakes and tyres are 15k lifespan. Coolant pipes in the valley split and leak - engine out. Air bags are a ticking time bomb - literally blow up.
    2003 Toyota ST246W Caldina GT-Four N-Edition
    2001 Nissan NM35 Stagea RS Four V
    1995 Yamaha SRV250 Classic
    1980 Kawasaki KZ750E
  25. #145
    Newcastle
    10,404
    Youíre mates full of it.
    Iíve done the brakes once in the last 100,000klms and put 2 sets of tyres on in 175,000klms. Coolant pipes is intake off nothing more.
    Tyres have been Goodyear F1 SUV tyres both times.
    Edit: If your mates a Porsche tech and if he following the book 1000% there are things like cam sensors that the book tells you is intake off. If youíre not a fucking spastic you can work out the you can pull the air pumps out of the way by undoing 3 bolts (part of intake off job) and reach down to and pull the sensors out. My wife did it in under an hour.
  26. #146
    9,175
    I've never seen a real Porsche technician take the engine out to change the coolant pipes, I've seen a few cars at my mechanic with their air pumps etc off for this very job (with the engine in the car)
    I brake hard all the time and have done more than 15,000kms on brakes that were on the car when i bought it, there's still plenty left when i last had it on a hoist.
    and the air bags aren't Takata.
    like 996's there's lots of doom and gloom on the internet about these cars which is great for pushing the value down. when people find out it isn't as big a problem as the internet says we'll see what happens.
  27. #147
    Launceston
    3,025
    Air bags = suspension, not the ones that shoot sharp shit at your face in a crash.
    Fair enough on the rest of the stuff. Though he may have been exaggerating a little, as about 15 mins prior I had asked him to talk me out of this bandwagon. He very nearly did, but continued to send me links to cars of interest on carsales, so he undid any progress he had made in talking me out of it.
  28. #148
    9,175
    it was a Porsche dealership technician that snapped the harness side clips off my air flow meters - so the plugs are now taped on. They're meant to unclip and it takes 2 seconds to do it without breaking it.
  29. #149
    Registered User Astina SP's Avatar
    699
    Semi-related, I've been looking a grabbing a 2012-2015 Touareg with the 3 litre turbo diesel. Looked at a few now and they all have evidence of oil leaks, some at the front of the motor, some the back. Seems to be 'normal' to have a bit of oil around from something, but is there a deal breaker area for the oil to appear? Assuming rear main seal ones are a pain in the arse, are others just from emissions systems blow by or something?
    If anyone has a 180kw air suspension version without silly km they want to part with, let me know. A 4X motion one would be a bonus.
  30. #150
    9,175
    ewww
