Results 31 to 60 of 143
Thread: RS46 crown wagon
    Jan 2017
    112
    not sure if 3VZ or 5VZ fits, that was someone else's assumption
    1,671
    if you are going to tow with it and go auto I'd defiantly be pushing to get the most cylinders and displacement in there that you can possibly fit
    Jan 2017
    112
    yup, I'm aiming for similar towing performace to my 3rz hilux which i found sufficient for what I tow. Bigger is always nicer though!
    Jan 2017
    112
    just been going through some of the parts car stuff from tamworth, pretty cool I thought.....
    lots of labelled parts jars
    3,908
    Hey! Sorry I didn't message back!
    Been collecting for 30 years - I only have 2 auto columns, and one of those is in my 1UZ wagon.
    Jan 2017
    112
    oh, right - I just realised who you were!
    all good, I was going to modify my manual column but now after seeing some other setups I need an auto one........I may just get one from an old holden
    599
    Use a cable to join the column to what ever auto trans you end up using. Pretty easy to suss out. Trying to think of Toyotas with column autos. Might be worth while trying to track down a later model crown one
    3,908
    A very early (late 67/early 68) 50 series column is supposed to fit BUT I have never done it. I also remembered I bought a whole car just for the auto column, so that makes 3.
    I think I might have mentioned to you on FB to just use a Lokar cable kit and modify it a little. If you use an A340, the selector switch has a series of outputs for the gear you're in - would be very simple to wire up a Dakota Digital gear selector light panel. Here's what I mean - there are retro ones which would fit with the look of the car and would be a piece of piss to fit to the dash.
    3,908
    If you were very creative and had a lot of patience, it would be possible to graft this on to the honey pot. You'd have to get a pointer and mount, and link it to the column shift with some fine steel braided wire at the right sort of ratio. All doable but a proper fuckton of detail.
    https://www.cjponyparts.com/ididit-s...1977/p/ASI2-V/
    Jan 2017
    112
    awesome andrew, I'll have a look into that - one problem I may have when using the manual lever to control the auto is not having a lockout function so i dont knock the lever into reverse while driving around.....I guess it's not then biggest problem I have so I'll figure something out when I get to that step
    TJzone TJ's Avatar
    24,626
    Beams 3S would fit easily?
    #teamtremolo
    And i'd still fuck Betty....
    Jan 2017
    112
    beams would be nice but too dear and no torque for towing
    I've also seen a japanese dude put a spacia van 3SFE into his one too but same problem - gutless....
    8,031
    Very cool.
    My vote is a 2TRFE. Just add a 3076 if you want to fry tyres later.
    My Sports Sedan
    Jan 2017
    112
    So I work for one of the biggest automotive wholesalers in the country and do you think I can find any tie rods for this thing?.....of course not! I did find a replacement for the short outer tie rod but the inner and also the idler arm/pitman arm are going to be IMPOSSIBLE.... It's looking more and more like I need a rack conversion..........which means daewoo/camira parts on my car
    1,671
    well worth doing a rack conversion, did one on my Cressida with the 1UZ and it went from 80kph is scarey boaty to 160kph is scarey boaty
    Sonova Beach
    5,757
    Quote Originally Posted by japlish View Post
    5S bottom-end?
    Jan 2017
    112
    5S bottom-end?
    anything is possible with cash
    Sonova Beach
    5,757
    It's only a Camry motor. Should be free.
    Just find some dumbarse with a whole car, that's snapped the timing belt.
    3,908
    More cubes the better here if towing is the plan. 5VZ, Moo, LS all worthy options. Rack conversion certainly transformed mine. Used a VN Commode power rack. Bit of bump steer but fuck looking for unicorn shit parts.
    BEAMS is a lovely motor but not really a tow motor. There is some peculiarity with the sump such that the earlier, easily modifiable 2S sump doesn't work. Suddenly that big bulky two part front sump is right where the chassis is. Also, the S-W5x isn't a direct bolt up proposition - some of the holes line up, others do not so you're resigned to using the 5 speed auto or the 6 speed box. Earlier generation 3S motors do not have this problem (all the 2S stuff just bolts up and works) but ultimately you still have a twitchy 2 litre motor. Even all the fuck around with a 5S bottom end only stretches you out to 2.2 litres.
    8,031
    So whats wrong with the 2Trfe suggestion? 2.7, adequate torque, modern and common so good chance wrecker motors are good, proven strength, relatively compact.
    My Sports Sedan
    Jan 2017
    112
    price...........
    Jan 2017
    112
    ANDREW - how did you support the steering shaft after the rack conversion? so the uni joints dont flop around?
    8,031
    Compares with a BEAMS, LS et al???
    My Sports Sedan
    Jan 2017
    112
    not using any of those either. others have mentioned it but it's no happening
    15,293
    Most of the conversions I've seen put a bush in the bottom of the steering column outer tube at the firewall.
    Jan 2017
    112
    yeah I've seen that too, I think i'll have to pull the column out to see how it works - not looking forward to getting under the dash in that thing.....smells like moldy old people
    3,908
    I'll get down to where it is stored and take some pics.
    Jan 2017
    112
    will be picking this up tomorrow, doesnt come with the shiny intake but that's ok - probably wont fit in my car anyway
    will be interesting to see how much room I will have........
    599
    Good score! Should fit ok I reckon. You going to adapt a powersteer box conversion in?
    Jan 2017
    112
    looking into a rack conversion as we speak - nothing else to do while i'm at work
    I wonder if a sirion steering rack will handle the pressure under more weight?? hmmmm
