Page 2 of 2 FirstFirst 12
Results 31 to 35 of 35
Thread: Carby issues
    18,170
    when the float sinks it opens the needle and seat, usually resulting in flooding ,
    my guess is the needle is stuck or blocked
    624
    Doh.... So much for my hypothesis. hastily deleting to hide the embarrassment
    wollongong
    1,080
    I've an annoying issue that stemmed from shut in the fuel ....I think.
    Float bowl won't keep up...drains after 30 seconds or so.
    Fuel pump is fine. New filter. Fuel lines blown out but still tested from a stand alone tank and still have this issue.
    Replaced carby and still the same problem.....ran sweet for maybe a minute before the stutter and die started.
    You can see the bowl level drop but just run the pump with the engine off and it will fill fine?
    I've put a whole can of carby cleaner thru it....can enough fine shit get past the filter to mess with the floats?
    I'm sure it's a simple fix as runs sweet for that few seconds....driving me nuts 😕
    What car is it? it could be a flexible fuel line collapsing, is there a mesh filter where the inlet line goes into the carby? mechanical or electrical pump? Shit in the needle and seat? Start from the carby and go backwards, check N&S, check float height, run the fuel container from the engine bay to eliminate issues under the bonnet then look further.
    ACT Now!
    27,279
    Needle and seat is likely. Tap the top of the carb with a spanner while its running.
    Id also consider the condenser on the coil and on the distributor. They can cause some funny problems when they fail.
    canberra
    3,651
    It has to be carb....runs beautiful with a full fuel bowl then the level drops and it starts running shyte....some blockage somewhere stopping fuel flow keeping up with engine demand but it all looks fine up until the carb. I've not had time to get back and try suggestions yet
    GT8
    1UZ Celica
    1.07 flat Wakefield Park
