Page 1 of 3 123 LastLast
Results 1 to 30 of 69
Thread: my Jeep has a drinking problem
    I <3 Mang. klampykixx's Avatar
    Mar 2011
    Coffs Harbour
    801
    so my Jeep uses a ton of fuel.
    been chasing it since I owned it.
    at first I thought my cracked header was making a false lean and therefore rich condition.
    welded it up and no change.
    figured maybe dead o2.
    swapped it out and now it's worse (56028233AA)
    was getting a consistent 20l per 100km but now it's up around 22 and even 25 per hundred km.
    I've got Holden commodore four hole injectors in( Bosch injectors 0280 155 777.) but there 19lb injectors so are slightly smaller to stock. initially they used less fuel but it's increased as of late.
    My battery is starting to die so I'm wondering if a lack of pressure would make the injectors dribble rather than spray and therefore use more fuel?
    Or. is there something else I should be looking for?
    just doing my head in. using half a tank of fuel to do 135km atm.
    Mar 2011
    Coffs Harbour
    801
    I'd be happy to get it down to 15/100
    Registered User Rockhopper's Avatar
    west
    156
    What year/model jeep?
    Any mods?
    9,429
    The next thing Id swap would be the coolant temp sensor
    5,496
    Tried giving it a service? Check that its getting hot (thermostat not stuck open), new plugs, timing, oil, filters etc.
    Daily: Honda Civic EK1 Hatch
    12,564
    Cut out the dash and put an ecotec in.
    Mar 2011
    Coffs Harbour
    801
    Quote Originally Posted by Rockhopper View Post
    Any mods?
    yep. 96 xj cherokee. lifted 4.5inch and 31inch tires. regeared to 3.7 diesel ratios. 2.5 header to cat exhaust and 3inch cat back.
    barra swap maybe and then build a sailing boat because y'know, barra....
    yep done all those things when the crank sensor shat itself. new leads dizzy cap, coil, plugs, also done thermostat a few weeks before, coolant flush etc.
    it's actually really good and reliable, it's just really thirsty.
    that's actually already next on my list.
    3,196
    This was going to be my recomendation.
    Look at the yank forums, there are literally centuries worth of info on all these things. And if that fails #barrathething
    Mar 2011
    Coffs Harbour
    801
    cool, yeh most of the forums I've read focused on the exhaust because they split and crack.
    12,894
    They barely got 15l/100 from the factory. With big tyres, gears and accessories, you arent going to get close.
    Mar 2011
    Coffs Harbour
    801
    so is there mods I can do that make an engine more fuel efficient? rather than just aiming for power
    3,196
    turbo will help, but then if going to that trouble a falcon 6 would probably be a better option
    6,349
    16,334
    It's a Jeep thing.
    9,452
    this is too good to go unnoticed
    . crack's Avatar
    BNE
    2,454
    Quote Originally Posted by klampykixx View Post
    No it wasn't. How about actually thanking the guy?
    I'm Johnny Hotfuck Greasystick's Avatar
    Jan 2011
    St Kilda VIC
    507
    US EPA rates them at 14mpg city cycle - so 16.8l/100km
    https://www.fueleconomy.gov/feg/bymo...Cherokee.shtml
    And that will be driving them like an utter grannny. Doubt you'll be so light footed.
    Mar 2011
    Coffs Harbour
    801
    seriously, I had just bought a new temp sensor.
    thanks for confirming my next move.
    Mar 2011
    Coffs Harbour
    801
    Quote Originally Posted by Greasystick View Post
    I'd be stoked to get it there. I give it a squirt every so often but I tend to drive it pretty casually more often than not.
    Desert Nigga vet 180's Avatar
    Dubai
    3,247
    You never will with 4 inch lift and 31s. Best you could hope for is low 20s
    Is the car auto or manual?
    Nov 2017
    486
    12,894
    All I6 XJs in Australia were autos.
    Best thing you can do is fuck it off. XJs were heaps of shit when new, and, things only went downhill from there.
    16,334
    Guys, I don't think the Jeep actually exists - he says it's reliable.
    Jan 2011
    St Kilda VIC
    507
    Plus with the option of driving an XJ or a moo powered Mazda van with epic quantities of performance and luxury, you'd never take the Jeep
    Skrrraaaarrrrrk Chase Rockwell's Avatar
    Skrrraaaarrrrrk
    2,704
    Modifies old 4x4, then can't figure out why fuel economy is shit.
    Lookout Mensa.
    Skrrraaaarrrrrk
    1,065
    XJ not reliable?
    That's a new one. 4.0L I6's are the L-series of America. They simply do not die unless you make a dedicated attempt to murder them.
    9,644
    The engines are reliable, it's the rest that gave issues.
    I think the only way to make them good on fuel is tow them around with a big block powered motor home.
    Mar 2011
    Coffs Harbour
    801
    it is true what you say, the jeep will never stack up to the luxurious performer that is the og MAD80X however blacky is unfortunately unregistered as I'm. currently saving for a house and engineer plus rego and the rest just wasn't feasible.
    I bought the cherry for 1500 with all the mods done. but I'd just like it to cost me just a bit less every week and I'd be happy.
    west
    156
    I have a 96 xj, and I did a few things, mainly to increase power, but also resulted in better fuel use.
    Ebay snorkel $90 - colder air into the intake box.
    Pod filter into airbox.
    Piping direct from pod filter/airbox to motor, instead of the clusterfuck box thing from factory.
    Removed viscous fan, got a different length belt that runs a new path that doest use that pulley.
    Ran twin AU electric thermo fans with the clearance from removing the viscous fan.
    Runs way cooler than it ever did. Noticeable power increase. relatively cheap.
    Mar 2011
    Coffs Harbour
    801
    I kinda like my clutch fan so I won't be changing it but future plans include a twin throttle manifold and a cowl intake and maybe extend into a snorkel.
    I'll add extractors while I'm changing the intake.
    hoping the extra free flow will allow it to run a little leaner maybe
