Page 2 of 2 FirstFirst 12
Results 31 to 34 of 34
Thread: MIG recommendation for panel work?
    BOOSTFARKIN Morcs's Avatar
    May 2012
    686
    Quote Originally Posted by Shifty View Post
    I ended up with a Lincoln 180C with trolley for $1100 through Adelaide Tools.
    Have had one for ~10years only thing have replaced has been tips and oring on the regulator.
    Good trick is but a ear plug on the wire between wire roll and drive roller thing so that the MIG wire gets cleaned as you use it.
    あなたの母親の肛門 Shifty's Avatar
    10,793
    Good to know!
    I'll try the earplug trick as well,
    biggest complaint I've had with MIG in the past is feed rollers.
    May 2012
    686
    The dual feed rollers help on these.
    Earlier models had stepped voltage control and single roller drive system still an excellent welder though.
    Still gotta keep the lead straight though.
    The ear plug also puts a little bit of tension on the feed which helps keeps the wire feed a little more consistent/smoother at the business end as it takes the backlash out of the roller system also.
    Registered User MWP's Avatar
    1,778
    180C here as well, is a good thing.
    That earplug trick is good idea, will do that.
    Ive even had some success MIG welding alloy with it... without the spool gun too.
