Page 2 of 2 FirstFirst 12
Results 31 to 35 of 35
Thread: Radiator Recovery/Expansion Tank - Need Info
    Nov 2017
    232
    I know they can vent, what im saying is they really arent designed to vent.
    Firstly "I'm" and "aren't".
    That is incorrect expansion tank systems are designed to vent. Expansion tank systems can have a higher vent pressure but this is entirely for the purpose of mitigating evaporation which is a pain in the arse in expansion tank systems.
    At work :(
    17,966
    (TM - AVENGE)
    FJ20DEBT NISMOgemini's Avatar
    Brisbane, QLD AKA: Gene FJ20DET
    3,900
    Quote Originally Posted by NISMOgemini View Post
    the pic above is exactly the same as my last vehicle. except the radiator cap was on the tank and no cap in the radiator at all.
    so i want to do it like this? (attachment) is the pindick hose from under the cap large enough to move enough fluid back and forth?
    i think this with a recovery cap on teh Rad and overflow to ground on the tank will be the easiest option
    3,900
    So is there a pro and con between the 2 recovery vs expansion? or they basically do the same?
    This is what i have (see pics) so i can ditch the filler that i currently have if need be as its not on the radiator, im just begin lazy. Probably put a blanking cap as it give me options. i also have my water temp sensor in this filler (on the underside)
    and i can jack into the lower coolant line via the aluminium joiner with a 1/2 JIC weld on..
ID:	103463   Click image for larger version.
    Perth WA
    699
    Header tanks or "expansion tanks" are higher than the system with bleeds back to it and generally has a air pocket in it which is good for engine or rad designs that require it. You can also have a header tank with a overflow in it as in pic 2 which wont have any air in the pressuised side but will act like a standard overflow system but with added benefit of keepingnair out of thw pressure side . These are factory oom setups but arent very common
