Results 1 to 28 of 28
Thread: Garrett G25 series- anyone used them?
    Feb 2018
    2
    Looking for some real world results to confirm the power claims by Garrett.
    Looking to use 2x G25-660 with 0.92AR on a twin turbo V8 for 1000whp.
    Thanks
    1,369
    No experience, but damn they look good (for small engines).
    The compressor maps indicate their power potential, you still need to work out how much flow you will need and at what PR.
    Feb 2018
    2
    Thought as much.
    Yeah I am interested as they are physically small due to packaging of factory turbos in this car.
    If it helps engine details are:
    4200cc
    Quad cam
    40 Valve
    10:1
    7500rpm
    Will be running E85 so I think they will make the power at high boost however ~2-2.5bar
    1,369
    A 2.1 litre bank of cylinders with 90% volumetric efficiency, running 22 psi of boost (pressure ratio of 2.5), at 7500 rpm will need about 44 lb/min of air. That's pretty much bang in the middle of the compressor map at 78% efficiency and I think it could make about 600hp.
    The surge line at 1 bar of boost is at about 13 lb/min of flow, which works out to be about 2800rpm. In other words if it hits 14.7 psi of boost at 2800 rpm or less it will surge.
    I think it's a pretty good match.
    Registered User Turboesky's Avatar
    Feb 2014
    perth
    49
    has anyone taken the leap yet?
    I have been enquiring about the g25-660 from turbotech but they're stating a 12 week lead time.
    Cant see many back to back tests yet.
    gold coast
    1,864
    keep your eye on the Integrated motorsport time attack R34.
    he's gone from a EFR 9180 with 1.44A/R turbine to twin G25-660s in the quest for more shove, so north of 1000hp is the target, as he would have been making that with the EFR.
    Oo___oO
    Feb 2014
    perth
    49
    This the only real back to back test i can see.
    Gtx3076r Gen1 (.64) vs G25-660(.92)
    Wrong.
    7,138
    I'm a bit torn on whether I want to throw one on the old TD42, or an EFR 6258 T4 for something not done before.
    Above dyno is pretty darn impressive given the housing size.
    Aug 2008
    2,223
    Please do. I had my annual read of patrol4x4 forum and it's all the same turbos still.
    8,707
    Are these available with an internal gate?
    Feb 2014
    perth
    49
    According to the Garrett Website, Yes
    Feb 2014
    perth
    49
    MTQ just called me back saying the g25-660 with 0.92 rear is on special for today only. so I pulled the trigger.
    Ideally wanted 0.72 rear tho but can always swap later.
    Will have to do my own Back to Back test i suppose.
    Sunshine Coast, Qld.
    7,781
    Taiwanese built TDO5's are still making 100hp atw more than is physically possible at boost levels they could never attain or sustain on an engine that you shouldn't try and make that sort of power from(however imaginary it is).
    BLING BLING PLAYA's Avatar
    adelaide
    6,288
    If you run it this is relevant to my interests as I want 1000hp +++ on a vr38 and need to packaging to be as small as possible
    3D scanning
    3D modelling
    Structural certification
    3 and 5 axis milling
    Feb 2014
    perth
    49
    Build quality looks very nice.
    Hope to have it fitted next week.
    Feb 2014
    perth
    49
    gold coast
    1,864
    https://www.facebook.com/14836808052...1800643119445/
    they're certainly going to give you 1000hp. this is on an RB28 at bulk Revs.
    Oo___oO
    adelaide
    6,288
    Seems pretty light on any real details?
    3D scanning
    3D modelling
    Feb 2014
    perth
    49
    Pink is gtx3076 gen1 0.63
    Blue is g25-660 0.92
    adelaide
    6,288
    What motor?
    3D scanning
    3D modelling
    Wrong.
    7,138
    Latest hotness is in calling garrett and borgwarner shit as p4x4 and some other anodised thai shit from 1982 in mates brothers 'locked coil cab ute on 37s' makes '40psi at 1200rpm'. Cunts now using 4cm exhaust housing.
    Feb 2014
    perth
    49
    What motor?
    2.0 cosworth
    Jul 2010
    835
    Thanks for being a ginea pig. Saving pennies now
    Feb 2014
    perth
    49
    Need some help.
    I am looking at changing the rear housing to a 0.72 on my g25-660.
    I cant find a part number just for the rear housing. Garrett website looks way different to i remember
    7,781
    Call Golebys, they supplied mine and either housing was available.
    3,602
    pretty amazing numbers. much smaller turbo making more power with less lag. nice nice
    you using internal or external gate?
    windsor nsw
    1,257
    Am I mistaken? Looks to be making less power on more boost but with much less lag.
    May 2014
    623
    Only took Garrett 2 years to finally catch up to the Borg master race.
    The new Garrett rear housings look mighty similar to the Borg design....bit unusual you think Garrett with their history would have all sorts of tricks up their sleeves? Yet their GTX range lagged behind the Borg for quite some time....
