Results 1 to 30 of 49
Thread: McLaren Senna - New McLaren ultimate series car
    Registered User Smudge's Avatar
    Apr 2014
    City
    626
    https://www.pistonheads.com/news/ph-...revealed/37227
    The latest Ultimate Series car has arrived, and it bears the name of McLaren's greatest ever driver
    Before finally pulling back the curtain to reveal the latest member of its Ultimate Series to the assembled motoring press, McLaren went on at some length about the most extreme road car it has ever made. Partly because it is justly proud of the remarkable machine that has resulted from a wholly single-minded pursuit of circuit prowess. And partly, one suspects, to ensure that the ground was sufficiently soft before anyone actually laid eyes on the car.
    The firm makes no apologies for the way the Senna (yes, we'll get to that in a minute) looks. Laudably, no-one wearing a McLaren logo suggested it was anything other than 'brutal' - and this description, having likely rolled around Woking for quite some time, is entirely apt. You hardly need me to tell you that its maker considers the car the epitomy of its form-follows-function design philosophy or that practically every surface has been optimised for better aerodynamic performance. That much is obvious.
    What you will need me to tell you is that the car has a tremendous and savage presence in the metal. And that it is quite beautifully made. Walking around the car with Andy Palmer, the Vehicle Line Director for Ultimate Series, is a treat because there is plainly so much going on. From the two-piece windows to the carbon fibre plenum, which can be seen working in the rearview mirror, to the visible door gas struts, it is certainly one of those machines which rewards close inspection - if not a long gaze from 15m away. The fact that no single line goes from front to back without swooping into a vent or intake speaks volumes about the styling sacrifices made at the altar of airflow.
    So what do we know? Well, as promised, this is McLaren's road-legal track monster. Or as Woking puts it: "legalised for road use but not sanitised to suit it." Which is another way of saying that the Senna is going to ride like a 720S or even a P1, but will be quicker around almost every circuit than a P1. It'll do that because the firm has combined its air fettling body with a 1198kg dry kerb weight - and 800hp from an overhauled version of the familiar 4.0-litre twin-turbocharged V8.
    This translates into a power-to-weight ratio of 668hp-per-tonne. And when you've finished staring at that figure, consider that the Senna also develops 590lb ft of torque. All of it dispatched via a dual-shift seven-speed transmission to the rear wheels. There are no hybrid gubbins as there were in the P1 - they were plainly considered too weighty - and while McLaren isn't prepared to discuss performance figures just yet, it has gone into some detail about how the Senna turns all this mechanical energy into potentially outrageous lap times.
    Underneath, the car is built on an evolution of the carbon fibre Monocage III architecture which underpins the 720S. Its development occurs in the upper portion and is significant enough for Woking to describe the latest monocoque as the 'strongest' ever built for a road-legal McLaren. As a result, the interior luggage-carrying space in the Senna is reduced to just enough room for two helmets and a race suit (we'll call that, 'the essentials').
    The RaceActive Chassis Control II suspension system is also a development of the firm's existing technology, utilising double wishbones all around and the hydraulically interconnected dampers which replace the need for conventional anti-roll bars. While the chassis retains its Comfort, Sport and Track settings, the Senna adds Race mode (engaged by an overhead switch rather than on the Active panel) which drops the car's ride height by 50mm. No prizes for guessing which setting is employed in the pictures.
    Clearly 50mm is a lot for an already low-to-the-ground supercar (even Palmer admits that you'd think twice before deploying it on the notoriously unflat Nordschleife) but then it's meant for the bowling green surfaces of race circuits rather than your local B road. There it will fully indulge the ground-breaking front and rear active aero; from the two aero blades now hidden either side of the nose to the colossal double-element carbon fibre rear wing - all of which constantly adjust to optimise the available downforce and aerodynamic balance.
    That's not all. At the back there are 'gurney' flaps ahead of the clamshell's stepped louvres to direct air away from the rear deck and down the side of the car. This leaves an area of low pressure which helps to draw out the heat coming from the radiators and engine bay. Like all McLarens, the exhaust exits the body via the most direct route, but is angled to direct gases away from the rear wing. The vast double diffuser below is created from a single piece of carbon fibre. That glass in the lower portion of the door is there so you can be in no doubt about whether or not you clipped the nearest apex.
    In short, it's all about attention to detail. The cockpit is similarly business-like. Stripped out even by McLaren's spartan standards, there's carbon fibre on display everywhere - and while Woking has opted to retain niceties like the infotainment display and a stereo, it has endeavoured to keep clutter to an absolute minimum. The glorious seats (available in two sizes) are only cushioned precisely where they need to be, and can be gently tailored to best fit their new owner.
    There will only be 500 of them, and according to McLaren, spaces on the limited production run were all allocated some time ago. Each lucky soul will have agreed to meet a starting price of £750,000 - without having actually seen the Senna. As far as McLaren is concerned, using that name could not be more appropriate. "You commit yourself to such a level where there is no compromise. You give everything you have; everything, absolutely everything," is the well-selected Ayrton quote emblazoned on page 1 of the car's press release.
    The car which bears his name is obviously McLaren's tribute to that sentiment. Or at least it will be until Woking gets around to a building a non-road legal GTR version, an option apparently being discussed behind closed doors. Palmer reckons such a development would strip an additional 50-80kg of non-essential kit from the Senna; making it impossible to drive down the public highway - a key criteria for membership to the Ultimate Series - but quicker still at the business of setting lap records. That's a prospect for tomorrow though: today, the Senna is as extreme as McLaren gets.
    He jerked off with the determination of someone within sight of Everestís summit, having lost all his friends and Sherpas, having run out of supplemental oxygen, but preferring death to failure.
    TJzone TJ's Avatar
    25,921
    So good.
    #teamtremolo
    And i'd still fuck Betty....
    Super Moderator Morgs's Avatar
    Sydney, 2030
    3,078
    Love it. However, the way McLaren are going it'll be 6 months before this is made completely redundant by the next iteration!
    Find your Freedom
    Home Loans | Car Loans | Investment Portfolios | Property Management
    www.FreedomFunding.com.au
    www.ProgressiveProperty.com.au
    Click for PF Loans
    Click for PF Property Management
    and then! maddy's Avatar
    Dec 2004
    honkers bonkers
    2,130
    Definitely the preferred angle and what most will see
    4,397
    Looks good, would bang, 10/10
    At work :(
    18,527
    Wonder how much they're paying Senna's estate to licence his name?
    (TM - AVENGE)
    16,733
    From memory with the Ducati and MV Sennas, it's a payment to the Senna foundation (A charity for underprivileged kids in Brazil)
    15,070
    That's got to be just about the ugliest supercar on sale atm.
    Quote Originally Posted by XXX19X View Post
    2,053
    I think itís bloody hideous. But the performance will surely make up for it.
    Registered User FLI355's Avatar
    3,546
    Fugly as can be. Surely goes like crazy.
    CAD Automotive Paint Correction
    Registered Cunt
    Nov 2004
    435
    Holy front overhang Batman
    Registered User evo-gsr's Avatar
    Aug 2013
    Here and There
    939
    Weapon.....Uncle's already ordered his?
    6,027
    Rear arches are all kinds of fucked too, ghey offset wheels. How you go from the p1 to this i don't know.
    If in doubt power out
    Wait what? sirhsv's Avatar
    Brizvegas
    6,285
    I think itís bullshit that theyíve put the Senna name on this. It should be on a no compromise track car as befitting the Senna name
    The royal penis is clean tremolo's Avatar
    Jul 1979
    Zamunda
    5,009
    What goes here? 23Kev's Avatar
    4,024
    Quote Originally Posted by sirhsv View Post
    Maybe it is. All we know right now is that its a bit ugly and it will be fast. From what McLaren are saying its a track focussed car... which they've never said about any of their previous cars...
    I survived the patio flooding catastrophe of 2012.
    yeah, that would be great Matty's Avatar
    1,694
    Cue footage of Jeremy Clarkson struggling to get his fat arse in, followed by scraping the splitter over a tiny speedhump.
    Quote Originally Posted by PJ OíRourke
    Name me, if you can, a better feeling than the one you get when you're half a bottle of Chivas in the bag with a gram of coke up your nose and a teenage lovely pulling off her tube top in the next seat over while you're going a hundred miles an hour down a suburban side street.
    Registered User Gats's Avatar
    7,608
    Pretty much a road legal Aston Martin Vulcan.
    AKA another retardedly expensive "track" car that will never get driven to it's full potential.
    Registered User MZ21's Avatar
    Sydney, NSW, Australia
    6,739
    P1 owners will be pissed.
    15,070
    Quote Originally Posted by Gats View Post
    All sold out though. And I'm pretty sure this is the common theme with all/most of their recent offerings (e.g 675LT). McLaren are on point as far as knowing what their customers want these past few years.
    Sydney, 2030
    3,078
    Quote Originally Posted by Shitbreak View Post
    Agree on point with knowing what customers want, but not with looking after customers resale values. Every time a new model comes out it is a significant shift rendering the prior iteration useless... if you can feel empathy for first world problems think about the poor MP4 owners!
    Find your Freedom
    Click for PF Loans
    6,739
    I look forward to buying a <50K mp4-12c
    Aug 2013
    gawler
    2,092
    Bah Bollocks! since when was glass lighter than carbon fibre?
    15,070
    Quote Originally Posted by Morgs View Post
    Is it though? I was under the impression that McLaren are managing this by producing the different models we've had so far in limited numbers. The older cars are taking a hit, but by not all that much (AFAIK).
    EDIT: I could well be wrong. Although the 12c is the very first model and also the base model, so perhaps it was to be expected.
    16,733
    Is it just me, or are the McLarens getting uglier and uglier?
    6,027
    Unfortunately the cheapest MP4-12c is still $289k in Aus.
    1,624
    Nope. The new 720 hasn't grown yet me yet and this thing seems to be function over form driven by the wind tunnel.
    16,733
    I have to say, even if I could afford the above McLaren, I'd probably rather buy the new Glickenhaus 3 seater (which is a $400,000 USD car.)
    on hoes? yohoes's Avatar
    3,354
    Quote Originally Posted by MZ21 View Post
    Would they be?
    P1 is literally the best looking modern supercar by a longshot.. versus this weird looking fucker
    6,739
    La Ferrari by a long shot for looks. Honest don't see McLarens as pretty cars. Functional yes, not hideous, but not Ferrari, Lambo or Porsche 918, Carrera GT good looking.
