Results 1 to 5 of 5
Thread: LS1 / Corvette fuel filter fittings issue
    irgendwo
    4,189
    Anyone have much experience with these?
    Im using one in my fuel system, and using adapters to convert from the GM quick connect fittings, to AN6
    Question relates to the output side of the filter - a female 3/8" GM quick connect. I've got a male 3/8" to male AN6 adapter shoved in there, but it's wiggly as fuck. You can feel an oring sealing in there, but the amount of up/down left/right toggle that's possible is a bit disconcerting. All other fittings of this type are firm and have a reassuring amount of resistance to them.
    Curious to know if this is normal, or perhaps there's supposed to be a second oring that gets pushed out easily. Or perhaps I'm just paranoid.
    Fitting to the left in the pic below
    Mit freundlichen Gre
    Jun 2009
    1,139
    I have run this set up for the past 5 years. Yep they are wiggly and feel shit but work. No leaks in mine.
    irgendwo
    4,189
    Ok... it's an uneasy feeling knowing that's the hot side of the pressure circuit, and yet has the shittiest fitting (it wobbles a good 5-10mm side to side!)
    irgendwo
    4,189
    See pic... fitting tilts in the filter a good 5mm upwards...
    sexy fingers
    Nov 2016
    Traralgon, Vic
    139
    yeah got the same filter/reg in my patrol with wiggly fittings and never had an issue.
    VF2 Redline Ute
    E36 Track Nugget Project
