Results 1 to 30 of 35
Thread: Carby issues
    canberra
    3,649
    Carby issues
    I've an annoying issue that stemmed from shut in the fuel ....I think.
    Float bowl won't keep up...drains after 30 seconds or so.
    Fuel pump is fine. New filter. Fuel lines blown out but still tested from a stand alone tank and still have this issue.
    Replaced carby and still the same problem.....ran sweet for maybe a minute before the stutter and die started.
    You can see the bowl level drop but just run the pump with the engine off and it will fill fine?
    I've put a whole can of carby cleaner thru it....can enough fine shit get past the filter to mess with the floats?
    I'm sure it's a simple fix as runs sweet for that few seconds....driving me nuts 😕
    GT8
    1UZ Celica
    1.07 flat Wakefield Park
    Registered User that_guy's Avatar
    Sep 2011
    canberra
    462
    Electric fuel pump? Is the pump only running when keys is in start position and shutting off when returned to the on position?
    canberra
    3,649
    Yup, thought it may have been the mech pump so replaced with electric wired to accessories
    GT8
    1UZ Celica
    619
    Needle sticking in the seat?
    10,741
    Can you break up your issues into bullet points a bit more. I'm struggling to understand the issue.
    Opens Babalouie's Avatar
    8,526
    Yeah the valve doohickey in the float bowl is getting stuck?
    canberra
    3,649
    Simply put the fuel bowl draws down when running until it splutters and dies. Only started after the tank was be,ted back into place so pretty sure I've dislodged A bunch of shit. Everything replaced and fuel supply is good.
    Guessing something has still found its way into the carby.
    Fuel bowl will fill fine if the car isn't running but can't keep up if it is?
    GT8
    1UZ Celica
    10,741
    Ok cool. Have you checked fuel flow into an open jar?
    Or you have a blocked needle?
    3,609
    Has this engine/carb combination worked in the past?
    Could be some sort of harmonic with the float...
    Struggletown
    6,552
    So you put a different carb on and have the same problem?
    Hold it flat cunt
    canberra
    3,649
    Yup....ran sweet for a minute or so then picked up a slight miss and within another minute splutter die and same low fuel bowl level.
    Fuel flow from pump is fine. I tried pumping from a separate container and same issue so flow from tank is not the problem.
    What gets past a filter but still clogs the fuel bowl needle?
    GT8
    1UZ Celica
    10,741
    What carby is this?
    Have you checked for vacuum leaks?
    canberra
    3,649
    What carby is this?
    Toyota two barrel downdraft on the 4M....it runs fine while the bowl is full. 99% it's fuel...lack of
    GT8
    1UZ Celica
    Struggletown
    6,552
    Is there anything you swapped between the two carbs? Like an inlet fitting that might have a gauze filter in it?
    Hold it flat cunt
    Nov 2017
    486
    Have you checked fuel pressure while itís running?
    canberra
    3,649
    Nah, it's just barbed inlet and outlets so I just plugged the hoses on....they are different sizes so they are in the right order.
    Like I said, new carby ran fine then died too......looking at the fuel it's quite brown....I'll chuck some fresh stuff in but something has passed into the carby I'm sure...well sureish
    GT8
    1UZ Celica
    16,340
    Does it have a fine screen in the banjo at the needle/seat?
    4,486
    This
    canberra
    3,649
    This
    It's fine.
    GT8
    1UZ Celica
    canberra
    3,649
    I'll have to start pulling it apart to check I guess.
    GT8
    1UZ Celica
    8,526
    Yeah check to see that the floats move freely and are vaguely in adjustment and that the float valve isnít jammed ip
    4,486
    It's fine.
    What pressure?
    canberra
    3,649
    What pressure?
    5-6psi
    GT8
    1UZ Celica
    16,340
    Once had an issue with one of those carbs on a Stout - wouldn't idle, would only run at full noise, and even then it was badly.
    Turned out the main jet had backed out and was sitting in the bottom of the bowl.
    wollongong
    1,075
    Is the tank vent blocked? A minute seems to be a bit quick for a tank vent issue but maybe worth checking.
    canberra
    3,649
    Quote Originally Posted by Mini View Post
    Had that thought and that did kind of help.....briefly...like it ran an extra 19 seconds lol....probably made the pumps job easier and helped it pump past the blockage?
    I should have some time this arvo to start pulling it to bits....hopefully I don't have to delve to deep into the damn thing
    GT8
    1UZ Celica
    Jun 2007
    750
    I had this problem with my 2000 sports, was bits of shit floating around in the tank and blocking the entry.
    cunt
    1,498
    yeah run the pump from a jar and see if its still shit
    canberra
    3,649
    Quote Originally Posted by XFJET View Post
    I did this! Posted above
    GT8
    1UZ Celica
    619
    Another suggestion - I need to think more carefully before posting
