Results 1 to 13 of 13
Thread: Diff ratio calculations for speed/rpm
    Terra
    3,375
    Tried a bit of a search but didn't come up with much. Likewise google has some calculators but couldn't find a straight forward one that seemed accurate with what I thought it should be (gear ratio 0.5 in sixth, 2.92 axle ratio, 19s and rpm@100 odd of about 1200rpm kept coming up higher when entered?)
    Essentially, swapped the car over to manual, still has the auto diff ratios in it (2.92 iirc). It's a low boost TT setup with twin 3071s so full boost is there by c.2500rpm anyway so don't need or want anything too steep (3.9) and street car that'll pbly never see the drag strip. Plus I'd like to keep highway revs as low as possible because I do a bit of that.
    Being the trutrac is going in figured a reasonably thing to chuck some 3.45s, maybe 3.7 though as above and don't want to make 1st useless.
    So either experience or a good calculator would be appreciated.
    Cheers.
    Nov 2017
    486
    3.75 or 4 is from memory what the VZ hsv's ran and that was a good ratio for the 6 speed. Been in a 4.11 6 speed from canberra to sydeny it wasn't too bad.
    24,299
    I use this one:
    http://www.apexgarage.com/tech/gear_ratios.shtml
    Is accurate for my car.
    3,444
    PM me your email and Iíll send you the one I did for my car
    Littering and....?
    1,611
    Ive got a turbo 5.7 6 speed with a 3.46 and its too low. You have to go back to 1st around round abouts, it does 130km/h in 2nd etc. It's a pain.
    Im looking to go to a 4.11 or similar.
    Nov 2017
    486
    Also is the wheel size the wheel and tyre diameter or just wheel diameter as your 19" wheels might have a 21-22" overall diameter that might be where you are getting higher figures.
    5,963
    Terra
    3,375
    I use this one:
    Cheers was one I was fiddling with but as per below...
    Yeh, obviously wasn't looking at it close enough, banged the 19" in thinking rim not rim+tyre
    Will send pm, cheers dude.
    Quote Originally Posted by Rhys View Post
    Huh, really, maybe the l98 has a bit more in the bottom end, typically hold mine in second? Good to know though, will run the calcs after work but starting to think the 3.7 might be a good balance.
    3,051
    3.74 if you keen but 3.4s are good for boosted LS unless you want to blow the tires worse than you are already. They donít mind being made to work so taller isnít a bad thing
    Terra
    3,375
    Yeh, still torn between the two, 3.45 or 3.7, was almost inclined to look into keeping the 2.92 but some slightly steeper wouldn't go astray.
    Will look up the ratios for the box in my car and have a bit of a play around with the calc above and the one lukevl was nice enough to offer. Main concern is not making first useless and still having the thing turning under 2000rpm at 110-120.
    24,299
    Calculator i posted is bang on. Feed it the right data and happy dayz
    For my car with calculated 4.8% converter slip utilising real track data the apex garage calculator gives a theoretical top speed of 126.35mph.
    My 3rd run last week was 126.22mph. Solid as.
    Terra
    3,375
    Heh, yeh, garbage in garbage out as it turns out!
    And nice one mate, that'd have to be mid 11s then, the bluebird or the new rig?
    Terra
    3,375
    And thanks for the link Jack, will reset long neglected dropbox password and check it out though spoilt for choice now!
    In other news, I have need of your Euro expertise, see euro travel thread and let me know if Oktoberfest, Vienna, Budapest and Prague > Switzerland!
