Results 1 to 20 of 20
Thread: Just how bendy is an intercooler?
    Registered User Mc Juicy Hairy Balls's Avatar
    Aug 2014
    New Zealand
    612
    Hey fellas latest technical conun is intercooler install. Was planning on super thick side mounts in front of front wheels. Lack of suitable cores and really space has foiled that idea. And trying to play inside the car mod rules and trying to house over the thousand HP setup has left me with about one option. Twin 600x300x76,s out the front of reo bar, which is sacred metal that cant be molested. Coolers need to be curved to follow shape of front for asthetic reasons really i dont want the front of car to look like its busting with coolers and theyre about one inch from the front of car. Also will have coolers sloping back in at the bottom to help with depth perceptions. Pics for clarity
    Planning on making up mdf curved former to press into rear of core. So centre of core will go forward one inch. Tube and fin core. My gut tells me itll be fine
    Aug 2003
    5,955
    I remember some mob bending oil coolers into a curve shape, should be doable. start with an ebay core and leak test it?
    . crack's Avatar
    BNE
    2,443
    1 central 100mm thick a2a with a 'stepped' design won't fit?
    are the coolers in parallel or series?
    Aug 2014
    New Zealand
    612
    Quote Originally Posted by crack View Post
    Well yea possibly but when u start to think about all the plumbing required to hook that up to two turbos and two inlets it loses its appeal. The way im figuring, the turbo outlets will come into the centre under the radiator, enter the coolers in a central tank then go left and right and off and up n round to each intake
    Aug 2014
    New Zealand
    612
    Quote Originally Posted by Roadsailing View Post
    Yea bike radiators are curved and curved quite a bit. And u cant tell me theyre constructed that way and not bent post assembly
    . crack's Avatar
    BNE
    2,443
    central bottom entry? that's going to leave sweet fuck all ground clearance? what about twin symmetrical bottom entry, vertical tubes, twin symmetrical top exit (like an aftermarket 300zx radiator)? lay radiator over and run cold side pipes over it.
    Aug 2014
    New Zealand
    612
    Mmm no room for radiator lay back. 1/4 inch clearance presently. But ur right i meant twin symetrical entry. Will still leave 210mm minus 2 1/2 inch pipes under bottom rad support. Theres not a lot of room here mate shes all full up
    15,788
    Quote Originally Posted by Mc Juicy Hairy Balls View Post
    Bloke on a bike forum I'm on used to work for a bike radiator mob in the UK doing custom cores for race bikes etc - I reckon he's going to take the secret of bending cores to his grave.
    Some have suggested running them through a set of rollers to curve, but he reckons that's not the technique. Curved former, and tilting supports may be the answer though.
    1,058
    Curved press bar, curved receiver die. That's how I'd do it, plywood with gridded up reinforcing will handle the job.
    Aug 2014
    New Zealand
    612
    Yes tilting supports would be best but more work. Will do as u suggest xnke. Will report next week with something curvaceous.
    8,298
    It was A.R.E. in Brissy that were doing the curved cores. Not sure if they'd be willing to give away their secret. Always worth trying though.
    http://www.are.com.au/
    My Sports Sedan
    15,788
    "so with all this in mind, I have developed two complex ball bearing carriage assemblies that curves the cores in a jig, with an absolute minimum of stress & deformation."
    Tilting supports I reckon!
    Registered User matty12's Avatar
    Jan 2007
    Perth WA
    704
    Something similar in construction to a sheet metal roller should do it.
    Registered User lukevl's Avatar
    3,290
    This. Don't bend near the end tank join
    1,058
    How did this go? Any updates?
    Aug 2014
    New Zealand
    612
    Hey man no i havent tried this yet because its been over taken with other events. Vibrant performance have released some interesting cooler cores which i have ordered. And now i can make some 7 inch thick side mounts.
    1,058
    Just how are you planning to get cooling air through a 7" thick core? Puller fan?
    15,788
    Bummer, was keen to see how it panned out, want to bend a radiator.
    Porsche 935s and Ferrari GTOs and F40s had box cores that woud have been 7-8" thick - it must be doable.
    Aug 2014
    New Zealand
    612
    ARC or some other jap tuner did supra 6 inch thick units as well. Apparently they worked well too. 7 inch thick ones is just me stacking up two 3.5 inch cores. Its all about using what you can find. I quoted up some 10 x 14 x 6 inch thick ones from bell coolers and they came to 1300 usd each. No thanks. Im totally sure that bending a cooler or radiator would be fine depending on the radius to thickness ratio.
    Registered User SR20 KE30's Avatar
    Sep 2012
    sunshine coast
    861
    Came here to say as above ARE in Brendale does them, They are pretty pricey but their work is insane.
