Results 1 to 11 of 11
Thread: Trailer brake controller and dual battery set up, advice.
    9,644
    Right, currently going through the motions of ordering a new family hauler and have decided I should get a trailer brake controller on it since nopics keeps talking about camper trailers/caravans etc. Any recommendations on brands/models? Prefer one that can be mounted out of the way, have no issues with mounting control heads on dash, this thing is likely to be drilled all over the place anyway.
    And secondly, I want to get a second battery for it, I would go for the factory dual battery but that's a special order build with is too long. Any recommendations on what isolator/charger to use? I'll be shoving the biggest battery I can under the seat, will wait till I have the car before I figure out the size, maybe even Li if they aren't stupidly expensive for my application so I'd need abit of flexability there. Will also add an invertor as well. Vehicle will be a VW Multivan which apparently uses a smart alternator.
    Cheers carnts.
    Toowoomba
    1,253
    I have the Tekonsha P3 and the manual override within quick reach has saved my arse more than once.
    1,872
    I got a redarc tow pro elite, have not used it yet but I went for it due to the lack of 1970's spec controller to bash your knees on.
    Sonova Beach
    6,503
    It's going to be a massive cunt to wire all of that up, and have everything working correctly, without upsetting the factory electrics.
    There's no brake light switch on the pedal to get a signal from, for the trailer brake module. All the lights run off PWM. Closest you can get, is to tap into the hall sensor on the master cylinder, as it's a proper 12V signal straight to the BCM, which converts it to a PWM output.
    Dual battery and invertor should be straight forward, as long as you leave the van's wiring alone, and run everything seperate as much as possible. You can even buy all the brackets, etc to mount it under the passenger's seat, as per OEM. The UK forums should be across all of this by now, and will have info on what to use and how to hook it all up. Good camper fit-outs run completely seperate wiring looms, that only interface with the car's original electrics where absolutely necessary.
    9,644
    Yeah, found a bloke in the UK who does camper wiring so that bit shouldn't be overly hard, once I figure out what isolator I need. Looks like I'll be talk redarc.
    10,800
    Ive seen a couple of newer installs that use an old style clutch/brake switch mounted to the pedal box for the trailer brake controller. Save tapping into anything.
    Tekonsha P3 ftw too, has saved me a couple of times with sudden crosswind wobbles.
    The new nugget
    Sep 2010
    Adelaide, SA
    1,480
    Another vote for Redarc TowPro. Great unit to use, simple install and neat switch / dial.
    For dual battery wiring talk to Tim at Traxide. http://www.traxide.com.au/ Knows his stuff when it comes to complex late model Euro stuff (he does great kits for Land Rovers).
    Sonova Beach
    6,503
    You know what, there's a very good possibility the pedal assembly carries over from the previous model on these (it is only a facelift of a faceift of a van that was released in 2004), so chances are the brake pedal switch off the earlier ones will fit and be useful.
    9,644
    Dealer is getting a Redarc tow-pro elite fitted for me, the battery can wait for the time being. Although not sure how long I'll be able to wait, there's going to be a fair few extra electrical stuff added to this thing.
    Nov 2017
    486
    I though that the rear lights were 12v and 6v not PWM. Either way you can get the signal off the trailer harness ecu.
    Sonova Beach
    6,503
    It's all PWM now. Trailer input and output for brake lights is also PWM, which will fuck up if you've pissed money away on LED lamps for your box trailer.
