Page 3 of 5 FirstFirst 12345 LastLast
Results 61 to 90 of 143
Thread: RS46 crown wagon
    3,910
    Turbo diesel of some description?
    1,358
    Quote Originally Posted by Andrew Bolt View Post
    Yes.
    Read OPs posts.
    3,910
    Currently at work - cannot see picture as hosting site is blocked.
    Jan 2017
    159
    yeah 2L-TE LX90 chaser engine setup
    engine/loom/box/piping....pretty much everything
    Jan 2017
    159
    So I got the motor on friday - was stinking hot in brissy the whole weekend so progress was slow, these things are heavy! Took me a while to get the stupid thing off the ute (just me )
    The sump on these have wings on the ends that had to be sliced off (get a pic later) and I also have to notch the crossmember a little more to clear the crank pulley. engine mounts are just 5L hilux mounts and still working on the gearbox mount,. I will have to make a tiny "clearance" bump in the tunnel for thats but that's no biggy.
    Have to go thermo fan though as there is no space for the stock clutch fan setup AND i cant use the factory powersteering pump as it uses the same real estate as the main chassis structure for the upper a arm
    Looks like I'm going electric P/S!!
    3,910
    Nice!!
    863
    Awesome! Good progress!
    Astra electric powersteer pump might be the go?
    1,858
    what gearbox?
    Jan 2017
    159
    naa not a fan of those - too messy/noisey, I took a toyota yaris rack home with me last night to test fit - looks like it will be fairly easy to use although I will have bump steer....ahwell.
    https://ls1tech.com/forums/suspensio...#&gid=1&pid=28
    Was reading up on this page about the electric columns, really handy info!
    Jan 2017
    159
    what gearbox?
    stock LX90 auto which is a A34DE? early ones same as MX73 cressida and older crowns.
    6,291
    I thought I was the only one that had that problem!
    CJM 4 Life yo!
    1,063
    Maybe look at an aftermarket fox body rack? You can get them "choppable" for custom length in non-power/power and I am pretty sure they do LHD/RHD as well
    Jan 2017
    159
    not very easy to get in AUS Xnke, if I was super worried I'd just use a daewoo centre mount rack but i'm lazy
    863
    Im pretty lazy at times, id just make a powersteer hilux box or something similar fit. Probably no room though.
    Steering rack with electric power column could be all good though. You might be able to mix and match enough parts to keep it column shift auto?
    Jan 2017
    159
    I only have a manual colomn shift lying around so that may be a little hard - was thinking of doing a dash mount style like the old 50's mopars
    863
    That looks pretty cool actually!
    I was thinking if you got creative with a cable set up on a stripped down Tarago / Previa van column, that might also be an option. Keeps it Toyota OG.
    Jan 2017
    159
    what would be even better is a column from a car that also had electric steering
    Jul 2007
    Blackwater, QLD
    1,618
    can you get some of the capacity back into the sump? the L motors need all the help they can get, oil capacity wise. i've seen a few soot up the oil and spin bearings. was likely related to poor maintenance too, i guess.
    Jan 2017
    159
    Yeah I was a little worried about that, I guess I could extend it backwards and forwards a little but not really keen to chop up more of the sump. I may just put a oil cooler on it to get back the lost capacity...
    Jan 2017
    159
    rear mount mostly done, just did a single offsett bush on the stock crossmember. Will need to shorten the drop down rods later when I raise the gearbox up a little further.
    scored all this for under $100 -
    yaris electric setup.
    and getto ziptied to the trolley jack while I get it sitting right for mounts lol
    Hooroo! Nitephyre's Avatar
    ormeau@gc.qld.au
    6,807
    Interesting. I wonder how difficult it'd be to do something like that on my Lite-Stout.
    1,858
    post a photo of the knuckle \ upright so we can see where the steering arm is...
    Jan 2017
    159
    suspension at full droop
    863
    Making good progress there mate! Does the Yaris electric column need a tricked controller to make it work in another car? I think some of the other ones do from memory.
    Your engine choice is perfect for this project I reckon
    Jan 2017
    159
    thanks dude,
    I put a link up on the last page about the conversion, seems toyota stuff works without much input even if it goes into fail safe mode it still provides assistance, I have an abs ecu for the steering which is not as usable but it will still work. ...I think.
    If not all i have to do is get a non-abs unit and problem fixed!
    1,358
    You can buy black boxes to trick the Yaris column ECU into working from the UK.
    Sonova Beach
    6,306
    Mate did that. Black box came with a dial to change the 'feel'.
    1,858
    pull the springs and shock out dummy it up sitting on the jack through the range of motion
    time spent getting the steering right even if it involves sump mods is well worth it!
    also check the steering arms are in the same place for the front disc conversion
    Jan 2017
    159
    mmmm...too late
    i'll try it how it is and change it if I have too, there will be alot of things like that on this car. I'm kinda doing this car in 2 stages unlike my ae86 on this forum, 1st stage will be getting rough and ready then later on neaten it up
    3,910
    Not here to fuck spiders. Great progress.
