Results 1 to 18 of 18
Thread: Sandown Hysterics
    Sep 2014
    Ballarat
    284
    Sandown Hysterics
    So - finally back in my car after 2 and a bit years.
    Qualified P2 and finished all 3 races in P1 so pretty chuffed.
    Surprised at how much race-fitness I'd lost .... even by the end of Sunday I was still over-braking the car and re-accelerating up to the corner.
    Props to Rob Palermo (RP Motorsport Developments) for his work redesigning the front suspension to make it Bailey-proof
    Enjoy the picsClick image for larger version.
ID:	103202Click image for larger version.
ID:	103200Click image for larger version.
    1,355
    Great Pics Robin, what class are you racing in?
    Racer 36's Avatar
    Oct 2014
    289
    Well done holding off Richard.
    Great event. Some awesome old cars.
    Sep 2014
    Ballarat
    284
    Quote Originally Posted by turbo510 View Post
    Last weekend was MG and Invited British.
    I turned 65 last week and in the 2 years I have been out of the car I have lost at least a second or more.
    I found I was over braking - or over-thinking my brake markers by 50 metres and more and whilst I carved 2 seconds out of my quali-time from Saturday morning to Sunday arvo, there is at least another 15 tenths to come because I've turned into a bloody wuss ...
    By the same token, SWMBO was pretty clear about the consequences of an enfuckeration to the car or my person so I had the "domestic driver-coach" in the back of my mind for pretty much the whole weekend.
    There are some video's floating around as well, but I was so out of race-weekend prep that I forgot my Gopro .... so none from my car unfortunately.
    8,582
    Great looking car.
    1,355
    I remember seeing you battling it out with the McDowalls (spell check) 30 odd years ago when I used to go to all the race meets with my dad.
    Was around when you first debuted the car from memory
    Sep 2014
    Ballarat
    284
    Car debuted in early 1989. Big dose of steroids and diet in 1990 and that's when is really started to get expensive !!
    Yep, raced against Neil McDowell, Andy and Junior (Simon), as well as Paul Trevethan and later Dr Mort ..... in those days there was no breathalyzer on Sunday morning so some epic sessions on Sat nite ... not any more - just as well 'cos I'm now well over the hill in that department.
    Car is completely over developed but isn't that what you do !!
    4,872
    what engine in it - with that bulge on the bonnet and user name i'm guess a V8 -but what?
    Sep 2014
    Ballarat
    284
    Rover V8 with TRS (TA Performance) heads and Jenvey downdraft injection, 14:1 on E85. Bulge on bonnet is a "mistake" - at least 75mm too high. Airbox top is 15mm above height at rear of bonnet and needs to be flat to front of air-box rather than 75mm above ....
    Have new bonnet ready to chop up and make nicer ............
    Dec 2004
    Country Vic
    1,576
    Minor traction issue, Rob?
    Sep 2014
    Ballarat
    284
    Quote Originally Posted by Lurch View Post
    Nope, rookie error ...... compression lock as consequence of too much rear bias and no more bias adjustment to move to the front. Replaced rear calipers (originals from 1992) and slight (1.5mm) increase in piston diameter exposed the rear m/cyl bore balance. Thought I could drive out of it but with more than an armful of lock I though I should just centre the steering, lock it up and give Phil a half-chance of avoiding me - which thankfully he did.
    Pretty happy with the one-day and got close to 17's .............
    Only been out twice in the last 3 years and brake balance aside, I need more seat time. The balance issue is an easy fix - I have a selection of master cyl's in the shed.
    Bigger issue was throttle jammed open on downshift to 5th at the top of the back straight ............ now that really got my attention. ECU held revs at 7500 as I threw the clutch and gave the throttle pedal a bang and it unstuck, but the flat spot was the size of my hand and thru to the kevlar belts ..... apparent the smoke haze resulted in calls to the fire brigade because of bushfire fears !!! Lucky to get out of it for the cost of a tyre .. could well have finished in the fence. ANyway the airbox will be off later tonight as that is a problem that needs to be found and fixed before I go out again.
    Anyway ...... "The older I get, the faster I was" is the quote now
    Pollitically incorrect
    Aug 2007
    7,722
    so who's going down this weekend, and who was it that had the accom down there? I might be keen for the family or a boys weekend (last minute for lyfe yo)
    Who's up for a weekend posse, or just a catch up at the usual spot?
    Dr Nick, sloth and milkman don have had their hands up, what about you Lincoln?
    Biscan ya Sydney fag?????
    Dr Hoon
    Aug 2007
    7,722
    never mind me, came looking for PI hysterics, and read it as such....
    Dr Hoon
    Mar 2009
    Bendigo, Vic
    1,703
    Quote Originally Posted by nastysven View Post
    Thread title is confusing.
    Mmmmmmmmm beer.
    Sep 2014
    Ballarat
    284
    Thread was originally from Sandown Historics last year and Lurch is giving me heaps from Vic State Series at Sandown last weekend.
    You want this post ........
    http://www.performanceforums.com/for...h-anyone-going
    8,582
    How did you like the Hankooks?
    Sep 2014
    Ballarat
    284
    Still wringing the last of the life out of the Dunlops ........ will probaly have them on for PI in early May, so cannot give you any feedback yet
    9,031
    Such a cool car mate, glad you didn't have worse damage!
