Page 2 of 2 FirstFirst 12
Results 31 to 35 of 35
Thread: Why is single exhaust runner glowing
    FJ20DEBT NISMOgemini's Avatar
    Brisbane, QLD AKA: Gene FJ20DET
    3,900
    Carbs were dyno tuned on the old engine. Iv made no adjustment changes since.
    Nov 2017
    82
    Swap the carbs around and see if the glowing runner follows?
    Might be worth checking the baseplates for any cracks/damage while they're off; I had an old 202 powered HZ which stumbled/leaned out, but only when attempting to make left hand turns at speed. The baseplate of the carb had a crack from the bolt hole to the centre on the passenger side which was opening up just enough to cause issues - Was only apparent once the carb came off.
    4,845
    i'd be looking at the carb that serves cyl 4.
    as each barrel serves a cyl
    float level,jets clear-inc air correctors, main jet not loose , drilings clear etc
    3,900
    I'll check the insides of the carb again. Had a quick look and all seemed fine.
    Swapping the carbs will be painfully due to the linkages but might need to
    5,372
    Block the throat to cyl 4 while idling and see what happens.
    Daily: Honda Civic EK1 Hatch
