Results 1 to 21 of 21
Thread: General Brake Bleeding Question
    6,240
    On a 2 output master, one circuit feeds the front wheels and the other circuit feeds the rear wheels. Both using a T piece.
    With completely dry lines, the rears bled up nicely and are free of air.
    The fronts now can't bleed because depressing the pedal is impossible as it hydro-locks and clamps the back brakes.
    Is there something I'm missing, either procedural or mechanically/hydraulically?
    9,034
    are all the brake lines OEM ? or has someone made changes?
    Opens GAZ914's Avatar
    1,558
    I take it the rear circuit is also the rear part of the M/C.
    Although the rear circuit 'locks up' - the piston should still push on the front piston in the M/C until it stops at the end of the M/C. See diagram
    https://en.wikipedia.org/wiki/File:M...er_diagram.svg
    Something doesn't sound right with the M/C - have you tried undoing the line at the M/C and see if any fluid being pushed?
    cheers
    Gaz
    Race Car: VT Commodore (Murray) coming soon!
    www.vsport.com.au
    14,713
    Let me guess, it's got a switch mounted between the line ports on the master? Bled it with a dry master cylinder? Rear circuit is closest to the booster?
    When you went full metal jacket on the pedal it pushed the shuttle valve that operates the master warning switch all the way down the bore and has closed off the port on the other circuit. Been there, done that. Had to pull the master back out, unscrew the closure plug on the shuttle valve and belt the thing against a bench to get the shuttle valve to unseat and return to centre.
    Oct 2012
    72
    ^^^ what he said
    ACT Now!
    26,758
    Yep for sure.
    When bleeding only use a 1/4 of the pedal travel to do it and bleed at the MC first.
    882
    Also you can gravity bleed the system before attempting to bleed the normal way, and that helps when you've got the shuttle valve in there. Also another way is to gently apply compressed air to the front brake circuit via a front bleeder, usually 5 or 10PSI is enough to shuttle the ball back enough to let you bleed fluid through. COVER THE MASTER! Not sure if the air trick works on modern shuttle valves but it's worked on the ones I have encountered on a few random 1969-1994 vehicles. Also didn't work on a few random vehicles in that range as well...call it a first attempt.
    6,240
    Handy shit fellas.
    The pedal basically goes 20% down with little resistance and then is rock hard.
    Worst case gotta pull the master off and have a play by the sounds of things but will try the others first.
    Down with ma homies Greg Rust's Avatar
    Perf
    10,285
    Just crack the lines 1/2 turn at the master cylinder and put a rag around it to stop the dribble on your paint.
    xw Falcon 393 full race cam, NGK spark plugs.
    ACT Now!
    26,758
    Did you take the brake clamps off?
    I may know someone that forgot to take the brake clamps off one day...
    Į\_(ツ)_/Į burn is weird's Avatar
    1,474
    http://www.ebay.com.au/itm/Hand-Held...g/162639571615
    or
    https://www.ebay.com.au/itm/Hand-Hel...p/172810521685 (supercheap want $202 for that exact model "bikeservice vacuum pump")
    pull instead of push. also awesome for pulling pistons back in multi piston calipers when changing pads by clamping the line.
    all Master cylinders are designed to feed from reservoir so will have no issues this way, added bonus is bubbles get bigger under vacuum.
    also good for calibrating absolute pressure sensors.
    9,034
    My pressure bleeder is awesome.
    Compulsive modifier awdmoke's Avatar
    WA
    1,205
    Vacuum bleeder is great, just remember to grease your nipples.
    Google it.
    Lots of minis & mokes including a G13b powered Sports Sedan, a couple of Swift Gtis, a Goggomobil, Porsche 928S, Polo Gti, BMW 540i, a WRX and a few others.
    Perf
    10,285
    Jason Bleedhurts.
    1,100
    What one do you use Tim?
    ACT Now!
    26,758
    Iíd use a pressure bleeder over a suction type.
    Good old clear tube into a bottle has served me well for 30 years and I donít see the value in other methods.
    Nov 2017
    238
    You know what vacuum bleeders are good for? When you have finished pumping the pedal into it you close the nipple pull the trigger and lock it so it sucks all the fluid out of the hose so you don't drip it all over the floor.
    9,034
    Quote Originally Posted by garvice View Post
    Ive got one of these
    1,100
    Cheers Tim.
    ACT Now!
    26,758
    Amazing. Are you saying they have invented a machine that can replicate the effects of gravity in fluids? Iíve always just held the hose up.
    14,713
    I think he also uses it on his cock to, errr, suck the fluids out.
