Results 1 to 11 of 11
Thread: New Mig Welder
    May 2016
    Maitland
    72
    New Mig Welder
    Hey all,
    I need a mig welder, have been using a old 200amp Lincoln and that was suitable. will be just doing a little basic fab in a home shed.
    I had a look at the Lincoln 255c but its out of my price range, any feedback on Unimig
    Sydney tools have this for reasonable $$ https://sydneytools.com.au/uni-mig-k...a-tig-inverter
    Any other recommendations in the $1500 price range
    6,154
    I'd be looking at stretchign that to buy a proper TIG or buying a cheaper MIG.
    maybe this one, haven't used it but that's more like the price range i'd be lookign at, the one you linked looks massive too.
    https://sydneytools.com.au/cigweld-w...nverter-welder
    Jan 2016
    NSW
    300,103
    Was going to suggest a BOC one with remote wirefeeder as it was on their website for ~$1000 inc. GST. Must have been taken off in the last couple of days though as it is no longer there. This is the newer version without the remote wirefeeder - https://www.boc.com.au/shop/en/au/bo...dvanceii250c-p
    441
    Lincoln Speedtec 200C ?
    Have had one for a couple of years now, replaced a 180C, used a fair bit for aluminium MIG as well as steel.
    Overall pretty happy with it for what it is.
    Radical SR3
    HSV R8
    5,505
    Love both my unimig 180 (old transformer mig) and my 200acdc unimig tig.
    I would go the new 250a inverter mig https://sydneytools.com.au/uni-mig-k...nverter-welder from unimig, think its around $1100. I would like to get a new Lincoln with the pre programmed settings etc mostly from all the yank youtube welding vids I watch, but i cant really justify the coin.
    Main thing is go inverter mig, just lighter and easier to set up. Id stay away from BOC, WIA and CIG. Just from online info they dont seem that great compared to what you'd expect from the names and price.
    Daily: Honda Civic EK1 Hatch
    Jun 2009
    1,155
    I have the lincoln 180C and its been awesome for years. If I had to replace I would look at lincoln again or unimig
    12,899
    Im happy with my cigweld weldskill 250.
    Its basic an solid. Can take full size wire reels, can be upgraded to a remote wire feeder, has euro torch plug etc. Can get them for under $1k when on special.
    Downside is the factory torch is crap, and there is no fine amp adjustment. No a problem unless your doing sheety stuff though.
    6,361
    When I set-up the factory out here I brought 2 unimigs and 2 cigwelds both 250amp.
    11 years on the cigwelds are long dead but both unimigs are still going strong.
    May 2016
    Maitland
    72
    thanks for the feedback, sounds like Unimig or Lincoln will fit the bill, what the go with the small ones ? they are just inverter based and can only run 5kg wire reels
    Jun 2009
    1,155
    I run 5kg spools in my lincoln all the time
    441
    Quote Originally Posted by stocko View Post
    snip.... what the go with the small ones ? they are just inverter based and can only run 5kg wire reels
    Yes, most of the non commercial ones run 5kg reels.
    ps. That Lincoln is a full synergic welder, so you just dial in material and thickness, thickness of wire and go for it. In my
    experience the settings for mild steel are a touch on the cold side so I wind up the volts normally by around .5 which suits
    my style better. YMMV Also is fully manual if you prefer, and can save your own settings in memory as well.
    Radical SR3
    HSV R8
