Results 1 to 22 of 22
Thread: Hotness in 4 bar map sensors
    ¯\_(ツ)_/¯ burn is weird's Avatar
    1,486
    Hi All,
    So I've pegged my delphi GM 3 bar map sensor now on E85 so need to throw a 4 bar in there.. whats the hotness? my sensor is in the cabin mounted near steering column so heat related sensor drift isn't going to be an issue.
    I've seen "GM style" 4 bar map sensors
    "motorsport" style sensor (i think these are a motorola?)
    or an "omni" branded one
    or even a 3.5bar AEM sensor
    ideal would be to use a GM style one as it would be plug and play, but i dont know if any reputable manufacturers actually make a 4 bar version of its just alibaba knock offs.
    thanks cunts
    9,051
    are you saying your emtron doesn't have a 4 bar on board like the haltech elite?
    #emtrontheworld
    (sorry cracka)
    Interested bystander
    786
    One of the 5 bar (absolute) sensors here? ; http://theknockbox.com.au/sensors/manifold-pressure/
    1,486
    Quote Originally Posted by tim510 View Post
    #emtrontheworld
    (sorry cracka)
    and thus ends the list of features an elite has over a KV8
    Inner Westside/Sydney
    1,207
    I can probably email you a smiths racing price spreadsheet (the knockbox site elfturbo posted) if you want.
    1,486
    All good,
    just ordered a 4 bar Motorola map sensor and an 8 bar variohm eurosensor for EMAP from them. pricing was very reasonable.
    I usually use honeywell MLH for everything but they don't do absolute pressure versions.
    thanks Chaps
    Alex
    Wrong.
    6,969
    Hotness is the Pajero OEM diesel sensors.
    I have four Volvo/ford TMap sensors (for reasons), but having a single bung combined temp and pressure with inbuilt CJ compensation that’s designed for manifold (vibration) mount sounds good to me.
    Plan is to use them pre turbo, post turbo, post intercooler and in plenum, then fuck a few off for shed/projects later.
    Emtron and Elite are comparable for sure, in the same way Jennifer Hawkins and Gina Rindheart are.
    Quote Originally Posted by Bosshoggett View Post
    1,207
    What range are they? I think most of the modern diesels have the combined TP manifold sensors but would be 3 bar absolute?
    1,486
    Manifold mount map/iat combined sensors are no good for an ITB rb26.
    Plan is to mount one of the 4 bar Bosch units in the plenum at some stage to use the throttle body flow model in the Emtron.
    It's on the wish list along with dbw itbs if I get around to it this year. Using an E46 M3 throttle motor
    Founder Nick's Avatar
    New New Zealand
    4,387
    #emtrontheworld
    (sorry cracka)
    Haltech Elite only has a 3 bar map built in.
    1 On-board 3 Bar MAP sensor
    • Supports up to 200Kpa of boost (2Bar / 29psi)
    '06 Subaru Liberty Wagon 3.0R-B
    '03 Lexus IS300 2JZGTE
    Jun 2007
    696
    Quote Originally Posted by burn is weird View Post
    Might be worth having a chat with Merlin on here, he's recently used them for an DBW ITB conversion and will know the pitfalls.
    452
    I would use the ti 5 bar map sensor.
    It has good range for both idle and boost, which isnt the case with some other sensors. I assume it will work on Emtron and Link ECU's
    1,486
    cossie can you clarify what you mean by that?
    are you saying the sensor/voltage response is non linear, or the low voltage cal limit of some sensors isn't low enough?
    as in 0-100kpa resolution is different to the 100-400kpa range?
    I would have thought a 0-500kpa sensor is the same as any other 0-500kpa sensor, save for temperature induced errors on the cheaper ones, that and I don't really care about the sub 20kpa range.
    while I'm at it, I'm going to install a boost pressure sensor (pre-throttle) which will allow me to use the throttle flow modelling of the emtron.
    question is, if i'm targeting a maximum boost of say 32psi after the throttle, what is a reasonable sensor range for the pre-throttle map sensor? im guessing even with the BOV, on a fast partial close of the throttle plates will cause the boost pressure to spike sharply. question is how high would be a reasonable guess?
    running the stock dual recirculating BOV of the rb26.
    452
    Sorry, took a while to check back.... For a manifold pressure sensor, you have to look at how far into vacuum your sensor can read. Some of the sensors that read higher boost, cannot read as far into vacuum. that is ok if your engine doesn't pull vacuum beyond that point. so for example, I have these numbers...
    Bosch 030 Map sensor has a working range of 10 kpa up to 115 kpa
    their 487 Map sensor has a working range of 20 kpa up to 250 kpa
    whilst their 655 map sensor has a working range of 50 kp up to 400 kpa (with a core measuring range of 70 to 360)
    So an Mx5 I am looking at has 30 kpa at idle
    My 1200 coupe is in the low 20's
    The Viper is in the mid to high 30's
    So, what does this mean.
    well an absolute pressure sensor used for manifold pressure readings reads 0-100 kpa abs is all the vacuum part of the range, >100 is the pressure side (I am sure that I am telling you stuff you already know, but anyhow)
    so a 250 kpa map sensor will not read outside a range of 20kpa in vacuum, and 150ksa of boost (taking off the 100 kpa of atmospheric pressure) 250 kpa = so this sensor will let you read down low enough in vacuum for any of the engines I see accurately, but only goes up to 21.7 psi of boost.
    The 4 bar map sensor will read only down to 50kpa.... but goes up to 300 kpa (43.5 psi).
    Why does this matter, well, when the car goes back to idle, the bottom 20 kpa will not register, so you cannot change fuel of ignition for any changes below 50kpa, as you cannot read the change. It means that it can be challenging to make it idle, and get off idle reasonably as you cannot read the map changes there....
    so that is why the Manifold pressure range is important...
    Jun 2007
    696
    Hi Jamie,
    Thanks for taking the time to write such a long response, I for one found it very enlightening.
    17,665
    the TI 5 bar is my goto on anything that needs more than a 3 bar,
    1,486
    thanks for the reply cossie, I didn't realise that was the case with these sensors. I'm used to honeywell PX2/PX3 which are all 0.5-4.5v ratiometric and are calibrated for the full rated span down to hard vacuum. couldn't get any with a lead time under 4 or 5 weeks. and am tuning next wednesday.
    the TI sensors are outrageously expensive compared to honeywell PX2/PX3. wasn't about to spend $500 on two map sensors when I could get two PX3s for about 45usd each shipped if the ones above aren't up to it.
    these ones: https://au.mouser.com/ProductDetail/...tent=Honeywell
    I ended up with these sensors:
    which use a NXP MPXH6400A sensor. sensing range is 20 to 400kPa for that unit.
    wired it in and it is 0.1kPa off the baro pressure sensor inside the ecu at atmospheric pressure so I'm happy with that.
    New New Zealand
    4,387
    Yeah that is the same as the Haltech 4 Bar Motorsport Sensor. The Haltech docs don't make much sense to me though. Says 99kpa @ 0v but I thought 100kpa was sea level atmo. Wouldn't -29.2inhg be -99kpa? Maybe a typo? Seems to be a trend.
    Calibration
    Volts 0.0 5.0
    kPa 99.0 315.0
    PSI -14.4 45.7
    PSI/InHg -29.2 45.7
    17,665
    yeh it should be -100..
    Jan 2011
    250
    Besides the typo (-99), perfect vacuum cannot he achieved so you can’t calibrate for this
    1,486
    that is a really strange way of specifying a calibration of an absolute pressure sensor. giving a gauge pressure calibration for an absolute sensor is totally arbitrary as the sensors reference is vacuum, not atmosphere or a defined sealed gauge pressure reference. any good ecu will have a baro sensor on board if you want to tune to MGP instead of MAP.
    i'd use the MXP datasheet calibration of 0.2 to 4.8v being 20-400kPa abs. which is the actual sensor contained in that unit.
    6,282
    It's like that because of the haltech software. it reads gauge in some places and absolute in others. the cal setup is done in gauge.
