Results 1 to 7 of 7
Thread: reducing thread size with helicoil
    Newcastle
    382
    After a helicoil with a M14 x 1.5 outside thread and m12 x 1.5 inner, does such a thing exist?
    5,614
    Doubt it, pretty sure the drill size for an M12 heli is something like 12.6mm
    870
    Yes, look up Timesert threaded inserts. You might be able to use the Timesert 1485 kit, it's for reducing an M14x1.5 oil pan plug hole to M12x1.5. Not easily removable, so once you do the job, it's done.
    Jan 2008
    Bris
    984
    Timesert or keensert. Your local bolt shop will have them.
    Helicoils use unique threads on the OD.
    www.brisbanecityfitnessbootcamp.com.au/brisbane-bootcamp/
    www.vapourblastingbrisbane.com.au/
    Sep 2012
    morwell vic
    266
    Quote Originally Posted by uuheels View Post
    Coarser or deeper to give a bit of "bite", so to say? Just curious.
    Yeah, bit too nice for me, I prefer my R32s with mountains of bog and LS engines
    870
    Actually the timesert taps are standard taps, they're just "STI" threads. "Standard thread insert" sizes, as timesert and others that make solid thread inserts use these. Helicoils are probably similar but I've never tried to interchange the two.
    Helicoils are wound slightly large on the OD/ID to retain themselves-as you twist them in you're actually compressing the OD into the threaded hole, which reduces the ID to the correct size. That's why they're a bitch to try and twist back out of the hole before you break the tang off, and even more of a pain in the dick to remove after you break the tang off.
    Nov 2017
    233
    There’s a triangle helicoil remover tool that works fine it comes in some kits.
