Results 1 to 2 of 2
Thread: Speed Density vs MAF
    Owns a Ferrari BeverlyHillsCop's Avatar
    Aug 2006
    Garage
    4,794
    Can anyone explain the pros/cons of Speed Density over MAF and vice versa, and what their experiences are?
    Thanks in advance
    /csh Racing
    Jul 2009
    Inner Westside/Sydney
    1,354
    MAF is more likely to work well on a packaged tune. It is more accurate and will compensate for some changing conditions better than MAP only tune. MAP with exhaust back pressure is more robust than intake only.
    OEMs use it for a reason but packaging constraints and big cams/ports can cause reversion issues on MAF systems.
    It is really about compromise which is application specific, you can get MAF sensors now that present very little restriction and up to massive flow with good turn down due to non linear scaling.
