Results 1 to 9 of 9
Thread: Moar Powah ... Cold Air induction
    Sep 2014
    Ballarat
    268
    So for nearly 30 years I've been pulling under-bonnet (hot) air into the induction .......
    Originally it was quad 45DCOE and more recently 8 x Jenvey ITB downdraft.
    Finally organized an air box and now a cold air inlet from over the top of the radiator after data logging finally working and reveals 60 DegC IAT (why was I surprised)
    Have fabbed up an ali runner per the pictures.
    Now I am concerned that all that cold air will affect AFR, so putting an alarm into the dash if it goes over 10 cos the last thing I want is to detonate the engine
    Sandown this weekend will tell ...
ID:	104899   Click image for larger version.
    4,015
    Err what?
    You run your car sub 10:1AFR's?
    460
    Keep an eye on your water temperature, that intake looks like it's pulling air from in front of the radiator, which might partially starve it.
    Sep 2014
    Ballarat
    268
    Is running E85 ... target is ~10. Nervous about going over 10 at WoT - Sandown has 2 uber-long straights and all I do is keep pulling gears - engine says flat for a significant time
    Sep 2014
    Ballarat
    268
    Thansk for tip ... Radiator fed from big opening in the splitter/spoiler as well as grille area - and has shed-loads of ducting. CAI takes top 40mm across the top of the grill under the slam panel.
    Now I have a decent dash I've set a water temp alarm of 106 DegC as well. Historically has never run above 100 DegC unless ambient is 35 plus
    460
    Very good. Best of success on the weekend.
    Nice workmanship BTW.
    Sep 2014
    Ballarat
    268
    Fabrication guy in Ballarat is a whiz ... not my work - I'm a klutz even if I measure twice to cut once !!
    8,242
    Thatís beautiful work. Best of luck for the weekend.
    My Sports Sedan
    Opens profi's Avatar
    Feb 2009
    2,140
    10.0 afr ie .7ish lamba?
    If so why so rich? we were closer to 13:1 AFR with forced induction and e85
    Profi
