Results 1 to 25 of 25
Thread: Upgrading brakes on VL race car
    1,611
    You would think upgrading early commo brakes would bee easy and budget friendly!
    My current set up is C4 (two spot sliding VR/VS era calipers on a 328x28mm rotors on the front, standard sliding 1 pot on solid disc at the back. Whilst they do stop occasionally the car is too quick and a little heavy for them to be reliable (1450kg with driver class minimum weight, IPRA 3J Late model)
    Since i was forced to change the front suspension, i went with VS uprights/VZ adventurer hubs and now can upgrade the brakes to this era. I've got access to new HSV 4 piston with 343x32 floating rotors ( will fit 17's, can run 18's) and HSV 4 piston rears 315x24 vented rear. This fits in with the 4k budget with race pads.
    I believe this should be enough braking as I can survive with the current woeful set up. The itch for a 6 piston, 355 rotor combo is strong, however the cost does blow out.
    After any experience with the above combo or hook ups for a better value set up. The car is reasonably handy, 32's at winton, 47's at PI, 22's at sandown. Pads and servicing needs to be easily available, nothing bespoke or rare, hence the factory commo parts
    Adam
    Sandown 1.23.31
    Calder 1.05.76
    Phillip Island 1.47.95
    Winton 1.33.30
    Bathurst 2.47.49
    10,816
    Brockas (Paul Brockbank) from Antilag does bloody good pricing on HSV spec 6 pot Brembos and Rotors new stock. Might be worth checking with him first.
    Bentleigh Victoria
    3,663
    X2. I also need brakes, but my budget is non existent.
    I hope to get some money soon, so on the look out.
    1,274
    Wouldn't get you front and rear, but no rubber dust boots to burn up like street based stuff www.powerbrake.co.za Believe the commo made it to SA, so might be able to make an adaptor bracket over there with any luck.
    350 x 34 and 6 piston was around 3 grand Au, 2000 rand cheaper in 4 pot, 5% duty and 10% gst should be under that 4k, 17" might be marginal?
    1,202
    These new 6 pistons Alcons seem to be the business.
    I have even ordered a set for my overweight pig.
    Available from gslrallysport on here.
    https://www.allports.nz/product-grou...aliper/product
    FG XR6T ZF - Road registered 410rwkw Circuit car. GONE! Written off courtesy of 2018 Hail Storm.
    668
    A thought from left field..... have you considered Porsche Cayenne front brakes? A mate has a Cayenne, and was working on the brakes a couple of weeks ago, said he was surprised about how cheap the parts for them were.
    Jun 2007
    758
    Check the pad shape for your HSV calipers and make sure it's well supported. One of the problems with some of the Alcon calipers is that they run an uncommon pad shape which is not only expensive, but seriously limits your choices for compounds. I assume that you can get a proper 72 vane rotor in the correct PCD for the HSV fronts, I can't see on in the DBA5000 series catalogue.
    Registered User DJ345's Avatar
    melb eastern subs
    173
    This link is for the ctsv 6 piston brembo's adaptor brackets.
    https://www.bohnmancustoms.com/GTO_6...8_9873441.aspx
    Calipers off ebay
    https://www.ebay.com.au/itm/2009-12-...19.m1438.l2649
    Jul 2015
    NZ/NSW
    177
    First of all what compound do you currently use? if you are talking about overpowered and underbraked cars, we supply Circo M207's to a few cars in the Touring Car masters. good consistent friction with temp rated to 920˚C. Also 1 of 3 control pads for the V8SC's. Same pads cope with the abuse of 6hrs of bathurst, targa tas, Australian Offroad Championship cars etc etc.
    Most aftermarket kits will run you up 4-6k for fronts alone, even the Powerbrake X-line in a 4 piston 350x34mm is close on 5K. So if you can pick up some HSV upgrades that will work withn your budget
    Komdotkomm- Alcon pad shapes are very common amongst the performance brands
    443
    Quote Originally Posted by adamRSLC View Post
    I believe this should be enough braking as I can survive with the current woeful set up. The car is reasonably handy, 32's at winton, 47's at PI, 22's at sandown. Pads and servicing needs to be easily available, nothing bespoke or rare, hence the factory commo parts
    Adam
    I and a couple of others ran VTs in QTCC with 343/315 or 343/343 HSV brakes for years. I have since changed to 378/343 as per Supercars.
    The 343/315 or 343/343 HSV kits need good pads. I always used Pagid RS14s and had good success but others tried cheaper
    pads and were less happy. The 343/343 HSV packages were the better choice for the heavy VTs but with a VL you should find the 343/315
    adequate.
    Choice of front/rear pads is important to get the right balance unless you have a balance bar setup.
    Radical SR3
    HSV R8
    BMW 325ti Proddy Car
    SA
    124
    This thread is relevant to my interests. Have you seen this? http://www.brakesdirect.com.au/alcon-big-brake-kit-sale
    Jun 2007
    758
    Wow, that's outstanding value.
    Bentleigh Victoria
    3,663
    Does seem reasonable.
    1,611
    Jeez that is a good link, thanks fnlow. I'll be chasing that up, I'm hoping it will fit under 18's.
    Adam
    Sandown 1.23.31
    Calder 1.05.76
    Winton 1.33.30
    Bathurst 2.47.49
    Opens GAZ914's Avatar
    1,624
    Be sure to research the availability of replacement discs.
    You may not need them for quite some time - will you be able to get them/make something else fit in a few years?
    I've seen a lot of people having to rework the brakes they got cheap because they can't buy replacement parts later on.
    Often that means custom hats to suit available rotors and/or brackets to move the calipers to suit, etc.
    Same goes for caliper seals, etc when you want to do some maintenance in the future.
    Generally our race brake kits use relatively common AP Racing discs and calipers so we can support them into the future.
    cheers
    Gaz
    Race Car: VT Commodore (Murray)
    www.vsport.com.au
    1,202
    V Sport have Brembo specials on
    Jul 2015
    NZ/NSW
    177
    The advantage extreme Alcon kits arent really a race kit, moreso a hi performance / modified road car, and occasional track day caliper
    gslrallysport.com gslrallysport's Avatar
    Mar 2007
    656
    The issue I have with the Cayenne brakes on a much lighter car is that the swept depth is way too high, which means a big heavy overweight rotor, and the subsequent ridiculous increase in unsprung weight. I'd be looking at a 54mm ish deep pad for something VL weight.
    Mar 2007
    656
    Quote Originally Posted by Komdotkom View Post
    I don't know of a single Alcon caliper that has this problem. All the motorsport range is heavily shared with AP Racing and Brembo, and the Advantage Extreme stuff is shared with Jaguar, HSV and Porsche road cars, so even manufactures that don't make pads for race calipers normally, have pads for the Advantage Extreme ones.
    Mar 2007
    656
    Quote Originally Posted by fnlow View Post
    That link is a little out of date. The rotors we supply now in those kits are the Forza ones, which are curved vane, forward facing curved slot (same as Brembo motorsport).
    This is the 365mm rotor that would now come in those kits:
    http://brakesdirect.com.au/aus/ffd-3...-pcd-left.html
    Those rotors are completely interchangeable with the Alcon and DBA ones that proceeded it.
    Mar 2007
    656
    Quote Originally Posted by GAZ914 View Post
    Alcon discs?
    1,624
    Quote Originally Posted by gslrallysport View Post
    Alcon discs?
    No brand in particular - just an observation about doing something 'cheap' in the beginning that turns out not-so-cheap eventually.
    Probably applies to a large portion of PF!
    www.vsport.com.au
    668
    Good point.
    Is there any reason not to take material off the pads so that they matched the swept surface of a light weight rotor? Apart from the hassle and wasted friction material.
    Mar 2007
    656
    Good point.
    Your pistons then wouldn't be in the middle of the pressure area.
    668
    So if you take an even amount off the inside and outside of the pad it would be ok? The caliber would need to sit a bit further out so you would need enough wheel clearance to play with, relative to rotor diameter.
