Results 1 to 6 of 6
Thread: Rebuilt SR20 stinks like/burns oil going downhill
    Extended member nopistons's Avatar
    Nov 2013
    367
    Hey Braintrust,
    This isn't a crushing issue, moreso just a curiosity.
    What: rebuilt SR20DET. Has done ~ 55,000km. Built engine in mid 2013, used OEM seals/everything, aftermarket cams/valve springs/oversized valves, rods. Have got an oil filter relocaton + cooler (installed between 25k and 30k). Have changed do a hybrid S13/S14 rocker cover with new S14 PCV/breather hoses around the 35-40k mark.
    When: when driving downhill, the car smells oily. When I had ignition issues, it would foul up and need a few good hits before it pumped out some tough smoke/misfired and banged, then would be good again. Since fixing ignition, it'll just make slightly less power for a few seconds.
    No real oil leaks, oil level never drops noticeably. I did a compression test in 2015 or 2016, it was still 150 psi on all 4 cylinders.
    It's done this literally since I put it together. So 4.5 years, 55,000km. The engine internals haven't changed (except changing busted titanium retainers for standard ones at 30k km), but did add the oil coiler / change to S14 PCV / multiple turbo changes over its life time.
    A friend says his friend had a similar problem, every time he's in the car, the culprit being valve stem seals. I would think that would cause more issues at idle? The car idles, drives, and revs out fine.
    I can't remember what I'm saying now
    tldr; car stinks like oil when driving down mountains. seemingly no other symptom or issue. possible causes?
    windsor nsw
    1,219
    If itís stem seals, vac will pull oil past the intake valve guide. So in a long downhill off the throttle, youíll get smoke when you get back in it. If you let it idle for 5 mins and give it a rev youíll get a bushfire on the first rev
    Sonova Beach
    6,517
    Yeah, definitely sounds like valve stem seals.
    I think Flanders went through this recently too.
    Nov 2013
    367
    Yeah fair enough. Makes sense to think of downhill driving as time spent in vacuum
    Churs
    Jan 2018
    blacktown/nsw/Australia
    1
    I have ford falcon au1 1998 just wondering how can i reprogramming dash cluster
    Sep 2010
    1,443
    Yeah mine was way worse when it was on a hill rather than the flat. My shitty exhaust seals had come off altogether on a couple of valves.
