Results 1 to 9 of 9
Thread: Might weld troubleahooting
    あなたの母親の肛門 Shifty's Avatar
    10,804
    Sorted my first drama, was a gas issue.
    Tacking thin panel steel, have good pen but a divot both aides in the centre of the tacks.
    Thoughts?
    100% agree with Shifty
    16,437
    too much heat?
    Just remember, "Grinder and paint make you the welder you aint!"
    10,804
    Asked around a few pros. The sink is due to the rate of cooling & unavoidable given material and welder.
    16,437
    I've seen it on the torch side of the weld, never seen it in the back side penetration like that before.
    6,212
    try reversing the polarity? what gas are you using?
    #sydneydents Blow's Avatar
    Apr 2007
    Somewhere in Straya
    3,965
    Looks fine, you won't have an issue after it's ground down and painted etc.
    668
    If you are that concerned, could you put a copper heat sink on it?
    If it were mine, I'd be doing as the others have suggested, just grind it down.
    10,804
    (Especially once overlaid to make a full seam)
    May 2004
    5,120
    Dont change the welder settings and try and lay down a bead. I wouldn't be surprised if its porosity. So check stick out, make sure the nozzle isn't full of shit, check gas flow, etc.
