Results 1 to 12 of 12
Thread: Best tyres for "happy laps" or roll racing at QR
    i want more power goracing's Avatar
    Jul 2007
    brisvegas
    560
    As the title suggests, I have having trouble with traction at Qr for these social events. On the strip I have so much grip but out there it just tears the tyre. I went from a ET street 16/255/45 to a 15/275/50 and while i think it was better initially, once the tyre starts to tear (will post photo Soon) its just shit from then on.
    I have tried low pressures but makes stuff all difference. My suspension is set to soft and does squat.
    Does being to soft in the suspension makes the tyre work to hard?
    Is the compound to soft and need a real good genuine Street tyre?
    Wanna sort this before me first crack at roll racing.
    Car spec - is manual with a little bit of HP and once into 4th will get grip by the end of that gear
    1,194
    Have you tried MT both types in 15"?
    I'd recommend anything from Hoosier instead.
ID:	103467   Click image for larger version.
    BMW M140i daily.
    Honda Odyssey.
    FG XR6T ZF - Road registered 410rwkw Circuit car.
    Wakefield 1.07.386 (Street Tyres 1.08.8) Marulan Short 43.4 SMP GP 1.48.1 Winton 1.35.4
    Registered User Dexi's Avatar
    Bris
    1,228
    Turn the boost down, hth.
    3,163
    Tried feeding the pedal and not trying to put your foot through the firewall? Stage boost in gears?
    9,010
    Will. Nto1s were pretty good on mine with similar power to yours but I'm way more stiff in the rear end. What are you using?
    Mar 2011
    649
    Quote Originally Posted by goracing View Post
    There is your 1st problem, drag radials (not pro et type) are designed to work at pressures closer to their road going cousins rather than at low cold pressure.
    Mickey Thompson have actually said that either the Pro Bracket radial or the Bias Ply ET Street R would be the best tyre for the "no prep"/roll racing style of events, but unfortunately I believe that they may be banned by Roll Racing.
    16,299
    The problem with having an IRS car soft in the rear is that the squat will induce a bunch of negative camber and it'll trash the inside edge of the tyres. Koeingsegg have treated this by adding a 3rd spring/damper that on works in squat, allowing them to maintain a roll-stiffness that works for going around corners...
    Struggletown
    6,552
    I don't think it's a tyre problem, sounds more like a suspension problem. I'm no expert but you basically want to force the tyre into the ground with leverage and the weight of the car. If your suspension is soft it's probably letting the tyre flop around and unloading it on gearchanges, letting it spin and tear.
    How much power/what's it weigh?
    Hold it flat cunt
    9,010
    It's about 750ish rwhp in a JZa80 from memory
    Jul 2007
    brisvegas
    560
    Wicked, I have some responses.
    Update, I went for another go with the suspension set alot stiffer and well it went way better. Can get through 3rd gear pulls now. I reckon with better tyres (these are out of grooves) It may pull 2nd.
    Pressures @around 20psi - suspension at around 3/4 stiff is way better. Might even try harder now.
    Jul 2007
    brisvegas
    560
    Quote Originally Posted by Dexi View Post
    We are about to turn it up now lol
    Jul 2007
    brisvegas
    560
    correct
