Results 1 to 10 of 10
Thread: towning the Einstein way electric brake hack
    syd
    2,668
    so im talking to my next door neighbour yesterday and he said he was building a trailer for his sprint car.
    he put electric drums onto it and said that he used a mechanical override hitch so if it was being towed by a car with no controller the brakes will still work.
    makes sense to me but is this a thing?
    Nov 2017
    486
    He would be using the hand brake.
    Retired dsm2002's Avatar
    1,288
    Towed a car trailer years ago with electric brakes. Had a potentiometer made using a pair of springs and a sliding adjustable bridging clamp. Set it for the load and adjust as required.
    Seemed to work ok when I used it
    syd
    2,668
    with a set of just mechanical drums the cable is used for braking while travelling and for the hand brake, its the same thing
    with electric drums i assume the hand brake actuates the shoes as if it was a mechanical system
    Nov 2017
    486
    Yea that's my understanding but it's been ages since I've worked on trailers so I can't recall how beefy the hand brake is.
    1,822
    mount an electric brake controller on the trailer in a waterproof box and have switch to select internal or external
    Nov 2017
    486
    That will be good when someone tries to tow it with a captiva or outlander ect with a factory fitted wiring loom. Most don't have the blue wire hooked up but some that come with 7 core are about 2mm which is less than 1mm squared. I was told 4mm absolute bare minimum when wiring in trailer brakes which is 1.85mm squared I would only do that on a 1200kg camper anything over that 5-6mm.
    1,822
    Could run a wire to a ciggy plug to charge the break-away battery and run the external controller off that
    Sep 2007
    555
    Irritating website but there are things like this he could use:
    https://caravanandcampinghire.com.au...c-brake-units/
    Aug 2008
    Buddina
    1,736
    Who wants an electric bike?
