Results 1 to 21 of 21
Thread: brake line tools. What's not crap (hard lines)
    free hugs! Paddington's Avatar
    May 2003
    Under a BMW
    6,216
    Have seriously had a brain meltdown and totally stuffed the front brake lines on a project so I need to make new hard lines.
    It's a 70's mazda and the brake tubing is 5mm OD. NFI what the thread pitch is on the fittings.
    Where can I get some tubing from (ideally in Melb or have it shipped) and where can I get a decent non crap brake hard line bending tool and then a flaring tool? I need to make two front lines for this project and then a few more for another.
    Quote Originally Posted by Stix Z
    Quote Originally Posted by Jim
    Registered User Shane001's Avatar
    Jul 2007
    932
    I just used my roll cage to bend my brake lines. Was only using standard bundy tube but worked fine and easier to get the exact bends where I wanted them then using a bending tool. Just pull the tube around the bars and bends perfect. Can even do full 180's.
    Aug 2003
    5,816
    I managed OK with the cheapest bender and flaring tool money could buy from eBay (was black with red handles), hard line should be easy to find, just google or ring around.
    EDIT: similar to
    https://www.ebay.com.au/itm/180-3-in...gAAOSwUwFaQhBp
    and
    https://www.ebay.com.au/itm/Flaring-...IAAOSwsTxXkinB
    I think the flare tool was cheaper than that worth getting a better one as it took a fair bit of fucking around to get workable flares. Was good for putting bards on fuel line too though.
    Pollitically incorrect
    Aug 2007
    7,236
    Reece/ tradelink etc etc?
    .... because every driver experiences the destructive potential of the effortless surge of power available through the smallest of body movements.
    Dr Hoon
    DrNick is king!!!! No, Mark Webber is now! Long live the king!... hold on a minute mate, Ricci is in charge now
    May 2003
    Under a BMW
    6,216
    There's a brake place in Derrimut that has everything... but they only do wholesale. Fuckers.
    10,205
    I have a dual action flarer and bending tool. Also ABS chains sell the ferrules and bundy.
    I cant get no sleep...
    AE86 race car thread is finally up to date | Supposedly i have a new daily project too
    xxxx BoboTheMonkey's Avatar
    Jul 2016
    past the berrimah line
    28
    trailer shops sell pre-made lengths
    Boldy going nowhere rolin7's Avatar
    Mar 2006
    Not Mt Druitt
    1,140
    Any brake shop should be able to sell you a length of 6 metre bundy tube.
    I just bought a roll off these guys -> https://www.ebay.com.au/itm/x-TRAILE...D/251866647234
    Flaring tools aren't worth buying unless you buy the good ones for around $350, have used this model and they make it so easy -> https://www.eastwood.com/professiona...ring-tool.html Alternative is just bend the lines and take them to a brake shop to flare.
    For the 90 bends, use a glass for non tight bends, for everything else, buy one of these -> https://www.ebay.com.au/itm/Mini-Tub...1/292144807549
    Pain is temporary, quitting is forever - Lance Armstrong (drug cheat)
    Aug 2003
    5,816
    this looks good for the price, no experience with this type but it looks harder to make than the one I linked above so i guess it will work better. https://www.ebay.com.au/itm/Genuine-...QAAOSwB9JZciRz
    Title pending
    2,877
    Pro tip
    Find a brand of bundy called Reliance... its distributed by Brake Parts Aust in QLD
    Nice stuff... easy to flare and bend... won't even need a bender
    And buy a decent flare tool... like the Eastwood vice mounted one... if your going to do flares in the future
    If your doing a few quick jobs... that $52 one will do
    Location Perth Western Australia
    25 schmeckles? Do the safety dance.'s Avatar
    4,285
    I recently got that cheapo one posted above. Works great for the price, much quicker to use than my more expensive universal pipe flaring kit.
    BOOSTFARKIN Morcs's Avatar
    May 2012
    613
    Those ebay black red specials suck balls... ok for 1 or 2 occasional uses but not overly great ..
    ie thread on the screw thing galled up pretty much straight away drilled and tapped it out machined a larger bolt to size and the cone on the end will not stop spinning when doing the second part of the flare.
    The good part is very small length needed to do the flare.
    Ive got a real old school meco one also that is well worn but does the job
    Ive got a bender from repco is like a set of pliers that wraps the pipe into a die.
    9,116
    Ive got a wurth turret flaring tool, but im planning to buy one of these too.
    Would making on-car changes way easier. $40 is dumb cheap..
    https://www.ebay.com.au/itm/jimy-Pro...19.m1438.l2649
    10,205
    Quote Originally Posted by tim510 View Post
    Damn, that is pretty good. Especially given the price.
    May 2003
    410
    Same price at Supercheap too. So if member/trade you get it for less.
    We had a guy come in to do a cut and shut on an abraded brake hard line
    and when he left he went straight next door to Supercheap and bought one.
    Its a direct copy of the Eastwood one.
    edit. or is it the Toledo one, one of them anyway
    Radical SR3
    HSV R8
    10,205
    Quote Originally Posted by GHZ28 View Post
    Nice. Pity it doesnt come down any on Club price, probably only Trade. Plus the shipping is more from SCA given its an order in item.
    Wrong.
    6,993
    i made an adaptor to hold your worth flaring tool, to do some on car in situ. Big old bit of nb40 pipe, few bits of rhs as a clamp, and a few bend options on the nb40 to position as needed. Worked fine now itís in the dirt and the dog plays with it.
    Quote Originally Posted by Bosshoggett View Post
    May 2003
    410
    Quote Originally Posted by takai View Post
    yes online says online only, but Browns Plains said they had just started carrying them in stock as of week before last and had 7 on the shelf.
    It only comes down a little with trade card.
    Radical SR3
    HSV R8
    15,330
    Can highly recommend Tim's Wurth unit. Works most excellently.
    I wonder if there's a version of the jimy that does bubble flares?
    9,116
    I donít even remember loaning it to Cracka and gammaboy. Glad it gets some use though!
    10,205
    Cool, ill give Maribyrbongs a go then.
