Results 1 to 16 of 16
Thread: Shared rear indicator and brake light. 67 Mustang
    6,501
    I've a mustang in the garage which is beating me.
    The rear lamp is shared by the indicator and brake light by the looks. The car is mint but the wiring is an abortion. When the hazards are on and the brake pedal is pushed, the indicators stop blinking and stay on.
    Has anyone got a wiring diagram for this sort of setup? It has a wiring loom kit like a painless or something. Click image for larger version.
    3,509
    I think the power wire to each light goes through a relay. The normal position is the brake light circuit but when you get an indicator switch signal for either side (or both for hazard) it pulls the relay to prioritise the indicator circuit
    4,845
    wow - sure looks painless.....
    U gon dun wha now? Speedyblue's Avatar
    Mar 2007
    Queensland, The Tax State
    1,105
    If you have an indicator on instead of hazards does it keep flashing when the brake pedal is pressed?
    Ya'll don't know what it's like. Being male, middle class and white.
    Canberra - ACT
    3,291
    From memory the most basic of these systems use simplified wiring out the back end of the car and do all the trickery with the switches/relays. The painless wiring manuals are really quite good for getting a handle on the standard US wiring.
    There will be a circuit for the front and another for the rear, if they're transposed weird shit like what you're struggling with will happen.
    http://www.painlessperformance.com/Manuals/20121.pdf
    Even though it's not painless you're dealing with the wiring from the switches/lights will be much the same.
    Jan 2008
    Bris
    1,149
    I can't speak specifically about a 67, but a 65 does the same. The switching is done by the indicator switch in the steering column.
    If you follow the wire from the brake switch, you'll see it runs through the column before heading back to the rear lights.
    The original setup uses no relays.
    Dec 2005
    Seattle
    2,929
    fwiw, thats what happens in my c10
    Indicate left, hit the brakes, left lights keep flashing, right go solid. Same if you indicate right obviously.
    Turn on the hazards, all lights flash. Hit the brakes, flashing stops.
    I think its just 'merican logic
    38
    all the US based vehicles do that, its done thru the steering column switch. to split the circuits to run seperate indicators, disconnect the brake feed to the column and run it to the rear of the vehicle (some aftermarket harnesses already do this as the '3rd brake light' ) connect this to your brake light globes. take the existing wires from the brake globes and connect to each side indicator
    Supercharged EBII 4.0
    1,858
    FARK electrical fire hazard!
    9,421
    were sequential turn signals optional? and do they use the same wiring setup?
    1,651
    My god.
    The stock stuff is miles simpler.
    Thats in rip it out and start again territory IMO.
    302 Ford Windsor Technical Forums
    Quote Originally Posted by rollin7
    but I'm seriously in love with this thing ...the pure uselessness and dickheadness of this mustang makes it the most enjoyable car I've ever driven, its fucking STUPIDLY loud for no reason, it gos real fast but wont slow down, they have made the suspension real hard and yet and it wont corner worth a shit. theres something very Aussie about it, like the drunk guy who makes a hat out of watermelon.
    Ellis Juan mizone's Avatar
    4,203
    That's a Ron Francis setup. Not sure what type you have there. Best bet is call them https://www.ronfrancis.com/contactus.asp
    Ask if the setup has a third brake light option. Use that as your brake lights (err derr) for the inner two lights and allow the outside to flash.
    Alternately you can use your reverse lights as indicators. Speak to Mr Mustang and get his amber lens whilst your on the phone to him.
    1,858
    I'm still having nightmares of that wiring, I have done some quick hack jobs in my time but fuck thats nasty!
    as for the indicators why not just put seperate ambers in...
    https://www.macsautoparts.com/ford_m...1967-1968.html
    1,651
    +1 on reverse lights as indicators. Thats how I run mine.
    1,651
    https://www.cjponyparts.com/led-tail...968/p/TLLED61/
    If you like the orange brakelight option... these are on sale now.
    4,203
    Amber tail turn lights - Don't help me much I've a 1970. But would be awesome. Some mob in euro land do a conversion kit to amber flasher taillights etc all LED, but the cost is more than my car.
    The only way to sort that mess out is to remove the dash and take the harness out. If the wires are labelled along their length then it's pretty straight forward and two days work.
    Why I think it's a mess is none of your wires are cut to length. It may be a generic kit.
