Results 31 to 60 of 75
Thread: Off road Teardrop
    11,072
    Cool camper. Keep that polyurethane bushing out of direct sunlight if you want it to last. UV light kills it.
    Mar 2013
    Katherine/NT/au
    238
    Trying to get stuff done in the worlds most unorganised workshop is fucken hard work but at least I have it all ready for welding now.
ID:	105276   Click image for larger version.
    Mar 2013
    Katherine/NT/au
    238
    Work has been stupidly busy for the last few months and the fella that owned the workshop I was going to
    use decided that getting a real job was better then being self employed so lost workshop space to do the
    work but have finally got a chance to get started on the chassis.
    Been so long since I used my welder that we had to hot rod it first before welding, now has the air line off a incendiary launcher as the gas line from solenoid to hand piece.
    Needs a clean up and a jam job but will be a billion times stronger then the 1mm C section chassis that it has now.
ID:	106793   Click image for larger version.
ID:	106794   Click image for larger version.
    Nov 2016
    geelong Australia
    74
    Ice I'll post some pics of mine some time.
    I to went from self employed to a real job..
    Quote Originally Posted by Shep View Post
    Sent from my SM-N950F using Tapatalk
    Mar 2013
    Katherine/NT/au
    238
    I got stuck into it today. Decided that the best way to do it was to get the new chassis off the ground and solid then as I
    cut the bits off the old one I would winch the pod onto the chassis.
    And fuck me dead it actually worked
    Hopefully have it ready for rego in a couple of days.
ID:	107512   Click image for larger version.
ID:	107513   Click image for larger version.
    PARRA MartyHusseinXF's Avatar
    vegas
    6,251
    fuck yeah, nice.
    Mar 2013
    Katherine/NT/au
    238
    Very happy with the way it sits behind the car and the new chassis, tyres and suspension has lifted it 230mm higher
    Perth, WA
    781
    Haven't read every post... but is the body/structure suited to being hammered off-road?
    Mar 2013
    Katherine/NT/au
    238
    Quote Originally Posted by South View Post
    Probably not but there is only one way to find out.
    Mar 2013
    Katherine/NT/au
    238
    Got the generator box mounted properly and the wind down things welded on.
    Need to make a tyre mount, chop the guards up a bit, fit the water tanks and plumbing and then wire up a battery and all the 12V stuff.
    Got a bit of an idea what I want for the tyre mount but no idea what to do with the rest of the stuff.
    Also glued the chain on
    Mexico
    3,984
    Mate if youíre using 200x50x2 the chassis will be fine. Big off road vans use 150x50 and between 2.5-4 thick. On a frame that small with such little payload it should be plenty strong.
    Mar 2013
    Katherine/NT/au
    238
    Chassis is 100x50x3. Chassis will be plenty strong enough, the pod is the unknown bit however it looks pretty well made and I reckon it should stay together ok.
    Mar 2013
    Katherine/NT/au
    238
    I went back through the thread to see where you got the measurements from and stuffed if I know where I got the 200mm from. Correct measurements above.
    Mexico
    3,984
    Ah yeah thatís more sensible. Iím sure that will be fine. And for the size of it the body will hardly be stressed. I approve copious off road thrashing for science.
    Mar 2013
    Katherine/NT/au
    238
    It is really just 3 bits of fibreglass glued to a ply floor so a roll or two of race tape will fix it if it falls apart.
    Mar 2013
    Katherine/NT/au
    238
    Finished off the outside bits and took it for a quick run. Went well and seemed to not mind smashing pot holes etc.
    All up weight including a N70 AGM battery, generator and 20L fuel it weighs 600kg.
    Very happy with it. Now just need to wire up the inside bits, fit a side awning and mod the rear awning and it is good to go.
    Pretty sure it needs to be orange as well
ID:	107676   Click image for larger version.
    5,737
    Surely a 3.5t caravan would be better?
    Good to see a lightweight setup for a change.
    vegas
    6,251
    Make sure you hog the right hand lane and whinge about Caravan Parks being rip off compared to free camping.
    Also, looks great!
    1,433
    Great idea and well thought out.
    Just put an orange vinyl splash down the sides under the windows to tie the colour with the Jeep.
    Nov 2016
    geelong Australia
    74
    Nice van mate.
    Should be verry happy with that
    Mar 2013
    Katherine/NT/au
    238
    Did a bit more today. Bodgy wired up the 80W solar panel on the roof, sticky taped a 12V fan to a wall
    and permanently mounted a Ctek 7amp charger. Also glued a battery box to the floor for a 105amp AGM battery.
    I haven't permanently mounted any of the accessory sockets or solar panel controller as they have pretty
    bright lights and I reckon they will piss me off when trying to sleep so need to have a bit of a think about
    where to mount them. Also found some stick on battery LED floodlights for cheap at repco so stuck a heap on.
    Took it for a 50km highway run to settle the suspension and at 130kph it was only using 16.5L/100 so not
    much worse then not towing. My wrangler carries 120L of fuel so should still have a good fuel range.
    Heading to the tanami desert fossicking next weekend so that will be the test if I have wasted time and money on the teardrop
ID:	107685   Click image for larger version.
ID:	107686   Click image for larger version.
ID:	107687   Click image for larger version.
    Mar 2013
    Katherine/NT/au
    238
    Quote Originally Posted by MartyHusseinXF View Post
    Also, looks great!
    Haha most of the roads I drive on are only 1 lane to start with. I just stay on the dirt and power on past the tourists and
    poor buggers stuck driving slow shitbox toyotas
    Mar 2013
    Katherine/NT/au
    238
    Did around 1400km on the weekend, teardrop worked real well and just needs a few little things to finish it off. Even found a little bit of gold.
    The coin is an abnormally large novelty coin.
ID:	107814   Click image for larger version.
ID:	107813   Click image for larger version.
ID:	107815   Click image for larger version.
    Mar 2013
    Katherine/NT/au
    238
    Stone guard on, tv wired up with a roof mounted antenna and a 2x2.5 awning.
    Still need to make a tyre holder and plumb the water tanks.
ID:	108200   Click image for larger version.
    Registered User TurbostyleR's Avatar
    Sep 2003
    1,084
    Ah I see you have wasted no time with the fap material on the tele...
    Pretty sick setup! How'd you go with the air con? Have you tested it yet?
    Get your hands off my penis!
    Mar 2013
    Katherine/NT/au
    238
    Haha yeah the a/c works real well. Because it is such a small space it turns it into a fridge, generator hardly worked once AC had brought the temp down and cycling.
    Mar 2013
    Katherine/NT/au
    238
    Spare tyre carrier finished, used a lazy hub with the same bearings so if I have a bearing let go I can just slap the lazy hub on.
ID:	108526   Click image for larger version.
    Mar 2013
    Katherine/NT/au
    238
    Really happy with how itís turned out. Tows really well in The bush and on dirt roads.
ID:	109784   Click image for larger version.
    5,737
    Looks great. Agree that a bit of orange would finish it off.
    Did you fish plate the drawbar to the main rails?
    Mar 2013
    Katherine/NT/au
    238
    Yes has fishplates
