Page 3 of 3 FirstFirst 123
Results 61 to 87 of 87
Thread: LS1 - Heavy Surging (Undriveable)
    6,715
    They would have an open center diff i reckon? Therefore garage should survive.
    Jan 2011
    248
    Lock up converter locked up at all speeds then? at idle its going to stall everytime
    Melb
    832
    OK so I found out my old man has what I would consider to be a better scan tool, which he has had all along :/
    It looks as though the long term (and short term) fuel trims are up the creek.
    Am I reading this correctly in thinking that the ECU is commanding a whole heap more fuel into the system but it's just not being delivered?
    Cub35 - to clarify, I can only get this about 2 houses down the street at about 5kmh before it stalls and dies. Can't check convertor issues I'm afraid.
    windsor nsw
    1,159
    Check fuel pressure, should be 58ish psi. Check map sensor. Unplug maf
    Melb
    832
    Quote Originally Posted by bpm View Post
    Cheers!
    Have done the unplug MAF trick before without success but I'll do it again with the scanner attached and see what happens.
    Is there an easy way to check the fuel pressure using the Schrader valve on the rail? (I.e. get a bike pump style attachment and ghetto up the gauge?)
    MAP reading of 44kPa at idle seems OK?
    Melb
    832
    OK so a quick test there showed Short term trim on bank 1 was sitting around 7% on idle, unplugged the MAF and it jumped to about 12%, pretty static. Give it some throttle and it climbs to the high teens.
    O2 reading on bank one would show ~0.6-0.78, then show one reading dropped to 0.10, then back up again.
    Next stop - parts shop to see if I can get what I need to check fuel pressure & wait for injectors to show up....
    5,399
    High fuel trims are often associated with vacuum leaks on vehicles with MAF sensors.
    But 13.6 g/s MAF rate at idle is pretty high so the increased trims is probably because of other reasons, like a fuel supply issue.
    As suggested I'd check fuel pressure.
    4,231
    You don't need a special fitting for the fuel rail. Just screw the valve out and shove a hose over the top. That's what I do and I'm a "professional".
    882
    Go through around the fuel injector seals in the manifold and carefully clean around the lower injector seals. I've seen these leak air before, but never really bad enough to max out a fuel trim. Was one of those "well that's nice to find now" discoveries.
    Also check the back of the intake to see if there are any leaks/cracks/hoses loose?
    Check the O2 sensor connectors for corrosion or chafed wires, too. I have found lots of these corroded up or chafed through against frame rails on 4wd types that do the "good reading-bad reading-good reading" thing.
    Melb
    832
    Great tips guys - really appreciate the help!
    I did a bit of an intake health check a week or tow back, looking for cracks in hoses, leaks etc. Might check again with fresh eyes.
    Safety Dance - Not sure what you mean by 'screw the valve out'- on mine its a valve equivalent to that of the tyre, though somewhat different dimensionally. I might be missing something obvious here (this is why I stick with 304's!).
    Melbourne, S.E. suburbs
    1,437
    You can unscrew the actual valve bit out using a special screw driver jigger, just the same as a tyre.
    Registered User Milkman Don's Avatar
    2,622
    Another hose to check, the PCV hose under the throttle body is always 60% of the time every time fallen to pieces.
    7,116
    Your o2 sensors are heating up at different rates.
    Melb
    832
    Happy New Years gents!
    I was going to type out a diatribe but ill cliff note it.
    New injectors didn't fix the problem, but did allow me to drive around the block (very poorly) where I couldn't before.
    Fuel trim behaviour changed slightly.
    Hooked up a fuel pressure gauge (finally!), priming on key on and it only gets to 15psi or so then falls away. Starts after a few cranks, running pressure is 25psi. That ain't right.
    Another complete fuel pump and regulator assembly on its way.
    What a saga...
    5,399
    Well yeah, that'd do it...
    I'm not familar with these models, does the fuel pressure regulator also take care of the check valve function?
    I mean there isn't a separate check valve in the line in addition to the regulator?
    In some vehicles there is a check valve in the fuel line which stops the rail pressure falling away when the pump is not running.
    7,116
    The reg is in the fuel pump pickup pot
    Bet E10 has fucked it all up. Probably throw a new fuel filter why you are at it.
    Least it will have all new things
    Syd-en-ey
    424
    Surely it's going to be easier to just remove the check valve temporarily and see if it makes a difference?
    It's either not enough voltage at the pump (extremely easy to check) or not enough current (also very easy to check) or a blockage in the line... Maybe a crushed fuel line? Or a completely blocked fuel filter?? Fuel reg could have failed and preventing pressure from building up?
    7,116
    New fuel pump assembly isnt expensive and just matter of dropping tank and swapping over.
    Syd-en-ey
    424
    They way he said "another" I thought he meant he'd already replaced the whole thing, but maybe he's just replaced the pump only per the original post...
    Melb
    832
    Bingo - only replaced pump w a Wally 255 I had on hand. New filter also.
    I'm going with a leak from the in tank equipment.
    Melb
    832
    I finally fixed it!!
    Complete fuel pump/reg/sender assembly and it holds pressure beautifully. Drives great!
    Thanks a ton for the advice guys, really appreciate the support.
    2,622
    Nice result mate, AWD skids in the rain today!!
    Truth told they actually drove really well compared to a standard wagoon, another case of too late to the party from Aus motor industry.
    ACT Now!
    26,758
    And badly marketed. Holden tried to sell it as the ultimate ski wagon (0.0001% of the population skis) and the motoring press tried to test it like it was a Nissan patrol contender. The average punter didn’t know what it was for until Subaru started selling outback’s.
    2,622
    Agree 100%. Iirc motor or wheels took them off-road and got them bogged everywhere, sooked about ground clearance and wrong tires.
    Nov 2017
    238
    Meh the AU wagon is a far superior vehicle to the outback or adventurer.
    Melb
    832
    I went an did some soft-roading on Sunday after all the rain. LS on limiter, mud spraying everywhere. Yeah, not the worst!
    7,116
    Woah.
