Results 1 to 27 of 27
Thread: Mates Kawasaki Z125 Turbo
    May 2014
    625
    So a mate of mine was tossing up for a while whether or not to turbo his 125. I didn't have much input other than to lend a hand with the fabrication. Have always wanted to try my hand at something like this so it was a good opportunity. I don't have a whole lot of intricate photos right now but more than happy to grab pics of anything you guys are interested in.
    The basic outline of the build was -
    - Borg Warner (off a Smart car for memory).
    - E85
    - Megasquirt
    - Wideband for tuning
    These bikes have a surprising amount of space available. Some guys mount their turbos off the side of the engine, we went for right in front mounted as high up as possible.
    The intercooler my mate first supplied me was hugeeeeeee. Clearly wouldn't clear the turbo!
    Decided to work with what I had, and I cut down the intercooler (by roughly half). Used an angle grinder to cut the tanks, then a hack saw to cut the fins. Wasn't too bad to do, unfortunately none of my neighbours had a band saw so had to do it the old fashion way.
    Next step was to block off the uuuge 2.5" outlets. Throttle body & turbo outlet were both 32mm which worked our very well.
    We decided to mount the intercooler down low in front of the front wheel. Judging by the angles, the wheel shouldn't be able to flick anything directly into the core. It may cop some shit from the road etc so I've recommended to my mate maybe to use some mesh over the cooler to protect it as much as possible.
    The other issue was giving ourselves enough space for the oil cooler & pipe work.
    This is the turbo outlet side. Was not ideal having to run piping past the exhaust housing, but didn't have much choice (will both need ceramic coating & wrapping). The fairings will need to go back on so had to keep that in mind.
    Decided to do the piping in alloy. Keeps the weight down quite a bit and I get a lot of practice with my alloy welding
    This is the turbo outlet side. Was far quicker making this one
    This is how much clearance the oil cooler will have. Not 100% sure I will mount it here just yet.
    That's about it so far. Quite a lot of fucking around dummying things up to see if/how they fit and what effect they have on other components. The hope is to make 7psi +. The turbo is pretty big for a 125 so we will see. The E85 should help lol.
    Wanker MexicanBatman's Avatar
    Mar 2011
    Mexico
    1,987
    Awesome stuff
    Turbo from the 600cc not the 1000cc I take it
    What would be even more awesome if you could fab in a 450 engine
    Now that would be a blast to ride
    Newcastle
    352
    Thats fucking cool.
    I've been thinking about getting one of these for the commute to work.
    Mar 2011
    Mexico
    1,987
    Donít i had a Grom with a takegawa kit and pipe and tune
    A scooter is better and quicker
    And unless you are a tiny dude, a scooter is also less gay
    16,466
    Saw two very small people commuting two up on a grom last night. Didn't look like a great idea...
    Civic turbo + 100hp gas biscan's Avatar
    1,032
    Thanks for starting this. I was planning to start a thread soon
    10,303
    Updates?
    1,032
    We are trying to get flanges made for the turbo in stainless. I have made gaskets to suit and a friend is doing some tracing in CAD to get them laser cut.
    The ones i made on a friends plasma cutter were completely unusable. n.b. I had never used a plasma cutter before
    Dec 2014
    syd>bne
    253
    Subscribed!
    Kebabhunter
    Nay sayer Mr Ed's Avatar
    15,076
    Is turboing a 125 a done thing? Ive never riden a turbo bike but i figure the power is pretty abrupt... smaller the engine the steeper the power curve right? Turbo 125cc must be pretty wild
    Fucking cool though
    1,032
    These make 8hp at the rear wheel stock Ed. I doubt it will get to 20hp.
    Should be a bit of fun to ride anyway !
    1,032
    Some updates.
    A mate did the CAD tracing from a gasket i made for the housing.
    3d printed the flanges for test fit. Everything is spot on. Ready for laser cutting in stainless.
ID:	104827   Click image for larger version.
ID:	104828   Click image for larger version.
    Mexico
    3,802
    Lol I love you used a 3D printer to validate a DXF. Donít own a die grinder? 😉
    1,032
    It is a whole lot cheaper to print another prototype than get 10mm stainless cut over and over if the holes are in the wrong spot !
    Also i needed a project for my printer
    Mexico
    3,802
    Iím believing your second point! Top work carry on
    あなたの母親の肛門 Shifty's Avatar
    10,804
    Funny as.
    Also... be aware the front suspension compresses yeah? Need to allow for that.
    1,032
    Funny you mention that Shifty. We had issues with the front guard hitting at full compression. Moved the intercooler to compensate and i have a full set of Ohlins suspension to go on as well. That should stiffen the front up substantially
    1,032
    Foamy has been putting some serious hours in on the build of late.
    Really starting to come together.
ID:	106110   Click image for larger version.
    1,032
    Starting to work through some of the supporting mods now.
    Barnett clutch and HD springs installed
    Light weight flywheel - Saves nearly 1kg over stock
    30% larger oil pump
    Oil cooler fitted - Properly tight. 1mm between intercooler and 1mm between exhaust.
    Sorted the fittings for the -10 oil drain on the turbo.
    Still need to do
    Weld fitting for oil drain
    Make all the braided hoses for turbo feed, drain, oil cooler
    Fit GM Flex sensor
    Fit Mircrosquirt
    Fit Ohlins forks and rear shock.
ID:	106367   Click image for larger version.
    Jun 2010
    769
    make with the choo-choo already beescan
    24,348
    Did this ever end up being a thing?
    I may or may not have just bought a cheap one of these to add to the toy collection.
    Hanover, NH, USA
    7,282
    At the MotoGP this year I went out for a few beers in downtown Austin and saw a fleet of modified Groms. I was amazed at what blokes were doing.. billet swingarms, Magnesium wheels, CR125R engine conversions, CRF250R engine conversions, Ohlins forks.. it was mental.
    This would fit in well with that crowd.
    1,032
    I stuffed up drilling and tapping the clutch cover for the oil feed.
    Dropped it off to the thread repair guy today.
    Then just needs wiring.
    1,032
    Engine cover came back from the thread repair guy over the weekend. Made up the oil feed line.
    A few more boring things to do like exhaust gaskets, Make spark plug lead and Microsquirt wiring and some painting.
    1,032
    A mate popped around to help out with the microsquirt wiring.
    Nearly ready to start.
    Vietnamese Gang im_boostn's Avatar
    Jul 2002
    1,136
    will you be stunting on this bike?>
    1,032
    Not really stunting on this. Pop a few wheelies but not sitting at 12 o'clock for km's on end.
