Results 1 to 11 of 11
Thread: 5x120.65 - 114.3 converters
    Apr 2014
    ACT
    1,076
    bar going on ebay - can anyone suggest anywhere I might be able to get good ones? also learn me something - they seem to range between 15-25mm or thereabouts. I was told safest is 25mm cause it covers the whole nut... but then wouldnt that mean that you wouldnt be able to fit a 15mm anyway cause the nuts will stick out? lol
    5,625
    Apr 2014
    ACT
    1,076
    awesome thank you!!!!!!
    14,735
    Quote Originally Posted by LoveB View Post
    If there's cast in recesses on the back of the wheel the nuts can sit in there.
    5,400
    Just be careful with the length of the studs...
    9,991
    Don't bother with spacers, just use wobble bolts and hubcentric spacers if the Jag centre bore is smaller and run 5x120 wheels. Opens up your options so much more in wheel choice and far less likely to have any issues.
    14,735
    I don't think the wobble bolts will give you ~6mm of PCD variation - I think they're only good for half that.
    15
    Quoted for truth.
    PCD variation nuts and 5x120 PCD wheels is what you want.
    http://www.bimeccengineering.com/pcd...ts-hex-19.html
    Apr 2014
    ACT
    1,076
    but I'm putting japanese wheels on a jaguar lol
    1,318
    Give this bloke alook on the ebay, http://stores.ebay.com.au/mywadapter/
    This is the guy I got my 25mm adapters from for my Merc so I could use the Romtec wheels I picked up for it that were stupid not as old merc 44mm offset.
    He does plenty of weird PCD conversion spacers. For example 15mm thick BMW to real size.... http://www.ebay.com.au/itm/Wheel-Spa...-/152428482585
    If you meassage him I am sure he could do something for the jag to nissan. The spacers are top quality and I would highly recommend using this guy. Service was also quick, there was a stuff up with the front spacers I bought and a three day turn around from me sending them back to a new pair was awesome.
    Apr 2014
    ACT
    1,076
    Sick ill get in touch with him thank you
