Results 1 to 30 of 50
Thread: Automotive paint messing up radio reception?
    6,276
    OK, this is a weird one.
    I had the rear bumper and rear spoiler on the XKR painted.
    The AM/FM antenna is a foil-type thing, on the inside of the plastic spoiler, spoiler is a urethane material, the antenna is a stick on thing on the inside, fitted from the factory.
    The DAB antenna sit's behind the bumper cover, it's also a foil but on a plastic frame.
    Both these antennas are mounted where they are mounted because they are behind plastic, not metal.
    Since having the bumper and spoiler painted, AM, FM and DAB radio in the car has gone to shit.
    I swapped out all the DAB components; receiver, antenna, antenna amplifier, antenna cable, results are the same.
    Can't swap out the AM/FM antenna as it is stuck on the inside of the spoiler, but I still have the old spoiler with the original antenna in it, reception is fine with that one plugged in.
    The only thing in common here is that they have just been painted.
    Has anyone ever heard of this happening?
    The Crime Zone
    30,656
    They couldn't have rooted a cable or plug you haven't replaced?
    6,276
    Nope, have been through all the wiring, it's a reception problem, as in the reception is being blocked by the painted parts. Which I never heard of, and neither has anyone else I asked about this.
    With the AM/FM I can actually improve the reception by moving around the rear of the car and standing in a sweet spot. I can make it worse by placing a sheet of alfoil over the antenna location.
    The DAB reception is fine with the antenna removed from under the newly painted bumper.
    It's like the paint is full of metal or something...
    15,063
    With the new spoiler can you just disconnect the brake light in it, and see if it improves the reception
    Slanted big_pete's Avatar
    Sep 2003
    Wagga
    7,791
    Just drill some holes to let the reception in
    16,437
    It's metallic paint yeah?
    3,624
    If it's a metallic finish then yes there are tiny bits of aluminium in there but I don't think it would act like a one continuous metal part - the plastic/polymer parts of the paint are usually non-conductive.
    Are you sure they didn't use this?
    http://www.emraustralia.com.au/shop/...hsf54-5-litres
    Marvellous things so quickly get mundane
    Oct 2016
    Central Coast NSW
    186
    Was thinking the same thing. The metal content in the metallic portion of the new paint is blocking/messing with the signal being received?
    3,624
    So you put a new spoiler on it and painted that? What was the reception like with the unpainted new spoiler.
    Maybe it's you, maybe since you started owning more flash jags you've become less grounded or something?
    6,276
    Funny enough, if I remove the brake light from the spoiler and let it hang, the FM improves a bit and doesn't seem to be affected by me moving around.
    But there's no power going to the light.
    And I mean walking around 3 metres away it was changing the reception.
    Quote Originally Posted by big_pete View Post
    I'm with you
    Yes, but so was the paint on it before.
    3,624
    Maybe they overcharged you for the paint job.
    Oct 2016
    Central Coast NSW
    186
    Perhaps the original paint had aluminium based metallic paint in it? Unlike the newly painted pieces, which maybe American based aluminum metallic?
    6,276
    Quote Originally Posted by Rascasse View Post
    It's just paint though, metallic yes but so was the paint on the old spoiler, and on the bumper before too.
    Quote Originally Posted by lumpy View Post
    Never had the new spoiler on unpainted, but the old one was painted and has the exact same antenna in it.
    Hmmmm
    16,437
    Did they strip the old paint?
    15,063
    You can still get passive interference running along the cable, hence if possible disconnecting at the last known good point. May have a dodgy joint or some thing, have seen similar issues with power cable with mobile phone antennas
    6,276
    Not sure about the bumper, maybe not.
    But the spoiler was brand new out of the box, in primer.
    I know a couple of other people who had the exact same spoilers painted in metallic finish, never had an issue with radio reception as a result.
    One other weird thing, if I connect a charger up to the battery, the reception disappears completely, which it never used to do.
    Driving around on roads I regularly travel, it's dropping in & out heaps, which it never used to do.
    6,276
    Hmmmm, the thing with the battery charger has me wondering now, maybe they crushed a loom somewhere and it's shorting out power to ground?
    16,437
    Odd. long shot - did they bake it?
    Might be time for something like this:
    Jun 2007
    Yeppoon
    4,247
    It is surprising how easy it is to block radio signals - a simple chip packet will block signals to your phone.
    9,476
    what is DAB?
    Registered User Gats's Avatar
    7,488
    Spotify.com will fix it.
    4,892
    check if there is any blacked out window A team Vans parked across the street - be the council doing wire tap and radio surveillance on you to get evidence for letting your dog shit on the footpath
    Aug 2013
    gawler
    1,909
    I'm going with something in the paint, old industrial enamel used to have a high lead content, enough to mask uranium ore radiation emissions.....
    Registered User TRH510's Avatar
    302
    Spoke to our JLR approved repairer and they've never had this problem. Weird one.
    They use PPG.
    Sent from my Nexus 5X using Tapatalk
    302
    I'd go with damaged harnesses. Panel shops often do this.
    6,276
    Well, make a note of this in the Weird Shit file, started pulling the bumper off, got the left tail light out and the radio sprang to life.
    Oct 2016
    Central Coast NSW
    186
    Once the left tail light was re-installed, reception stayed strong/consistent?
    Jan 2011
    1,673
    Quote Originally Posted by TRH510 View Post
    This.
    6,276
    Yep, all back together now, everything's fine.
    The guy who did the painting knows how to paint, but disassembling and reassembling cars doesn't seem to be his forte.
    When I first picked up the car the parking sensors and active exhaust weren't working, there was a loom unplugged in the boot, pretty straight forward.
    Then I found some bolts and nuts missing...
    And now I found the harness inside the rear bumper was just hanging, rather than clipped into place.
    Honestly I got NFI what the problem was here, but it must have been a short or something putting battery voltage into the chassis.
    Magnets or some other witchcraft
    2,377
    Lucas Prince of darkness????
