Page 1 of 2 12 LastLast
Results 1 to 30 of 32
Thread: Jz auto options
    Opens ALLMTR's Avatar
    23,311
    Jz auto options
    If you're making good power ie 125mph trap speeds you need a th400
    Thanks for your time
    1,188
    Wat?
    23,311
    We decided we needed a dedicated thread to how good a th400 is
    Mar 2011
    Campbelltown, Sydney, Australia
    640
    You have been reading the bullet too much.
    You need a glide......... apparently.
    1,188
    I see... I think... or not lol
    Registered User Tyrie's Avatar
    Mar 2010
    2,405
    Surely if you're only trapping 125 the a340 is fine. And if you're dead set on losing overdrive, why not c4 over th400?
    14,868
    Electronic controlled and shifted lenco
    17,237
    the guy with the sequential turbo setup celica had a lenco with a clutch.
    I'm also keen on this... gotta be able to do drag challenge & a little street duty & a KM flat out.
    23,311
    Quote Originally Posted by Tyrie View Post
    I think that's the changeover point (there or thereabouts). Once you're doing all the conversion bits (mounts/bellhousing/tailshaft/shifter/speedo) you may as well go to the strongest. I regret going c4 in the Barradore
    9,337
    C4 is way too expensive to make it >500hp reliable.
    4,161
    Jamming a valve body, convertor and fitting a good cooler in a A340E gets you quite a way and they will handle some power.
    Issue is, when you blow it up getting it properly rebuilt is a fair chunk less than conversion costs and another transmission, if you legitimately drive it a lot then going back to a 3 speed box is insanity when even a 4 speed these days is a bit gay - so factor in a gear vendors OD for the TH400.
    TLDR; Unless your making really big power towing the cunt to the drag strip, give the stock box a go.
    Fuck I'm retarded
    Mar 2010
    2,405
    Quote Originally Posted by dnegative View Post
    Mine was fine with nearly 600whp 1uz and 135mph.
    23,311
    I don't think losing overdrive is that much of a problem for a 2.5 or 3.0 litre motor. The prices I've been quoted to build another strong 340 are similar to the price of a built th400 so you'll only be out the cost of the conversion bits
    17,237
    so anyone street drive a CO2 shifted trans? am i going to need to top it up every 100km?
    VW Service Bloke Sloth's Avatar
    3,731
    toploader or your a faggot.
    Only be concerned if that Dunning-Kruger Motorsports bloke is there and goes all Captain Damphands McGigglefingers on you after a couple of lemon squashes....
    I'M NOT A HOOKER BUT 20 BUCKS IS 20 BUCKS...
    robslothyoung - follow me on insta.
    1,858
    Mar 2011
    640
    Just use a 15lb nitrous bottle without the siphon tube
    17,237
    Quote Originally Posted by 1320ft View Post
    I was thinking extinguisher - but y'know.. doing some reading on lenco's - seems like it might fit the bill pretty nicely - and the function of the CO2 engagement (and being able to adjust it to suit conditions - of say, a runway vs a prepped track - give me a bit of a chubby)
    but not much good if the bottle has to be above x psi all the time and changed between passes...
    Registered User Ke26 Wagon's Avatar
    Jun 2009
    1,135
    4L80e..... same strength as a th400 but extra gear
    1,062
    C6 or don't bother
    If you're gonna go for the strongest, go for the strongest. They don't suck power like people say, I've run them back to back against a C4 in the same car and didn't loose enough time to get outside the realm of pass-to-pass variance. There are LOTS of 2000HP blown alky big-block monster trucks running C6's, have been for ages, and normally it's only input and output shafts that get the boot. Drag guys like to rollerize them, which works great but costs money. Like I said, in my drag application we didn't see anything close to the "OMGZ 50HP LOSSEZ WITH C6!!!" claims.
    Goat roper Motherfucker Jones's Avatar
    Struggletown
    6,552
    You could do that with an auto with a lot less hassle. Either a bump solenoid on an aftermarket shifter or internally with something like a 4L80E. And drive it like a normal auto the rest of the time.
    Quote Originally Posted by RVK 355 View Post
    Hold it flat cunt
    Struggletown
    6,552
    C6 or don't bother
    What would be the advantages over a GM Trans that has heaps of parts availability?
    Hold it flat cunt
    1,062
    C6 really needs no parts aside from input shaft, converter, shift kit to get it shifting where you want, and done. Stock rebuilds will live behind high horsepower heavy as shit drag cars for years with few to no problems. Like I said, Bigfoot was built around the C6/460 Ford combo, and a lot of monster truckers and tractor pullers still use them, while drag racers seem to whine about being a big heavy transmission. (I will admit, it's a heavy motherfucker of a trans!)
    4,161
    The old TH400 is the gold standard, everything is cheap and every combination is known and has been done.
    There are probably a half dozen off the shelf kits to bolt a GM auto to a JZ, not many for the Ford box.
    Fuck I'm retarded
    1,062
    That's true-and the bell is not removable on the C6. Did you guys ever get the C6 behind anything but the big blocks down there? If you got them in the small block pattern like we did here then a C4 adaptor plate would work just the same.
    Struggletown
    6,552
    So basically the same benefits as a TH400 but without an endless array of aftermarket support
    Hold it flat cunt
    aka SpaZdA (tm) mondo2000's Avatar
    1,341
    6L80 is lighter than any other GM box.
    Are they inherently weak, or are knuckle draggers afraid of electrons or something?
    1,062
    Probably more spendy all told, is the reason they don't get the nod, mondo.
    1,188
    6l80 is a massive cunt of a thing
    Registered User Euronymous's Avatar
    Feb 2017
    1,112
    you cunts are fucked, trimatic all the way!
