Results 1 to 3 of 3
Thread: Auto Trans Tuning - Kick Down Conditions
    9,276
    Guys,
    Fiddling with my Dad's FJ20ET datto ute. It has a VL 4N71B Jatco which I'm setting up as standalone (no TCU).
    At the moment I have a switch on the accel pedal that activates the kickdown, but it only does it at 100% throttle. It seems a big clunky. Great if you are drag racing, not so good if you are losing speed up a long slow hill. You can boot it, make it shift down and then feather the throttle. I'm looking at a better solution.
    I have a spare ECU output and would like some advice regarding kick down conditions.
    I have inputs for Road speed, RPM, TPS, engine load (all the typical EFI shit). These inputs can be used to build a rule controlling the output.
    I'm thinking :
    IF TPS > 70% - kickdown
    or
    IF RPM <3500 and MAP > 5psi? - kickdown?
    Am I on the right track?
    1,462
    I guess because turbo some sort of vacuum modulation is out.
    9,276
    Quote Originally Posted by BigJonWB View Post
    It has a vacuum modulator and shifts up well with this, but doesn't seem to work that well on the turbo car shifting down. Its a NA box on a turbo engine. I have a 'turbo' modulator to be installed. Replacing it on the car is a bit of a pain though.
