Results 1 to 29 of 29
Thread: Hand finish on deck surface what abrasive?
    Nov 2017
    486
    Hi all I'm going to hand finish a block deck it's just a stock moomang so don't get excited. What stone is best for this or should I buy a small surface plate and use wet and dry?
    windsor nsw
    1,197
    Itís stock moo mang. Scrape it with a razor and put it back together
    Nov 2017
    486
    Quote Originally Posted by bpm View Post
    It's on it's second set of gaskets so I thought I would give it a sand back (this is the first time I've touched it). Plus I want it to last this time.
    Struggletown
    6,552
    Can you actually see where it's blowing head gaskets or is it just the intake gaskets leaking and making a milkshake like they always do?
    Get the heads pressure tested, checked for straightness and skimmed and check the block surface with a straight edge and see if you can find the issue. If there's any real problems with the block you'll struggle to fix it properly with sandpaper. More than likely it'll be the heads if its not the intake gaskets
    Hold it flat cunt
    Nov 2017
    486
    First time apart was for new lifters and valves now it needs mains and bigend bearings. So it should be flat, I was going to buy a straight edge to blue it after to see how far it's out.
    The owner who I know wants this thing to just run and last but does not want to pay the extravagant amount wanted to rebuild an L67.
    Nov 2017
    486
    So I found this but it's a custom made item FFS.
    16,301
    What, you can't use your brain and get a bit of gauge plate, drill, tap and use some wingnuts to hold on some bar?
    Nov 2017
    486
    Where the fuck do you get gauge plate from?
    That was rhetorical btw, googling now.
    Defective Faux Forg's Avatar
    Sydney Traffic
    1,670
    6,277
    80 grit flapper on a 4" will sort it.
    Nov 2017
    486
    It's looking like that will be what it gets after a scrape. Just need to see if the engineering shop up the road has 500mm x 25mm x whatever precision ground bar.
    I'm going to buy a good scraper and practice scraping for my engine and see if I can scrape the heads and decks lol. Edit my engine in need of a rebuild is a 4g54 so I'm going to experiment.
    9,392
    Sonova Beach
    6,405
    Back and forth with a sharpening stone is the most I ever do, if everything is true-ish.
    Nov 2017
    486
    Yea thanks. I just have never used a sharpening stone for this sort of thing itís always shave head and scotch bright the block get the shit box out of the shop ASAP. I want to do this job with a little more care and all the following jobs.
    HDSTV Gus The Snail's Avatar
    Sep 2005
    west brissy
    1,190
    I have a rather large and thick plate of glass thats perfect for heads
    ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ
    The Burquas arent better at hungry jacks!
    16,301
    Not so useful for blocks though is it?
    Sep 2005
    west brissy
    1,190
    thats what the mill under the house is for
    Nov 2017
    486
    Quote Originally Posted by Gus The Snail View Post
    Mills are overrated.
    Registered User Dimi's Avatar
    Sep 2012
    1,675
    Its a mang? one of these are more than the deck deserves
    1,065
    Without a reference face and the training and practice to use it, you're far better off not touching the deck with a stone or scraper.
    4,228
    You cant fuck much up with a sheet of 800 grit went and dry on good sanding block;
    Heavens knows how many cunts use roloc discs on heads, blocks and fuck knows what else and get away with it.
    Am also a fan of brass wire wheels in drills for getting gasket and shit off cast components, just keep in mind that bits of wire will come loose and go places.
    Apr 2008
    NSW
    521
    you cant fix much either with 800....id be using a thick piece of glass and spray adhesive with a large sheet of some coarser paper than 800 if i had to true a block or head myself. if i just wanted it clean id use a scotch brite and chemicals
    E30 325is M20 3.1L
    Nov 2017
    486
    I've used roloc discs many of times before brown ones for cast and blue ones for alloy It's what you do when the boss is trying to pump out maximum amount of work in the shortest time possible. If you roloc a head and blue it on a reference plate you can see the high and low spots. An engine shop I use had one on display. Method always was get head shaved and roloc the block in the car.
    Any way I just stoned it with the one Faux Forg posted and it worked fine there was a bit more wear at the edges from the stone but I didn't go to hard so i just stopped. The high spots are around the bores where I guess you want extra pressure from the head clamping down any way.
    Jul 2007
    Blackwater, QLD
    1,646
    quoted for truth. the amount of flat surfaces fucked by these is mind boggling. timing covers rounded so the cover cuts the gasket when it's done up. a bit of wd40 and a stone does the final clean just fine.
    Nov 2017
    486
    If you're aware of how easily they can fuck a surface which most aren't then you can be gentle and not do too much damage. It's expected that you use them in some shops as your always working too slow. I like to use the scotch brite that panel beaters use for just cleaning alloy gasket faces like rocker cover gaskets and timing covers ect.
    Sydney Traffic
    1,670
    A mechanic mate of mine did head gaskets on a customer's fully built 355 Holden. He didn't check anything for flat/true/etc, cause it was a 308; how bad could it be? It blew the gaskets again before it even left the shop. Heads off again and sent to a reputable local machinist, who sent back a series of photos of each pass of the mill. It was like a series of topographical maps. 60 thou off each head to make them flat. The surface of the heads was high in the centre and low along both edges where some clown had filed material off.
    CSH.
    Nov 2017
    486
    CSH.
    Yea with the stone i was using you could see the edges getting more wear from the stone so I had to stop but it was clean enough if you kept going so that it was nice and shiney I can see how you could fuck the deck.
    Jul 2007
    Blackwater, QLD
    1,646
    CSH.
    wow. jesus. an extreme example.
    4,228
    Fuck that, and I bet the foreman gets the shits when things come back for re-work?
    Not really a shop you want to work in.
