Okay all, few simple questions, what are you's all doing for computer and harness ? Whats thr best way to go, std ecu or aftermarket? Also what block should i be looking for cast etc
Sent from my SM-G935F using Tapatalk
Depends on your budget.
I went with the cheap cast iron 5.3 with gen 4 rods, open up the ring gaps and add boost. Also using standard ECU and modified harness.
Personally I would go gen 4 rods and cast block
Chasing about 135mph....horsepower....fuck knows
yep can fit a 255/60/15
255 with std width ?
I don't care what you do with this...as long as you sling that 202 pronto.
Okay all, so what ls bits we got lwying around for sale
Still trying to make my mind up before i rush in and spend some coin, love the LS Turbo idea, but also like the stout n/a sbc route, any ways been cruising her around.
Well have finally made a decison, at this stage will be going ls2 N/A with TH400 & 9inch Diff. Alloy 6 L with a good cam, ported heads & valve springs + nitrous... will be looking at going 403 stroker or 408. But will set it up first with std ls2 + cam etc & nitrous. And looking at running a holley hp efi kit.
What's your budget? If it is small of 4 figures, kiss the above ideas goodbye.
Those ve 6 litres with 6l80e would be cheap conversion & seem to pull some decent numbers when you add cam & stally
Goal for this rig is to be a 10 second streeter, should run 11s aspo and into the mid to high 10s with the help of some giggle gas
Will be running the rodshop convertion kit, who is using this package. Also whats a good cam package, will look at somthing around 113/114 lobe seperation as i want to run 150 shot of gas at the Track.
Well this build is going to happen, will start looking for parts this week , goal is to have it back on the road with a ls by March. My goals are to drive it to the track & run a 11.50 & drive home N/A & high 10s with some giggle gas. Lets see how close it will go.
Just goals mate, sooner the better, just with work, christmas and going on a cruise early next year. So looking for a l98 @ the moment. Once i find a engine it will be getting the basics. New head gaskets, arp head studs, double valve springs, cam & lifters. Should the oil pump be done? & new rings & bearings. Will be looking at working out a fuel system straight away as well . So far these are my cam selction. Bottom 2
Engine, gearbox, standalone ECU, 9" and aftermarket FI for $2500 - you're either stealing the parts or telling us the conversion cost as if we were your Mrs.![]()
$2500 is the budget for the turbo alone, right?
Yep, my missus thinks it cost $5k all up, which it did... for the diff!
Yes do oil pump and double row timing chain while it's apart
Fuel system once you get it out of the tank use a Corvette reg/filter - it's cost effective and very popular for swaps, then whatever line and fittings you can squeeze into the 2500 budget![]()
Originally Posted by race6.3l
Haha im only shit stirring with the $2500, i got a good budget to allpy 9inch, th400 & engine + conversion
Drove her to work tpday, cant wait to rip the 202 out. Its great to drive but i need a few more ponies
What would you's budget on to do a ls turbo?
Just say i went a 6.0L ls2 Alloy to start with.
3k - Pro Boost 42, Wastegate & Blow Off Valve
2.2k Killa Boost Manifolds suit hq.
Fuel Rails & id1550s or 2000s (e85) 2k
What intercooler, radiator, fuel reg, etc computer
Get on YouTube and search Sloppy mechanics. Have a look at what's in his 6.0 Colorado that made 1000rwhp. It's pretty sketchy but it's a good education of what you can get away with. shows you what factory parts can take. Might help you figure out what really needs doing to do it budget.
Look at Justin's HQ. Stock manifolds with some steam pipe and a $1200 Borg Warner turbo. Guys run into the 8s on similar combos.
Thats a cute shopping list....not budget but.
Personally I would get off the LS1/2 alloy block shit.
Get yourself a cast iron 5.3 or 4.8, put a s475 borg warner on it, reveresed manifolds and a stock computer on pump 98. That should run you deep into the 10's if not a high 9.
Dont get caught up on the "must have fancy turbo, fancy manifolds must have e85 etc"
My old NA combo compared to the new boosted combo are light years apart, to the point that it turns the tires at 100mph now. Krisr on PF has ridden in both and can give you a fair assessment.
Mother fucker is on the money.....sloppy mechanics are your best point of call.
But as you asked for a $$ break down
1600 - 5.3
200 - 880cc injectors
200 - FPR1200
250 - LS9 cam
200 - manifolds
1200 - turbo
250 - fuel rails
150 - ebay intercooler
200 - ebay radiator
900 - HP tuners - tuning done by Krisr and Myself. This includes the AEM AFR meter
1000 - pumps, lines and fittings
50 - 3 bar maps sensor
if your handy on the tools its pretty easy
Where do i find one of these $1500 5.3?
Try LS iron blocks .com
Hes on face book as well, seems to import container loads of them
